Question about Viper Security and Remote Start System (basic install included)
Vipor 3000 car alarm system problem: car not starting
I can not start car, and battery is fine. My alarm is not on, but the red light inside the car is flashing. I attempt to start the car, but after I do
the lights start flashing as if it sets off the alarm, without the sound.
I use the remote to turn the alarm on or off and the flashing lights stop,
but the red light still flashes. (Which should indicate the alarm is on)
Problem is the alarm is not on, and the doors are not locked.
Any idea how to fix this?
SOURCE: Viper 791 XV Automatic Start Not Working
Viper Working installed in my 2000 Honda Civic. It's the 791 XV model I nite diagram
Posted on Nov 08, 2008
  • 905 Answers
SOURCE: Battery Died, now remote start wont work at all
there is a reset button stuffed under the dash ( drivers side ) , it has two wires from it to the alarm box ( not the switch )
Posted on Jan 28, 2009
  • 43 Answers
SOURCE: won't start my car anymore. everything else works.
Check to see if any fuses are blown on the alarm brain.
Posted on Apr 01, 2009
  • 50 Answers
SOURCE: viper works but remote start and keyless entry does not
On the remote start part, it might be as simple as relearning the tach. To do this, crank the car with the key, press and hold the valet switch until the led lights and stays solid now release.Try the remote start. Need to know what kind of car to comment on doorlocks.
Posted on Jul 06, 2009
  • 69 Answers
SOURCE: remote has red light flashing and beeping?
i have this alarm also.... for starters your batteries are dead, so get those when you get a chance. (best buy or radio shack) for now you can manually over ride your alarm... what you when need to do is get into your car by using the key, and the alarm is going to go off
1. locate your antenna, which is going to have your blue LED and a square push button. usually at the top of your windshield
2. while the alarm is going off, you will need to put the key in the ignition and turn to the on position, ofcourse it isn't going to crank.
3. within 5 sec of turning the key on, you will need to push the valet button( button on the antenna next to the blue LED) 1 time, release, then push it a 2nd time but hold it down until the alarm shuts off, this will allow you to start the car with the key. if it doesn't work the first time, turn the key off and try it again
the default is 1 press, the pushing it one more time and holding, but it can be programmed by whoever installed to be 1-5. hints, pressing it 2X the holding on the 3, or 3X then holding on the 4 ect
Posted on Aug 15, 2009
Avital 3100 keyless entry remote sets off alarm when trying to unlock or lock doors with remote. Doors stay unlocked but alarm keeps sounding off and car wont start.
hi'
i think the wire that connects to the door trigger for the interior light
a negative or a positive one has been mixed up
if its neg change it to the positive one
if its positive change it for the negative one
25666027-extj4arg1t42xbh3l3byl5v2-3-0.jpg the purple or green wire
cheers
Apr 26, 2015 | 3100L 1way Security System
My 2008 Saturn Vue won't crank or start!? We have tried everything to get the Saturn started but nothing working. It's not the starter or the battery. We have lights and everything works just won't crank...
If you have a voltmeter, Connect one end to the hot terminal on your starter. (Making sure that you don't get any body part or anything stuck in any moving parts in your engine compartment!) Turn the key and look at the meter. If it goes up to 12 V or higher, that means that power is getting to the starter, and the problem is either the starter or a bad ground. If the voltage stays at zero, the problem is before the starter and could be your alarm, a relay, a fuse, etc. It would help you to have the wiring diagram for your car.
May 25, 2014 | Cars & Trucks
What do I need to connect on the 5103L and what can I leave unconnected?
I would suggest you connect alarm , the door trigger ( usually green) - to the dome light wire that can be found inside the door. If there is no pin in the door it's inside the door panel by the latch and shows - when door or latch is open. It is also possible to connect to the dome wire in the ceiling but dome light delays will cause a problem or if there is no light. You need to connect the starter wire possibly blue red on this car, two ignition wires on the car colors possibly red and red yellow for the second ignition wire. Brake light wire possibly white black above switch pedal. Battery or constant possibly black yellow at ignition switch. Parking brake is usually required. On this car you will need to add a actuator in the driver side door to unlock and lock the car. Diagram is to use two relays, can be found on websites. Adding actuators to a door. You will need to disarm the alarm with the alarm disarm wire on the alarm the disarm wire on the car is possibly white green it is negative in the driver kick panel.
May 04, 2014 | 5103L Security/Remote Start System
Car starts but doors stay locked and alarm system starts flashing light and honking horn. Next day I was inside car and doors would not open and alarm system went on.
Hi first thing I would replace the battery in the key it might need to reset security system by disconecting the battery .
Dec 15, 2013 | Vehicle Parts & Accessories
Car alarm keeps going off and car wont start
try this: dicinnect battery fir 15 minutes , then reconnect. turn the key to the on position for 15 minutes , then try to start. You may need to reestablish communication in the vehicle.
Jun 12, 2017 | Volkswagen Jetta Cars & Trucks
2000 Toyota Corolla wont start Changed 02 sensor disconnected bat
that red LED is the Alarm, if its solid red, its fine; blinking is about to trigger I think and off means the Alarm is active and opening a door will set it off.
as to why it wont start...not a clue,
check gas, make sure its in park,
you said its turning over but not firing, perhaps its a bad sparkplug or just flooded...
Apr 17, 2009 | 2000 BMW 3 Series
Alarm wont shut off and lights keep flashing
This can be very simple look for alarm brain and unplug the brain, this vehicle should start. if it doesn't the look for valet switch it usually mounted under dash or on kick panel next to hood lever or close to where clutch pedal will be, Turn Ignition ON and in ON position flip switch the led light should stay on steady then the vehicle will start. If None of this works then you will have to take panel under steering column down and disconnect complete alarm system. Disconnect wires one ar a time and re-join them with the correct ones. It's NOT hard to do, there will be spliced into ignition wires.To do this you should disconnect positive lead on battery pole to stop the annoying noise until you are done. Good luck and contact if you need more help. Thanks for using FIX YA
Mar 24, 2009 | Vehicle Parts & Accessories
Security alarm problem
Do you have the key fob? Alot of alarms will go off if you unhook and rehook the battery. All you should have to do is disable the alarm after you unhook the battery. Is this a factory alarm or an aftermarket one?
Mar 07, 2009 | 1993 Chevrolet Camaro
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
171 people viewed this question
Top Viper Home Security Experts
Will Halftowaite
jason
Kevin Daniels
Are you a Viper Home Security Expert? Answer questions, earn points and help others
