Question about Refrigerators
Cata fridge freezer manual
Temperature
5 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
shastalaker7
  • 1515 Answers
SOURCE: fridge and freezer display shows ON and not
Hi, if the display is supposed to show the temperature of the fridge/freezer on the display then what appears to have happened is that the remote temperature bulb has come out of place. If you can get to it you may be able to put it back in place. You will have to start at the display and will see the temp. cable and follow it back to see where the bulb is now resting. If it is not exposed for you to be able to excess it, I would call asap from where you bought it as it is new and tell them about this condition! Keep me updated on this please.
Sincerely,
Shastalaker7
PS It would not be the compressors unless the unit is not cooling at all then you could have a serious problem.
Posted on Jan 17, 2010
heatman101
  • 43501 Answers
SOURCE: the temperature has been really
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Jul 20, 2011
imufo2
  • 3773 Answers
SOURCE: my Kenmore Elite trio Fridge/Freezer
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 27, 2011
Kenmore appliances manuals
All cooling is done in the freezer. Refrigerator side gets air from the freezer. Controls are usually in the refrigerator compartment, upper front or center back
Aug 18, 2014 | Refrigerators
Is there a video which will show me how to fit a CATA fridge freezer into a cabinet?
As any integrated cabinet, you have to measure the dimension of the Freezer and create a space a little wider say 1/2 inch on each side and on top to make sure you can slide it in
http://www.thegascompany.ie/iopen24/images/content_images/hotpoint_built_in_ovens/hotpoint_60_int_dishwasher_drawing.JPG
After you can nail down moldng around it
Do not forget to install an electric outlet to plug it in ;)
Jun 05, 2014 | Refrigerators
Fridge temperature too warm
As you know this is very large fridge and try to find service manual for help and solve problem with using deduction method of step by step trouble shooting and eliminate possibilities
This might be compressor problem or evaporator problem or main controller problem or sensors or etc.
Baumatic TITAN 5 Stainless steel 4 door 607 Litre Frost Free Fridge/Freezer
Technical Details :
* Total gross/net capacity: 607/557 litres
* Gross capacity fridge/freezer: 428/179 litres
* Net capacity fridge/freezer: 397/160 litres
* Energy efficiency class:
Dec 06, 2013 | Refrigerators
Fridge not getting cold...but freezer is working
the fridge gets its cold air from the freezer fan blowing it through small air passages between the freezer and fridge. when you adjust the temperature in the fridge you are increasing/decreasing the amount of air being let into the fridge. Two common problems that could cause the freezer to freeze but not the fridge getting cool is the freezer coil is frooze like a ice cube blocking the air going to the fridge or freezer fan is not working could be bad or froze up due to too much ice. If fan works after manually defrosting problem could be in the auto defrost mechanism. If fan don't work after manual defrost replace fan. Manual defrost by putting a pot of very hot water in freezer with door closed change water foten until defrosted.
Jan 02, 2012 | Westinghouse Avalon Refrigerators
Do you have instruction manuals? I have a 6WRI24NG and it seems to be dripping water from under the freezer bit into the fridge, and everything in the fridge are is freezing.
The problem seems to be with the condenser. the freezer is leaking because of the breakage of temperature between freezer and the fridge. I will update you soon.
I have not found an online manual yet for free. But we could find the free manual from the company's website.
Jun 27, 2011 | Whirlpool Refrigerators
We did not receive a manual with our fridge and need to know what temperatures to set it at. It is a two door fridge with a bottom drawer freezer and digital settings. Can you helps? Also do you know how...
If you set both in the middle settings thats generally best. 1 is the on/off and compressor control to run the box temperature, the remaining will say colder /warmer, this can be misleading however as colder actually is colder freezer! not reefer box! so to max that one actually makes the reefer warmer and freezer colder!
Jan 12, 2011 | LG Refrigerators
Fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Belling fridge/freezer controls
most likely that is an on off switch for the temperature alarm. the 1 or l is the on psosition and the O is the off postition..
Nov 16, 2007 | Freezers
Refrigerators Logo
202 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
