Question about Shark SV75 Cordless Pet Perfect Hand Vac
Sv75 SHARK BELT REPLACEMENT - Shark SV75 Cordless Pet Perfect Hand Vac
Shark rotator nv340 roller brush is not spinning
just found this from another fixya member....There are a number of reasons why your brush roll has stopped spinning on your Shark Rotator. Here are a few things to check for when trying to fix your Shark.
First things first lets focus on the brush roll. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roll. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roll to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roll is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. This could be the other reason why your brush roll has stopped spinning. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roll. Lesser tension diminishes the brush rolls turn rate and speed. If the belt feels loose then it certainly is effecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html?limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Dec 09, 2016 | Shark Vacuums
What is belt size for shark rotator model NV341
Hello, this is Ava with Think Crucial.
I don't have the exact size of the NV341 belt for Shark however, you may order the belts for your Shark and other replacement parts directly from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
2 Shark Belts Fit NV350 HV400 NV500 Series
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Oct 07, 2016 | Shark Vacuums
I need a belt for a shark model #v131optn power pet upright bagless vacuum
Mark, Google search for a near by vacuum shop and stop in and get a belt or google search your make and model, Belt. Check the attached links for replacement belt, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.sharkclean.com/parts/0/all/484/replacement-belts-2
Vacuum Cleaner Belts Walmart com
Vacuum Cleaner Belts at Ace Hardware
Jul 14, 2016 | Shark Vacuums
How do I change the belt on a Shark Rocket
Always unplug your vacuum from the power source before performing this. Use a Philips or a crewdriver - to open the screws keeping the roller covered. The screws are located in different places depending on models but they are easy to spot. Hold the roller ending and remove it from the holder. Hold the roller at the end furthest from the belt. When that end is free, repeat with the other roller endings. Slide the belt off the roller and, after that, off the motor shaft. Clean throughout the brush roll with a hairbrush, a pair of scissors and a pair of pliers (if necessary) to get rid of all hair and debris. Be careful or you could cut the bristles. Slide the belt over the motor shaft then over the roller and finally over the seat. Hold the roller at the two ends and separate it from the motor shaft making sure that the tension at the two ends is equal. Partially attach the end furthest from the belt then tightly pull the other end and partially attach it to its holder. When the two ends are in place, push them in. Reassemble the brush roll cover and protect it, using the screws you've just removed. Place the vacuum machine upright, connect it to the electricity outlet and check the roller.
You may order replacement parts for your Shark directly to us. You may visit this link for your Shark replacement parts needs:
http://www.thinkcrucial.com/search?type=product&q=shark
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10.
Ava B.
Feb 11, 2016 | Shark Rocket Self-Propelled Bagless...
Why isnt the beater bar turning on my shark. The belt is intact
More then likely, the belt is just worn out and slipping on the drive shaft. (I've encountered this problem) replace with a new belt.
Mar 04, 2015 | Shark Vacuums
Shark navigator making strange noise. Still have suction, doesn't make noise when beater bar not moving. What could be the problem?
HI, it's Jim from Crucial Vacuum!
If your Shark Navigator vacuum is only making a strange noise when the brush roll is turning then the two things to consider and examine would be the brush roll itself as well as the belt.
First off lets look at the brush roll itself. Right off the bat is there any noticeable debris caught in it? You're mainly looking for long carpet fibers, or even strands of hair? If so try using a scissor to cut the blockage away. Then, manually rotate the brush roll to uncover further clogs. When examining your brush roll take note of the condition of the bristles. Are they loose? If so this would be a good time to change your brush roll entirely. There should be two screws holding the plate onto your Shark Navigator. Use a screw driver to remove these screws to gain access to the brush roll and belt.
The second part to check would be your Shark Navigator's belt. With use the belt will stretch out, lessening the tension on the brush roll. Lesser tension diminishes the brush roller's turn rate and speed. So if your belt feels loose as well replace that. A general rule would be that you're going to want to replace your belt about every 6 months. And if your belt is really loose this could be causing a noise when your brush roll is active.
You can purchase your replacement parts for your Shark Navigator direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=Shark+Navigator&limit=all
Jim Thompson
Crucial Vacuum Customer Care
Nov 26, 2014 | Shark Vacuums
Where can I get Shark NV 352 replacement belt
Try bed bath and beyond or the official shark website
Mar 30, 2013 | Shark Navigator Lift-Away NV350
Shark SV75 Cordless Pet Perfect Hand Vac Logo
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
