Question about GE Microwave Ovens
Ge microwave ceramic element
GE Profile Advantium 120 Convection m sca1000hbb 04 The ceramic heating elements are not working for the speedcook setting. The lower ceramic heater works on the oven setting but not on the speedcook setting. We checked the fuses and TCOs. There is power being sent to the ceramic heater from the relay and the ceramic element resistance is 22.4 ohms. All other elements seem to be working. Any ideas what to check?
  • GE Master
  • 9,047 Answers
The service manual is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You can download GE owner's manuals and installation instructions here.
Posted on Dec 28, 2013
3 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Hello, I have a 7 year old GE Advantium oven that
I would first suspect the primary interlock (top door switch) or maybe that switch's mount is loose or broken.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
We have the service manual and have uploaded it here to help you.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Aug 20, 2010
  • 1196 Answers
SOURCE: My parents' GE Profile Advantium
Have you tried to reset it, if no, try this, Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock. This should help fix the problem.
Posted on Apr 30, 2011
GE Profile Advantium SCB2001FSS02 halogen heat won't turn off. All switched and digital panel working fine.
On an oven in the model SCB2001F series, when any of the Speedcook elements stay on when they should be off, there is a shorted relay and/or triac on the relay board.
I can repair your relay board, usually for $69.95, which includes insured return shipping. See my link below to e-mail me for full information or other free help.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 17, 2017 | GE Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Hello, I have a 7 year old GE Advantium oven that the microwave has quit working on. The power and timer come on but the actually cooking element of the microwave is not working. When testing the oven...
Aug 19, 2010 | GE Advantium 120 Convection/Microwave Oven
GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
Need to replace fuse in GE Profile advantium oven
remove outer shell/cover, the fuse will be in a fuse holder about 1" long X 1/8" in diameter and is called a ceramic fuse,take it out,look on ends for current rating go to hardware store they have repl fuses, if the new fuse blows it could be your h.v. diode, capacitor, or the magnetron tube
I have a GE profile advantium 120 . The panel lights up I do not get an error code the timer works but it does not heat up. what could cause this
Check your power setting, making sure that you are cooking at 100%. Adjust if necessary.
It could also be a bad magnetron.
Regards, --W/D--
Jul 05, 2009 | GE Advantium 120 Convection/Microwave Oven
The door handle on my GE Profile ADvantium 120 Microwave is broke
appliancepartspros.com. part number AP3187809 $56.40 plus shipping
Apr 27, 2009 | GE Advantium SCA1001SS Convection /...
Microwave Ovens Logo
91 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
