Question about RCA R52WM24 52" HDTV Projection Television
Television picture does not work when first turned on
I have a Samsung rear projection TV, not sure what model number or anything, it is about a 42 inch and about 6 years old now. The problem first started several months ago, basically when the TV was turned on, occasionally the picture would be distorted, and the sound would not work, it was noticeable by these red, green and blue curved lines which went across the top of the screen. At first you could just turn it off and back on and it would be fine, but the last month or so I have found that it can a long time before it starts working, sometimes it seems to take over an hour to 'warm-up' or something before it starts working properly, basically it is useless and frustrating and cannot be used. I guess I am just curious about what you might think is wrong with the TV and how much it might cost to get it fixed? Thanks, James
  • 36 Answers
It seems that there are capacitors in the power supply which have dried or leaked, It is vurtually impossible to diagnose sight unseen however, the fact that it effected the three colours I envisage that problem to be associated with the supply, also the curving effect makes me look there, it seems that there is a ripple in the AC. I am assuming that it would take around 1.5hrs and cost of caps. This is working on the assumption that the fault is what I have listed without looking at it. Cost may be around the $150-$250 but don't quote me, I can't see the fault so it is an educated guess only...Phil
Posted on May 18, 2009
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: I have a Samsung rear projection TV, not sure what
Hi. OK, you will have to replace some serious hardware in order to restore this unit. i will post the circuit boards and there respective part numbers below.
Main board---Samsung Part Number: AA94-03388T
Convergence Board---Samsung Part Number: BP95-00415H
Deflection Board---Samsung Part Number: AA95-01846D
Replacing these boards will restore your tv.
Light blinks there is sound but no picture
We have a Samsung DLTV that does this when the bulb needs to be replaced. We have to replace the bulb quite frequently. You can look up the bulb you need online using the model number of your TV. I hope this helps.
Sep 14, 2011 | Samsung HCM4215W 42" Rear Projection...
How do I turn off the on / off melody on the 42 in samsung LCD tv?
Usually melody turn On-Off option is available in Settings menu of tv, let me know model number of your tv to provide you more detailed info about how to turn Off melody sound on start up and shut down.
Thanks.
Nov 07, 2010 | Samsung HCN4226W 42" Rear Projection...
MY TV HAS NO POWER I CHECKED THE FUSE IT SEEMS
hello have you checked the glass fuse inside the tv it will be in the power supply beware if replace the and blows again the you have a dead short circuit
regards
shaun
Apr 09, 2010 | Samsung HCN4226W 42" Rear Projection...
My lamp light on my 42" rear projection.
you need to replace the lamp you will need to know the model# you can find it on the back of the tv
Jan 26, 2010 | Hitachi 43UWX10B 43" Rear Projection...
My tv sumsung hcn4226w 42 inch rear projection will not turn on
either the lamp is burned out or the ballast and power supply board need to be replaced. can call 1-800-samsung for nearest service center.
Dec 11, 2009 | Samsung HCN4226W 42" Rear Projection...
I have a Samsung rear projection TV, not sure what model number or anything, it is about a 42 inch and about 6 years old now. The problem first started several months ago, basically when the TV was turned...
sounds like the convergence chip. i think you can get a kit from tvrepairkits.com not sure how much it would be to have fixed. But if your good with a soldering iron i think their kits come with instructions as well.
May 18, 2009 | Samsung HCL4715W 47" Rear Projection...
Wheres the model number samsung 42" rear projection tv
The model number should be on the inside of the back cover. Usually is but if not, check the frame or system board. First check back cover
Apr 30, 2009 | Samsung HCM422W 42" Rear Projection...
Studioseries (samsung) 42" rear projection tv red duoble outline of picture
sounds like the red convergence Ic is weak ready to go out. try replacing the ICs around 10.00 do the blue as well as that will be next.
Mar 18, 2008 | Samsung HCM4216W 42" Rear Projection...
Samsung sp47Q5 rear projection
when you turn on the tv you should get that static feeling when you toch the srcreen. if not then there is no high voltage
Dec 27, 2007 | Samsung HCM4216W 42" Rear Projection...
RCA R52WM24 52" HDTV Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
