Question about Canon NP 6050 Copier
Solution E031 NP6050 - Canon NP 6050 Copier
Aurora troubleshooting
why does my 2001 olds aurora make a buzzing noise when I try to start it
Jan 14, 2014 | Cars & Trucks
I want to get some help about canon np6050 error
Hello jig,
I wish to help you quickly as you are down. I dont have immediate access to the older analog service manual and Canon no longer keeps it on their website.However, E005 has been a common error code for many products, if not all. It means that the cleaning web (which is an item that is "used/consumed "normally as the copier is used.) has run out.The copier should have been diplaying (in small letters on the dispay) "WEB LOW" for quite a while.It needs a new cleaning web.An untrained end user could change this but without instruction most people would not be able to. Its located in the fuser area onder a yellow cover. I bet you can do it !
Apr 09, 2010 | Canon NP 6050 Copier
NP6050 Codigo E400
E400RDF to copier communication problem
Recommend to apply to service.
Nov 02, 2009 | Canon NP 6050 Copier
NP6050 false paper jam at doc feeder
When you put documents in the feeder and you push start do you see 2 black arms swing out to count the number of orignals? If yes, dose the doc tray begin to go down and then jams? If yes, you can try something.... OK, turn the copier off and move the 2 paper guides of the doc tray toward the middle. You need a #2 philip's head screw driver. Remove the 2 silver screws that will be sunk in a bit on the top of the doc tray. Once you remove the screws, remove the top part of the doc tray and you will have one connector toward the front. Unplug it and replug it back in and see if that works, if so return the 2 screws and you should be OK.
Dec 12, 2008 | Canon NP 6050 Copier
Canon copier ir600 problem
Try to reset the machine and use it
Nov 02, 2008 | Canon MF8180C Color Laser MFC Printer
Purging the memory
Hello Jim.I would like to help you but I am not quite sure I understand your need. The Canon NP6050 is an analog device that cannot be networked. And it does not have a hard drive that might retain any information from previous copy jobs. This device does have a small amount of memory to retain custom copy settings, user codes, timers etc, but really no ability to retain and store documents in the manner I believe you are concerned about.So the need to "purge" this device (if I understand your concern) does not apply. I hope this helps, but if I missed your point or can be of further assistance I will do so gladly.
Nov 09, 2007 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
old marine
old marine
