Question about Worldtech Devices Toys
My fxd helicopter wont work and i just bought it
RAGING MONSTER FAST SPEED HELICOPTER 3.5CH BUILT IN GYRO
  • 23 Answers
SOURCE: my helicopter wont fly
either stripped the main gear inside the heli or the main blades where they slide on the shaft. you should be able to buy a replacement set of blades. try that and see if it'll fly.
Posted on Apr 04, 2010
SOURCE: i have just bought a kds 450 sv helicopter and
Me too i just boight one with the flymentor built in and same it just been and nothing happens, ive tried everything re binding but the binding been not to be working either it says to connect the jumer to the bind pins and it will flash red but it doesent?
Any help would be great same as the guy above...
Thanks in Advanceds....its just a nice awniment at the moment....
Posted on Sep 10, 2010
  • 3 Answers
SOURCE: i just got an r/c helicopter ( gyro s032 ) i've
couple of things possible. 1) change outlet. 2) call customer service for the helicopter (should be on manual in contact section) 3) the helicopter has a loose cable connected to the battery inside the helicopter so you probably need to sodder it.
Posted on Dec 26, 2010
  • 76 Answers
SOURCE: do you have a manual
u can get it from internet
Posted on Dec 27, 2010
SOURCE: How to change channel/band for
1. Switch the controller to the desired channel. 2. Turn on the helicopter you want to control. 3. Move the joystick forward and back until the rotors start spinning.
Posted on Aug 28, 2011
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
Repair, parts and instruction manual
search Google for remote controlled toys and see what is out there .
Oct 08, 2015 | RC Toys
Helicopter swerves right at speed
Hang it from a sting attached to the rotor shaft and see if it hangs level. It sounds to me like it is off balance.
Mar 07, 2014 | WL Toys WL V912 MAX 4CH FP RC Helicopter...
Helicopter not stable
Hi, I had a toilet bowl effect after changing the blades on my s107g. After making sure the shaft was seated properly, I simply adjusted the tension on the screws holding the blades in position and after a bit of trial and error tightening and loosening: it's as good as new!
Jan 21, 2013 | SYMA Toys industrial New Syma S107 Radio...
How could i use my iphone 4g to control my toy helicopter
Instructions
    • 1 Remove the main rotor blades, throttle up the helicopter while holding it in your hand and twist the helicopter from side to side to determine if the gyro is working. The gyro should make the tail rotor spin faster when the helicopter twists; you will be able to hear a difference. If the gyro does not appear to be working, replace it. Some gyros have a sensitivity adjustment screw; try making small adjustments if possible.
    • 2 Check the tail rotors and see if they are connected correctly. If the tail rotor blades are not pitched correctly they will not be able to hold the helicopter still.
    • 3 Test the tail rotor motor and see if it seems strong and responsive. Brushed motors, like those commonly used to drive tail rotors, can wear out in a relatively short time. Replacing the motor may solve your problem if the gyro seems to be working.
    • 4 Check the trim on your transmitter. Ideally the trim should be in the center of the stick movement. You may need to dial in some extra right trim or you may find the trim is set too far to the left.
Jan 20, 2013 | Toys
I just got an r/c helicopter ( gyro s032 ) i've just tried it once but then i tried charging it for second run, but when i plugged the charger cable in the helicopter. It din't want to charge,i looked,and...
Dec 26, 2010 | SYMA Toys industrial Syma S032 Ready to...
Hey I recently just bought the SO32 helicopter and am having trouble getting it to work. The helicopter is charged and the lights on it are flashing, but when I turn the remote on, the power light is...
The problem is the battery, I just got one for Christmas and overcharged the battery. I put a new one in and it works. The manual says never charge over 90 minutes.
Dec 25, 2010 | SYMA Toys industrial Syma S032 Ready to...
Hi my brother got a little helicopter and ind wont turn on or move
the batteries are most likely are in backwards or one is in wrong
Nov 21, 2010 | Worldtech Devices GYRO AirX 35CH Tilt...
Crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
Try setting gain on Gyro (use small plastic screwdriver) to a straight up and down position.
Set Gyro setting in Transmitter to 75%. NOTE: before turning on helicopter, be sure to center all adjustments on transmitter
Side switch on GYRO to DS and make sure the servo is moving in correct direction. If not. reverse direction with switch on side of Gyro. You may need to reverse the controller of Rudder in settings on transmitter.
This worked for me on my Blade and using the same Gyro on a self build 450 heli.
Helimangler
Apr 20, 2009 | E-Flite Blade 400 3D RTF Electric Mini...
Helico
Gyro is oriented, flip it over, or turn it 180, see if this solves the issue
Jan 23, 2009 | GWS Pg-03 Micro Piezo Gyro Pg03 Heli...
Toys Logo
107 people viewed this question
Top Worldtech Devices Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Worldtech Devices Toy Expert? Answer questions, earn points and help others
