Aiwa ad 450 - Audio Players & Recorders
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
Aiwa instruction manuals
I suggest you contact Aiwa themselves. Some makers have free downloads of PDF files of them. But if they don't they should be able to send you a copy, perhaps for a small fee.
Apr 01, 2014 | Televison & Video
Aiwa AD-1250 When a cassette tape is inserted the spools do not turn; there is a whirring noise when ''forward'' button is pressed. Is it possible for me to repair this fault by opening up the machine ?
You need to replace the belts from the motor. From memory I think there are two. You will probably find that all the rubber parts need to be replaced, including the pinch roller.
Nov 04, 2010 | Aiwa Audio Players & Recorders
Can you still get the px-e860 turntable? The one I have won't make any sound thru the speakers
Judging by my own experiences with hifi gear on eBay there is little on the face of the planet that ever really becomes UNavailable.
Wouldn't an attempt to resolve the issue work, too?
Describe your setup (preamp, amp, whatever) and if it has ever or never worked.
This unit can work through its own preamp with any audio equipment or with old-school gear already having an internal Phono Preamp. There's a switch to select which one.
Apr 08, 2010 | Aiwa PX-E860 Turntable
Rubber drive belts wanted for Aiwa AD-F810 cassette tape recorder
my aiwa brand cassete recorder model : TP-VS485 drive belt is broken, how replaced and where I can find spare parts
Nov 02, 2008 | Audio Players & Recorders
Aiwa cassette deck won't eject
I had this problem on an AD-S40. Turned out to be the drive belts, which had stretched, resulting in the fact that the motors couldn't drive the mechanism through it's various load cycles of opening/closing the captain roller, etc. as required to operate the mechanism. Stuck in mid-cycle, the doors would not open.
After removing the case cover, you can turn the belt driven wheels by hand to complete the cycle, so that you can eject. Then get new belts (several outfits sell belts based on length, on line). You don't need to do much to replace the belts -- after unlocking and getting the tape out, it was only a couple of screws to remove the mechanism, as a unit, and there is no need to fuse with the circuit boards and such. Easier than I expected.
Apr 20, 2008 | Audio Players & Recorders
32 people viewed this question
 Grubhead
Grubhead
