Question about Canon PowerShot A570 IS Digital Camera
Lens control The lens doesn't work, can i fix it
Lens doesn't work
Try removing the battery and memory card for at least 15 minutes. With some cameras, this will reset the camera and lens may clear the error message, as long as there is something that is not physically damaged the camera.
Jan 20, 2013 | Kodak Easyshare C195 14 Mega Pixels...
Some dash lights on my 01 ranger don't work.the bulbs are good
Get an Auto Electrician to trace and fix the problem. There are partial contacts in the wiring system.
Dec 29, 2012 | Ford F-250 Cars & Trucks
Lense doesn't retract
Common faults for this:
The lens motor is defective, lens gears jammed. Fix is lens unit replacement.
The lens servo drive circuit is not functioning. Fix is to replace the circuit board that contains the lens servo control circuits.
The connector assembly between the lens is not making proper contact, or the lens wire assembly is defective. Fix is replacement of the cable and connectors if applicable in the particular model. If the connectors on the circuit board or lens are defective, then the appropriate unit must be replaced.
No power is going to the lens unit, and or the lens servo circuit. Fix is replacement of the drive circuit board, or the power inverter if it uses a separate feed for the lens only.
Generally, with these low cost cameras they generally do not pay to service out of warranty. The service cost can approach the cost of replacing the camera.
Common causes of failures in these cameras is from water (getting wet), or dropping, or rough usage.
Jerry G.
Jun 29, 2012 | Sanyo vpc-s1415 - Vpc-s1415 14.0...
My dvd/cd-rom acer aspire6930g not work, what i heav to do?
Get a laser lens cleaning kit and clean the CD/DVD drive's laser lens. If that doesn't fix it then it's probably dead and you will have to replace it.
Jun 19, 2012 | Acer Aspire 6930 6930g 6930z 6930zg Laptop...
I have a nikon mount AF 70-300 quantaray lens that I am trying to find a mount so that it can fit onto my sony alpha DSLR camera. Does this exist? Will a simple T mount fix my problem?
A simple T mount adapter will NOT work, since your lens doesn't have a T-mount.
If your lens has an aperture ring then something like this will work.
You'll see more information here.
May 23, 2012 | Sony Cameras
Canon 70-300 is usm
I think your lens has suffered significant damage when it was dropped. It needs the attention of a qualified Canon technician.
Nov 15, 2011 | Canon Cameras
Some how my Samsung SL820 digital camera's shutter door got stuck and it is not closing how many ever times I try to switch the camera off and on. Because of this the camera doesn't work. I've...
Did you happen to drop it accidentally? Or accidentally applied force into your camera? If yes, then there is big chance you will gonna have to replace the whole lens! If not, then it might just be dirt stuck inside your lens mechanism. To fix it, hold your camera with the lens facing the ground. Then, tap your camera repeatedly. Start with light tapping to moderate. If that doesn't work, spray condensed air directly into the lens part of your camera.
Sep 21, 2011 | Samsung SL820 Digital Camera
My Modern Warfare 2 Doesn't work... How can I fix it without sending it off?
When you say 'It doesn't work,' How far do you get? e.g. Does the game load at all? What condition is the disk in? Is it scratched? Have you tried a lens cleaner disc for your PS3?
Hope this helps,
Best Regards,
L J
Aug 23, 2011 | Video Game Consoles & Games
Olympus Mju 400 error code d: 1E12
the lens is with problems and needs to be changed. doesn´t happen when u connect to computer, because when is connected the lens doesn´t move.
Jan 21, 2007 | Olympus MJU 400 Digital Camera
Canon PowerShot A570 IS Digital Camera Logo
16 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
