Question about Bosch DAH9505 30in Traditional Wall Updraft, Stainless Steel, Half-Round Bullnose Style Kitchen Hood
Bosch DAH9505 Hood Auto-On
I have a Bosch DAH9505 Hood, which supposedly has a thermal switch that will turn the fan on, at its lowest setting, if it detects a temperature above a certain setpoint.
I'd like to be able to lower that setpoint, or even better, find a way to trigger it by some other means like a motion sensor (aimed at the stove).
The problem I'm trying to solve is that more often than not, the user forgets to turn the unit on when cooking, which rather defeats the purpose.
In fact, the perfect solution would be to somehow trigger the fan (preferably the medium or even high setting) just by turning the stove on.
Ideas?
I have a friend who is an electrical engineer who, with a wiring schematic, could no doubt devise a (safe) way to do this if you don't know of a solution, but I would need to find a schematic.
Thanks!
4 Suggested Answers
SOURCE: Bosch HBN 455 Oven Cooling-Fan Issue
Our HBN655 had similar issues- the upper cooling fan would cycle on and off on a relatively quick duty cycle until the whole mess cooled off enough and it shut off.
My workaround is to turn the temperature dial off but leave the oven function dial on to BAKE. This seems to force the fan to stay on; then we shut it off a while later and avoid the annoying fan cycling.
(note- 2 years ago, our fan became intermittent, varying speed, etc... for about 2 months before it quit entirely. When that happened, the oven started to heat then the thermal cutout kicked in and the oven shut down entirely. We ended up replacing the fan and that fixed the bug... except now it's starting to act up again...)
(also note- the racks on this beast have a faulty design. if you have a heavy casserole and slide the rack out all the way, it tends push the sidewalls apart and the rack drops. I spoke with Bosch about this and they sent me new racks, no charge... so they know there's a problem. But the new racks don't fix the bug; they just make it harder to reproduce. I have actually had one rack fall with 2 piping hot casseroles on it. Fortunately no one was hurt.)
Posted on Nov 04, 2007
  • 103 Answers
SOURCE: Fridge not getting cold Bosch KGV36390/05
Hi: It shouldn't need a recharge as your freezer is cold, and that's wher the fresh food section gets its cold from via a fan. If your vents are blocked with too much food in the freezer this will happen. If you have a problem with the defrost heater or timer frost will build and block the port to the fan, causing a warm fresh food section. If the circulating fan is out your f.f. section will get warm. It's a small fan not to be confused with the condenser fan below (at the grill.) Here's a question for you. Did the fresh food compartment work for the first week or two? That's how long it would take frost to build and jam the system if your defrost system is out. If this is the case you can unplug it and put your food in a cooler. Melt the frost with a hair dryer carefully avoiding plastic components. It will then work for a week or two before it fails again. It will get you buy until you get service. If you do it yourself... Look for the defrost heater in the freezer and see if the coil of wire in the glass tube is broken. You will need a service manuals or a parts list with a diagram. Sears parts on line has a good database of parts and diagrams. Hope this helped, Jeff
Posted on Jun 01, 2009
bobhifi
  • 635 Answers
SOURCE: We have a problem with two of the burners on our
Remove the brass burner heads.Remove the Butterfly nut ( in some models just a screw ) and remover the cast iron base.At the narrow end there is a nozzle with a small pin hole which couples with this pipe. Take a fine needle or pin and insert into the small hole and clean. Reassemble and Voila !!!! bobhifi.jpg
Posted on Mar 07, 2011
I have an evcon furnace that was put on brand new about 5 years ago. I have noticed that it doesn't seem to be kicking off and it doesn't seem to be heating my home either. A line was kinked last year...
This going to be little lengthy. The fan can be on from two reasons. If your thermostat has a fan switch, it will say ON or AUTO. Put it to AUTO. Turn your thermostat to its lowest setting and wait 3 or 4 minutes. If the fan stays running, the problem is in the furnace. Newer furnaces have big circuit boards that control all its functions. The fan automatically starts after a factory set period of time (about 45 seconds). Try a HARD reset to get all the furnace functions back to normal. Turn your thermostat as low as it will go. find the breaker or fuse that serves only the furnace. Unscrew the fuse or turn off the breaker for a good minute and replace/reset it. If the fan starts right away, the board is probably bad. PC relays often arc together and the entire board will need replacement. If the fan is off, turn your thermostat way up and see if the furnace lights. The fan will probably restart in a minute or so as a normal function, heat or no. If the furnace does not fire, Let me know and I'll tell you how to check that switch that was replaced.
Oct 24, 2013 | Heating & Cooling
I have a vostro 200 large tower with a g33m02 motherboard. The cpu cooling fan is very loud. (not bearing loud, but it seams to try a lot harder than it needs too for what the computer is doing.) the cpu...
