Question about Sirius Audio Players & Recorders
Just bought a XM onyx wont play all displays good installed out of Truck and installed in house base same shows its onthe station and a good strong signal but no sound?
SOURCE: Stations dropped
go to refresh.xmradio.com and insert your radio ID and click submit. It will resend the activation signal and should unlock your channels within 15-20 minutes.
Posted on Sep 04, 2008
sTatiC00000L
  • 8 Answers
SOURCE: xm radio installation in house
hi there..this will be like a walk in a park...first, in your home kit you should be having the ff: antenna, rca cable(audio cables), power adapter & docking station. We just have to 'placed the radio into the docking station' then we just have to plug in the ff cables into the xm receiver..we can start plugging in the rca cable(one ended connector) into the ' audio out ' of your xm radio...the other ends of the rca cables should be plug in into the 'audio in'(at the back/infront of your sound system)...plug in the antenna in the 'antenna out' of your xm( the antenna should be placed into a south facing window and not being block by tall trees and buildings outside)....plug in the power source and turn on the radio....if you got it right you should now be getting the prev.channels/emergency allerts...u can call xm to send a refresh for you to get the complete channels..or you can do it online by logging into www.refresh.xmradio.com(if the radio was already activated) if not, you have to call xm radio to activate it..enjoy listening to xm..Godbless..
Posted on Sep 08, 2008
LVT7857
  • 116 Answers
SOURCE: Static sound or no sound with FM Trans and with Audio Plug
I agree with you. It sounds like an internal audio circuit problem, especially if the tape adapter does the same thing. Have you tries headphones on the unit? If they work, then get the sure connect as it plugs into the headphone jack (Aux out jack)
By the way, you as an XM customer for years, usually XM will just give you another unit to keep you as a customer. I've seen it many times. Couldn't hurt to ask!
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
TOLhamRadio
  • 509 Answers
SOURCE: no signal problem on xm home satilite docking staion
You have probably lost a local repeater. Try moving it temporarily to a south-facing window. Here's another one to try: Put in dock and turn off with button on unit. wait 10 seconds, now press "2" "0" "7" "XM" buttons one at a time in that order ON THE FRONT of your SkyFi2 and the radio will go ON by itself! Now, press "Display" 4 times. You will see a screen that says "SAT1", "SAT2" and "TERR". You need a constant checkmark for DEMOD on at least one of the 3 boxes. Please tell me which ones are checkmarked and the average "BER%" number is. The lower the BER% number, the better. If BERis 100%, you are out of luck. Write back and let me know what you read. Press "Display" 5 more times to go back to regular screen. Thanks,
John
Posted on Aug 21, 2009
  • 3 Answers
SOURCE: Pioneer xm radio suddenly stopped playing
I have same problem and sure connect did not help.
The unit works fine otherwise except will not send a signal to my car radio.
I will try removing the battery today & if this does not work I will do t paper clip reset in the battery compartment.
Posted on Dec 01, 2009
Cannot power up xm onyx radio in docking station; will turn on when not in docking station..what's wrong?
I had the same problem, Bought a new Onyx and tried the supplied 12v power cable on existing Onyx and it worked, So it appears to be the power cable, Hoping now I can find a new power cable,
Dec 30, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Xm radio
Looks like my company is going to purchase a new fm radio for the company truck, I should be able to plug the xm radio into it.
Jun 03, 2009 | Delphi SKYFi XM Radio Receiver
Poor cound quality
does the XM use a radio station for recieving the sound or is it wired in to the vehicle. if you have to set a radio station so you can use the XM then what you can do it set the station to some other channel. it maybe to close to a real radio station or the frequency it to weak and you'll need a stronger signal
May 27, 2009 | Car Audio & Video
XM Roady is non functional
turn ignition on and disconnect your car battery then leave it on until its done loading if it still there then call xm and have then send an update good luck....
Dec 30, 2008 | XM Radio Dual XMP7000 Auto In-Dash CD...
Skifi xm
click on the display button until it shows the channel name
Aug 19, 2008 | Delphi SKYFi3 XM Radio Receiver
Set frequancy
Mount your Roady 2 in your Truck .Make sure the power is on & the antenna is connected. The middle connection should be open. Push the menu button, you should see FM Frequency at the top.Push the scroll button(Top Right) and you should see FM station numbers. Scroll though the stations and pick a frequency that isnt being used in your area. Push the scroll button in to set the station. The display will show that number set 88.3 set for example. Set the FM Tuner in your truck to the same station. You should be go to go. Good Luck
Dec 18, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Top Sirius Audio Players & Recorders Experts
Steve
Oloyede Monsuru
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
