Bosch varioperfect - WAQ243D0GB error code e61 e:61 what does it mean please? The door will no longer unlock and every programme I select gives me the beeping and the e61 error code.
SOURCE: annoying beep when wash cycle finishes on bosch classixx 1400 express
Starting with the rotary switch in the off position, turn it one click clockwise, press and hold on the bottom right hand button, turn the rotary switch one more click CW and release the button. The number displayed is the volume for button presses, press the centre right hand button to increase/turn off (0). Turn the rotary switch one more click CW to select end of cycle volume, agjust and set the rotary switch to off to leave set up mode.
Posted on Sep 12, 2009
  • 414 Answers
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Posted on Jul 12, 2010
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
SOURCE: Bosch Maxx7 Varioperfect Manual in English
simbolo llave que debo hacer
Posted on Nov 26, 2010
  • 414 Answers
SOURCE: washing machine bosch maxx 7 varioperfect
Sounds like have inadvertently activated the child lock. To deselect you need to press and hold the start button for approx 5 secs or until the key light goes out. Hope this helps, please let me know if this works or if you need further assistance.l
Posted on Nov 23, 2011
I have a bosch varioperfect washing machine, the door stays locked after a cycle and the display shows - - just two dashes. I can only get the lock to unlock after moving the dial from prog to prog
this is an ntc fault the temp reading is out of calibration it keeps the door locked to avoid burns from scalding hot water it is fitted inside the wash heater.
Sep 25, 2016 | Bosch Washing Machines
How do your error E17 on a Bosch Maxx 7 varioperfect.
Hi Kerry, The same question was asked on this site back in March 2009 !! and the link below has an answer..... CHEERS..
E17 error code Fixya
Apr 04, 2016 | Bosch Washing Machines
What does E18 fault code mean on a Bosch exxcel 8 washing machine mean?
Drain error detected
Check drain pump filter
Check drain pump for blockage or restriction
Check outlet hose for blockage or obstruction
Check drain pump operation
Check drain pump wiring
Sep 09, 2014 | Bosch Washing Machines
A bosch varioperfect error code E29
E29 indicates a fill error. If the door is locking then check water feed. Make sure water is on and hose isn't kinked.
Jul 22, 2014 | Bosch Washing Machines
Bosch excell 7 varioperfect washing machine will not programme, the key flashes on the display
Dont worry your machine is ok
the flashing key means your child lock is on, and has to be disengaged
What you need to do is press and hold the on/off button for approx 5 seconds This should turn the lock off.
I hope this was useful.
Oct 20, 2012 | Bosch Washing Machines
How do you remove the unlock on Exxcel 7 VarioPerfect washing machine?
Aug 13, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
Error code F16
F16 on a Bosch indicates the door is open / unlocked.
If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board.
The wash programme should halt when this comes up but you should be able to restart it when the door is closed.
As the cost of a new door interlock isn't overly expensive I would suggest fitting a new lock on a "fit and see what happens" basis.
Aug 10, 2009 | Bosch Washing Machines
Washing Machines Logo
1,564 people viewed this question
Top Washing Machines Experts