Check your BIOS Settings
CPU Configuration
CPU Internal Thermal Control [Auto]
Hyper Threading Function [Enabled]
Intel(R) SpeedStep(tm) Tech [Auto]
Power>Hardware Monitor
CPU Q-Fan Control [Enable]
CPU Fan Ratio [Auto]
CPU Target Temperature [60degC] (lowest setting available)
or you can replace it with Cooler Master XDream
Sep 20, 2011 | Dell Vostro 200 Desktop Computer
Blower motor/fan wont shut off when you press off switch,can turn speed down to lowest setting,when you push off switch it speeds up 09 expedition eb
It needs to be replaced or someone had this apart and put it back together the wrong way. If you cannont figure it out, bring it to a dealership and ask them. This is an 09 something like this may be under warranty if you didn't do anythign to it.
Mar 29, 2011 | Ford Expedition Cars & Trucks
I have a simple comfort 2000 thermostat and the fan will not cut off unless I cut the breaker off. The thermostat cuts the ac unit off and on but the fan will not go off. What could be the problem. I only...
Sounds like the Fan/Auto switch is not working or is out of the circuit. Do you have a Volt/Ohm meter to check the switch? Set the meter on Ohms on the lowest range, turn off the breaker, disconnect the leads from the switch, and put the probes on the connections to the switch. The reading will be near zero when you touch the leads to connections that are turned on by the switch. You can buy cheap meters at Harbor Freight ($5) or other discount places. If the switch is working, it has been bypassed somehow, or the wires are connected wrong. Did you recently install the thermostat?
Aug 21, 2009 | Heating & Cooling
2002 Honda Odyssey fan only works at high speed. The A/C compress
Usually when the blower fan only operates on hi speed, its because of a failed blower motor resistor. You still have hi speed because on hi, the power going to the blower motor goes directly to it, as opposed to the lower speeds, when the power is routed through the resistor, thus lowering the voltage, which in turn lowers the speed of the fan. The resistor is usually located near the blower motor itself, under the hood back near the firewall.
Aug 15, 2009 | 2002 Honda Odyssey
Range Hood Issue
Definetly need a new motor control.
Nov 26, 2008 | Kitchen Ranges
Vornado heater doesn't work on high setting but only at low setting
Dust on the inside of the unit can cause the overload switch to shut many vornados down. Blowing the dust out of the unit with compressed air or a blower may help.
Another problem that causes vornados to stop working (light on - no heat no fan) is when one of the bearings starts to go bad in the unit. This causes the fan to be slower and less effective and the unit’s inability to move the heat away from the thermal overload switch again causes it to shut down.
Though you could remove the front and rear bearings and try to get replacements if it's even replaceable ... Once the bearing starts to go bad there is little that can be done ... HOWEVER, here is one solution to get more life out of the unit.
First, use a blower to blow all the dust out of the unit.
Then, because it is typically the front bearing that goes bad first, lay the vornado on it’s back (so the unit would be blowing air up toward the ceiling), this will relieve the front bearing somewhat and rely more on the rear bearing which tends to last longer.
The vornados I’ve had are all thermistor units ... that is, they don’t just turn on and off when the set temp is reached but in fact slow themselves down (both heat and fan) to keep some level of air circulation in the room. This is a good thing by the way.
There are usually two toggle switches .... one is a heat switch - usually Low & High .... the other is the thermistor switch (this sometimes is labeled “fan”) - usually Auto & High.
Once the unit is on its back ... Now, change the settings as follows:
Turn the Heat switch to LOW
Turn the Fan switch to HIGH
Turn the dial (with the temperature in degrees on it) to the lowest setting - which is somewhere around 60’ish.
Now turn the unit on and it should stay working.
Three things that could cause it to turn back off ...
You turn the Fan switch back to Auto.
You turn the Heat switch back to High
You turn the temperature selection dial too high ... though, you can cautiously turn the dial up a few degrees at a time ... the unit will start shutting down again when you set the temp too high ... then just dial it back down ... unplug for a couple minutes, then turn back on.
Oct 22, 2008 | Vornado EH1-0014-01 Compact Heater
We have a Bosch fan oven. We had to turn off the electricity and when we switched it back on found that the oven does not work now. The clock is flashing, but I don't think we can set this as I have had...
It is possible that the after turning off the electricity the oven has reset in AUTO (timed cooking ) mode, try setting it back to MANUAL mode and try the oven again
Oct 21, 2008 | Bosch Kitchen Ranges
After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
Sep 12, 2007 | Bosch HBN 455 Stainless Steel Electric...
Bosch DAH9505 30in Traditional Wall Updraft, Stainless Steel, Half-Round Bullnose Style Kitchen Hood Logo
50 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Joseph Hoffmann
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
