Question about Vector ® Maxx SST 1200 - watt Power Inverter
Green light on but no ac power out
I check the fuses and there are ok theres 5 fuses please help
Tip
Fuse list ford contour
The following specifications are for the Ford Contour and Mercury Mystique manufactured throughout 1995-2000.
Fuses Rating Color Circuit
Engine bay fuse box
1 80 Black Power supply to main fuse box
2 60 Yellow Radiator fan
3 60 Yellow ABS
4 20 Yellow Daytime running lights
5 30 Light green Fog lamp
6 30 Light green Not used
7 30 Light green ABS
8 30 Light green Air pump
9 20 Light bue PCM module
10 20 Light bue Ignition switch
11 3 Violet PCM memory
12 15 Light bue Horn & hazard flasher
13 15 Light bue Oxygen sensor
14 15 Light bue Fuel pump
15 10 Red Right-hand low beam
Passenger compartment fuse box
16 10 Red Left-hand low beam
17 10 Red Right-hand high beam
18 10 Red Left-hand high beam
19 7.5 Brown Heated door mirrors
20 10 Black Windshield wipers
21 30 Light green Electric windows
22 7.5 Brown ABS
23 15 Light bue Reverse lights
24 15 Light bue Brake lights
25 20 Yellow Door locks
26 20 Yellow Main light
27 15 Light bue Cigarette lighter
28 30 Light green Power seats
29 30 Light green Heated rear window
30 7.5 Brown Engine management
31 7.5 Brown Instrument pannel lights
32 7.5 Brown Radio
33 7.5 Brown Front and rear sidelights (left)
34 7.5 Brown Interior lighting & clock
35 7.5 Brown Front and rear sidelights (right)
36 30 Light green Air bag
37 30 Light green Heated blower
38 Unused
Relays Color Circuit Location
Engine bay fuse box
R1 Green Daytime running lights (Canada)
R2 Black Radiator fan (high speed)
R3 Blue AC cut-out
R4 Brown AC clutch
R5 Dark green Radiator fan (low speed)
R6 Yellow Starter
R7 Brown Horns
R8 Brown Fuel pump
R9 White Low beam headlights
R10 White High beam headlights
R11 Brown PCM power supply
R12 White Interior and courtesy lights
R13 Yellow Heated rear window
R14 Yellow Heated blower
R15 Green Windshield wiper motor
R16 Black Ignition
R17 Unused
R18 Black One touch window switch Driver's door
R19 Blue Cruise control cut-off Central fuse box bracket
R20 Unused
R21 Unused
R22 White Fog lights Interface module bracket
R23 Black Turn signals Steering column
R24 White Left-hand flasher Door lock module bracket
R25 White Right-hand flasher Door lock module bracket
R26 Unused
Bulbs / Lights Wattage Type
Low beam headlamp 55 9006 Halogen
High beam headlamp 55 9005 Halogen
Parking / Side light 5 2357A Wedge
Front turn signal 21 2357A Bayonet
Rear turn signal 21 1157 Bayonet
Tail light 21 1157 Bayonet
Stop light 21 1157 Bayonet
High mount stop light 5 2723 Bayonet
Fog/Driving light 55 893 Halogen
License plate 5 6418 Festoon
Reverse light 21 1156 Bayonet
Front sidemarker 5 2357A Wedge
Glove box
Map light 5 64111 Wedge
Dome light 10 6411 Feston
Step/Courtesy light
Trunk/Cargo area
Engine compartment 10 89 Wedge
Instrument-general
Automatic trans indicator
on Apr 15, 2015 | Ford Contour Cars & Trucks
Tip
LCD TV TROUBLE SHOOTING
1.Do not power on .
1 .1 Please check AC cable if connect to AC plug. Is true the connector don't connect to AC plug. Please connect it.
2.2 Please check AC cable if connect to AC power. Is true the AC cable don't connect to AC power. Please connect it.
3.3 Please check power board of fuse if broken. If the F1 fuse is broken, Please pull out the AC cable from AC power. Please check AC L power and AC N ground by multimeter, The read number is infinite, the fuse is broke. Then look up power board if not burn out place. Is true it. Please change power board or be changed power board.
