Question about LG Audio Players & Recorders
Keymat dvd player - LG Audio Players & Recorders
Where to purchase a nokia 6015i keymat
Go to a nearest Nokia Care Centre or it can be available from a vendor
Dec 20, 2011 | Nokia 6015i
Auto key pad working
wash pcb with petrol and check again if doesnt work properly resold keypad ic with resolder paste because i hope pcb has some water or any liquid form under the keypad ic and remove keymat and clean keymat area on pcb if doesnt work yet resold upp carefully Note; cover up sim card connector and glued ic`s when you resold cpu
Jul 12, 2010 | Nokia 1110 Cellular Phone
Does cyberhome ch-dvd 300 dvd player play burned mp4 movies?
the answer is "No". Your player cannot play MP4 DVD discs.
Take care.
Jun 18, 2010 | Cyberhome CH-DVD 300 DVD Player
My k1 is in great condition but is missing 1/4'' center menu button and I would like to replace it. can anyone help me!!
That button is part of the keymat assembly, so the only real option is to change the whole thing - it's easy to do, though - just remove the battery, memory card and SIM card, take out the 4 torx screws, remove the rear panel, unplug the display flex cable, then remove the main PCB and the keymat.
It should only take about 5 minutes.
Jul 05, 2009 | Motorola Mobility KRZR K1 Cellular Phone
Sub Keymat
you need to take the phone to a mobile service center and have the sub pad replaced.
Apr 10, 2008 | Samsung SGH-d807 Cellular Phone
Flex connector
remove back cover and battery
you can remove ur front panel by using ur nail it self
u can find white keymat that willbe fixed with flexi , remove it
then remove lcd carefully
unscrew the the four screws in the back panel
then seperate D cover from front panel you can find flex conn
give some little care while removing flexi cable for its position .
plz follow the reci for assembly
Nov 04, 2007 | Nokia 6288 Cellular Phone
20 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
