Question about Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G
Physically can't plug into front usb ports on new Inspiron 660. port will not accept the plug,
Tried it both ways. tried another memory stick. both go in fine on my old computer. this is crazy.
    Top Expert:
  • Dell Master
  • 2,907 Answers
Some USB 3.0 connectors are very tight plugging in.
I had that problem on my Dell laptop, but i tried another USB input and it was ok.
Hope this helps.
Posted on Jan 31, 2015
    Problem Solver:
  • 8 Answers
I've only ever come across this once before as a technician, and it turned out to be the board, with the ports mounted on, not being set in quite the right place on the inside of the front pannel. I only had to push the board and it located. Hope this helps you.
Posted on Jan 29, 2015
bluegreenash
  • 661 Answers
SOURCE: dell precision not recognising usb 2.0
sounds not,  some of the older systems only have 1.1, Usb 2 is not all that old (about 2-3 years).
you can upgrade to USB2 bu adding a USB2 PCI card to your system, this would give you some ports on the back and it may be possible to link the ports on the front to the new PCI card to upgrade those as well (depending on how they are connected to the mobo)
you can get USB2 cards with a Pin header which would allow for a pin block connection.
Posted on Oct 25, 2007
  • 103 Answers
SOURCE: USB port problem
I would try first of all making sure that all of your drivers are up to date. I am saying this because it is always a good first step, but I am not 100% confident that this will fix it. There are a few updates that are listed as URGENT for your specific computer. The link to your drivers is below. The main one that concerns me is the Intel Chipset Driver located under chipset. This is listed as URGENT and may be a solution to your problem. The chipset is part of the motherboard that can be responsible for controlling your USB ports. If this does not remedy the situation I would contact Dell support for a possible solution.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=PLX_GX620&os=WW1&osl=en&catid=&impid=
Posted on Apr 24, 2008
muttuswami
  • 42 Answers
SOURCE: my usb ports aren't working at all
try reinstalling the chipset drivers from
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=27&impid=-1&servicetag=&SystemID=PLX_GX620&hidos=WW1&hidlang=en
Select the Operating system
The Category as Chipset
Importance should be All
Click on the Intel driver
Download now
File name is R132539.EXE
If this does not work you will be having 2 usb at the back and in the front of the system.IF the back does not work than you need to get a local tech out at your place as it is a problem with the USB controller on the motherboard and that might have to be replced .If it is the front USB (Only if you have them) then there is a cable coming from the USB controller to the fromnt usb ports that cable might have got unplugged for that you need to open the tower.But i would still recommend a local tech.
Posted on May 27, 2008
techniwiz
  • 275 Answers
SOURCE: dell 4600 usb ports not working
do one thing disconnect all the devices connected to the usb and if possible use a ps2 mouse to do the step i am going to tell you or if u can use the keyboard that would be fine ...
go to device manager and uninstall all that is under universal serial bus ... remove everything that says root hub and than restart the system
Posted on Oct 31, 2008
efs_perpends
  • 1996 Answers
SOURCE: usb ports not recognizing devices
You might be drawing too much power from the usb port, if you're not using a powered usb hub.
Unplug all your usb devices. Go to the device manager and uninstall the usb controllers, then reboot your system and they will be reinstalled. connect the usb devices one by one and try to ascertain which is causing the problem. Some powered devices like printers can conflict with devices that require power from the port, and sometimes there are driver conflicts that can be resolved through the use of a hub, or connecting the devices to different ports or in a different sequence. You may also need to update or reinstall drivers for usb devices such as the PCI bridge. Please see this link for more info on troubleshooting usb. And this for possible cause.
For further reading, see here and here.
If you work through that and still have trouble, write back with the results and we'll help you to sort it out.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 19, 2009
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
Computer does not reconize mermory stick
Either the port on the computer is bad or the memory stick is bad.
If you are using a usb port to plug in the memory stick, try another usb port.
Try plugging the memory stick into another computer to see if it works or if it is bad.
Jun 02, 2012 | Verbatim STORE-N-GO (95312) 8 GB Hard...
My del inspiron mini has no cd drive so how do i install new programs
Hi! Welcome to www.fixya.com.
You need to put your program on a flash drive or an external HDD and just plug in the to your usb port so you can install the programs yo like.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 19, 2011 | Dell Inspiron Mini 10 Notebook
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
UBS port won't allow my memory stick to go in is there a lock on it???
Hello !
Be certain you are trying a USB port. It is rectangular in shape. The USB memory stick will only go in one way. Try flipping it over.
If still a problem ...
Either your USB memory stick is bad or your USB port on your notebook is bad.
Try another memory stick or try a different USB port on your notebook - should determine which is OK and which is bad.
Hope this helps.
Oct 28, 2009 | Acer Aspire One A150-1006 Notebook
USB PORTS
does your usb mem stick have any light indicators? if yes , whenever you put you usb stick, does it light? if it lights are USB ports is still ok,  You just have to reformat or partition you USB stick.
(you can also try other devices like usb mouse or any usb devices that lights up when you connect it)
if there are no lights if you plug, or no indication that a power goes to your stick, its possible that your usb your are busted. if this is the case, if your laptop has a PCMIA slot, you can find a pcmia USB card, if you dont have. your only option is replace the  motherboard.
Feb 01, 2009 | Averatec 3200 Notebook
Am I supposed to just put the memory stick in the usb port in the front of my cpu? How long does it take before it's done. This is the first time I've ever purchased this.
Most of these portable memory sticks are all plug and play. This simply means they are ready to be used whenever and wherever. Just plug in the drive to your USB port and drag files into the listed hard drive. Just remember, do not pull this stick out of the USB port without pressing "safely remove hardware" on your start bar. Failure to do this can result in frying your flash memory. Best of luck!
Jan 14, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My computer usb ports are not recognizing my i pod or any other device.it wont accept a new drier.
Some usb ports on the front side of the computer may not function properly. So try to plug the device on back side usb ports. If no success, then check the bios setting to enable USB ports.
Dec 17, 2008 | Acer Computers & Internet
Usb ports not picking up memory stick
Is it just Memory Stick, or everything that you plug into USB?
Try following:
  1. plug in other USB device into ports
  2. if it does not detect any USB device on any port on your computer
  3. if both front and back USB do not work it may be taht USB is turned off in BIOS, or USB driver is corupted
  4. If you have front USBs and they just do not work there is wire connecting them to the motherboard since it may be loose, if connection is OK than they are dead.
  5. If just back USB do not work than they are dead>
Jan 30, 2008 | Computers & Internet
Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G Logo
81 people viewed this question
Alun Cox
