Dryers
Problem for Dryers
Generic problem for all Dryers
Drier problems
By weghse on Oct 17, 2007
Went to use it and nothing. It's plugged in knopw light ,timer ticking nothing. Is there a fuse or a reset bottom I'm not seeing?  HELP!!       Rick
Same Problem
Mar 08, 2009
-   Our dryer was drying and then when we went in to start it again it wouldn't start. The door is shutting tight. We don't know what else to check? -   jacquelimurr
Feb 19, 2009
-   I have the same problem. Amana Heavy Duty NED5400TQ front loader. Door is closed, but when hit start, nothing. Is pluged in, circuit braker good, but you can see the light in the dryer, shinning from the back of the dryer. And when pressing the start button, it sounds and feels normal like before. Please help, thank you. -   sfetters
Jan 12, 2009
-   I went to use my GE DRSR483GD2WW dryer today and it will buzz and sound like a bad starter. It buzzes but does not ignite and tumble. Does anyone have any clues? My wife and I both swear we didn't use it last but I did go down this morning and it sounded like an electrical humming coming from the dryer and I thought it was the buzzer and it was running. I turned the buzzer off and went back upstairs. Then tonight went to use it and got this problem. -   Dan18063
Jan 07, 2009
-   my driyer is getting power cause the light turns on but it doesnt want to start heating-   Guest
Dec 06, 2008
-   replaced push start. timer is ticking, belt ok. won't do anything else. what else can I check?-   Guest
Best Solution
posted on Oct 17, 2007
Helpful)
Jimster
Rank: Guru
Rating: 90%, 288 votes
I dont know what brand it is, so will generalize this if I can.  If you have no start condition, it could be a number of things.  First, be sure door is closed, and door switch is good.  Check wires going to switch as well to be sure they havent fallen off.  There are a number of fuses depending on the type and make of the unit.  Whirlpool (Kenmore, Roper, Inglis, etc) use 2 fuses, one on the element and one in the blower housing.  GE uses usually 1 thermofuse, top right corner (again, depending on make and model), and Maytags use one usually mounted around the element area.  If you can get me some more information, I can narrow it down a little.   Jim
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Dryers
Questions and Unsolved Problems for Dryers
Answer
dryer will not heat and heating element is good.
Answer
how about a 100% dryer and tell me about the advs and disadvs
Answer
i have a zanussi tc7102w condenser drier ,drum not turning , removed lid found large belt broken,... (More)
Answer
I Have rented a flat in Holland with a Zanussi Condenser Dryer model TCE7114 and I need English... (More)
Answer
my gas dryer wiil light but will go out and will run rest of cycle with no heat
7 Other Users Have The Same Problem - Continued
Comment by miketwolf, posted on Oct 31, 2008
I have a similar problem. I have a Whirlpool Ultimate Care ii electric dryer. The light is on inside, but when we press start. Nothing happens. Any suggestions? Do you think it is one of the fuses? I have tried checking it with a mutlimeter, but I am not sure I know how to check it.
Comment by Guest, posted on Oct 18, 2008
No power but plugged in
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dryers:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