2. The power on switch of green extinguish.
2.1 The power of led(indicator light) is red light, To touch power on key when indicator light wink. Is true that the power DC output have somewhere short circuit. Check connector J39,J31 .If not connector direction is wrong. Or the mainboard somewhere of power short circuit.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
on Feb 14, 2015 | iLO Televison & Video
I have a 1999 Ford contour lx neither the brake lights nor the turn signals will work what would cause this
a fuse number 24,,,
Fuses Rating Color Circuit Engine bay fuse box 1 80 Black Power supply to main fuse box 2 60 Yellow Radiator fan 3 60 Yellow ABS 4 20 Yellow Daytime running lights 5 30 Light green Fog lamp 6 30 Light green Not used 7 30 Light green ABS 8 30 Light green Air pump 9 20 Light bue PCM module 10 20 Light bue Ignition switch 11 3 Violet PCM memory 12 15 Light bue Horn & hazard flasher 13 15 Light bue Oxygen sensor 14 15 Light bue Fuel pump 15 10 Red Right-hand low beam Passenger compartment fuse box 16 10 Red Left-hand low beam 17 10 Red Right-hand high beam 18 10 Red Left-hand high beam 19 7.5 Brown Heated door mirrors 20 10 Black Windshield wipers 21 30 Light green Electric windows 22 7.5 Brown ABS 23 15 Light bue Reverse lights 24 15 Light bue Brake lights 25 20 Yellow Door locks 26 20 Yellow Main light 27 15 Light bue Cigarette lighter 28 30 Light green Power seats 29 30 Light green Heated rear window 30 7.5 Brown Engine management 31 7.5 Brown Instrument pannel lights 32 7.5 Brown Radio 33 7.5 Brown Front and rear sidelights (left) 34 7.5 Brown Interior lighting & clock 35 7.5 Brown Front and rear sidelights (right) 36 30 Light green Air bag 37 30 Light green Heated blower 38 Unused Relays Color Circuit Location Engine bay fuse box R1 Green Daytime running lights (Canada) R2 Black Radiator fan (high speed) R3 Blue AC cut-out R4 Brown AC clutch R5 Dark green Radiator fan (low speed) R6 Yellow Starter R7 Brown Horns R8 Brown Fuel pump R9 White Low beam headlights R10 White High beam headlights R11 Brown PCM power supply Passenger compartment fuse box R12 White Interior and courtesy lights R13 Yellow Heated rear window R14 Yellow Heated blower R15 Green Windshield wiper motor R16 Black Ignition R17 Unused R18 Black One touch window switch Driver's door R19 Blue Cruise control cut-off Central fuse box bracket R20 Unused R21 Unused R22 White Fog lights Interface module bracket R23 Black Turn signals Steering column R24 White Left-hand flasher Door lock module bracket R25 White Right-hand flasher Door lock module bracket R26 Unused Bulbs / Lights Wattage Type Low beam headlamp 55 9006 Halogen High beam headlamp 55 9005 Halogen Parking / Side light 5 2357A Wedge Front turn signal 21 2357A Bayonet Rear turn signal 21 1157 Bayonet Tail light 21 1157 Bayonet Stop light 21 1157 Bayonet High mount stop light 5 2723 Bayonet Fog/Driving light 55 893 Halogen License plate 5 6418 Festoon Reverse light 21 1156 Bayonet Front sidemarker 5 2357A Wedge Glove box Map light 5 64111 Wedge Dome light 10 6411 Feston Step/Courtesy light Trunk/Cargo area Engine compartment 10 89 Wedge Instrument-general Automatic trans indicator
Apr 15, 2015 | 1999 Ford Contour
1990 Isuzu Truck 2.6 5-Speed , Cranks but no fire to the plugs, new cap. rotor Turn key to ignition on and no check engine light, no heat/ac , no flashers. HELP!
OK several things to check, is there power to the fuel pump, check as close to pump as you can? and did you check the ignition coil?
Jun 09, 2012 | 1990 Isuzu Spacecab
The generator starts ok but no electric been produced and no light on
my generator has lost it's field. How do I recharge it? there are 5 wire from the generator: red, black, yellow/green and two green. I assume that the two green wires are the field. as the red black and yellow.green goes to the output plug.
Jun 17, 2010 | Briggs & Stratton 11HP 6200W Es Generator
Please Help! I THINK I have a bad power supply (a bestec atx-300-12eb3 rev s2 from a Sony Vaio VGC-RB30). Power will no longer come on at all, however I do have a blinking green light on the back of the...
ok first you disconnect the power supply from motherboard then measure the output voltage if it is ok then there is two wires green and black at o/p of power supply short green and black and see fan is rotating or not if rotating then power supply is ok if not then open the power supply check ac voltage in the pcb if present then check dc voltage after bridge rectifier and ckeck part by part
Feb 23, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Please help my indesit ta 5 fnf s is dead with no warning. no lights no power nothing. its not fuse power or socket
Had the same problem with my TA5FNFS once you have confirmed as there is power in the wall socket and the fuse in the plug and cable are ok, I found as the PCB control board had burnt out costs about £60 for a replacement board
Apr 30, 2009 | Freezers
INFOCUS LP240 POWER SUPPLY PROBLEM
Caps being burned. caps usually go bad or explode because of to much voltage, was it hit by lighting?
But you say the fuse is ok... I would look for voltage regualtors or resister type fuses that are blown.
you might want to check with ptscorp.com to see if you can send in the power supply.
Feb 06, 2008 | Televison & Video
Vector ® Maxx SST 1200 - watt Power Inverter Logo
94 people viewed this question
Top Vector Electronics - Others Experts
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
