Question about Protocol Manta 4-Channel Radio-Controlled Quad-Copter
Will not throttle up
Charged until usb connector went out,synced ok throttle control beeped to confirm sync.the light on the mantas blinks slow.
Manta quadcopter won't recognize the remote
Turn on the remote controller first then heli the instructions are wrong
Dec 24, 2013 | Protocol Manta 4-Channel Radio-Controlled...
The brookstone stunt copter and remote donot sync
It would not sync. solution was to assume poor technical writing. step zero. turn the controller off. step one. plug in the battery to the copter. step two. QUICKLY turn the controller on. if you miss this small window of time, it is going to fail. The copter light blinks fast during this period, and if it slows the blink rate, then you have waited too long.
Dec 13, 2012 | Shuttle 9094 Emax Remote Control...
My xbox controller is fully charged and it wont connect to the xbox. If switched the batteries and everything. The lights just keep blinking, slow then fast.
Next to the button that you use to remove the batteries there is a button that you must hold to sync it to the xbox. You have to also hold the sync button on the xbox which is near the usb ports in the front or if you have a older xbox near the memory slot b slot.
Sep 29, 2012 | Microsoft Xbox 360 Controller
My xbox 360 will not sync with any controllers besides the one controller I've already had synced. I haven't had any problems with it until recently, and now it seems like the xbox won't...
If you have an xbox slim model then there is a button above the USB slots at the bottom. Press Start and Back on the controller until the center button lights up. Then press the button above the two USB solts and hold it for a couple secs.
If you have n old xbox there should be a simliar button some where.
Also if you bought one of the charging packs for the controller, use the cord that came with it.
Thank you for your time, Good luck and I hope it works.
Jun 05, 2011 | Microsoft Xbox 360 Console
I did exactly what the instructions said to do with the controller, I turned on the PS3, then plugged in the controller, turned it on, then puched the sync button, then plugged in the 2.4 wireless stick...
If the wireless remote has a USB plug, the remote has to be temporarily connected to the PS3 to physically sync. Once that is accomplished, the remote will always work.
Jan 11, 2011 | Intec PlayStation 3 Infinite Play Wireless...
My friend gave me a ps3 controller...so now i dont know how to sync it...i have it fully charged and i plugged it in the usb but all that happens is 4 blinking lights...i can't get it to sync...Help...
press the button on the back with a pin plug it in using usb cable switch ps3 on then when the ps3 controller buttons blink press the ps button on the controller then unplug usb.
Dec 14, 2010 | Sony Wireless Controller for PS3
YT-9014A1 will not sync
i just sync both of mine to my ps3 it was giving me difficult at first, but i noticed the when u first put in ur usb wireless thing it starts to blink really fast and when u push the p3 button on the controller twice it flashes really fast. so i took out the wireless usb thing then put it back in so the light on it would be flashing really fast like it was searching for somthing, then press the p3 button twice to make the lights flash really fast aswell so it will sync with it. Thats how i got both of my controllers synced we my ps3. the lights on on the wireless usb thing and the controller lights must be flashing fast at the same time to sync.
Mar 06, 2010 | Sony Wireless Controller for PS3
4 RED LIGHTS BLINKING ON JOYSTICK,BUT NOT WORKING
If the Joystick batteries are fully charged, and the playstation is active, pressing the playstation button on the controller should sync up a channel. If it doesn't, you may have to connect it with the USB wire until it syncs properly. We have had troubles also when a controller becomes sync'd to the wrong playstation (we have 3 in this house) and the controllers can work up to 40 feet away. So even a close neighbor's system can interfere. Once you have sync'd it with the USB wire, then it should work fine wirelessly.
Dec 21, 2009 | Sony Video Game Consoles & Games
I tried to connect my controller to the ps3 and all it does is it just keeps blinking, help me
Putting batteries in controller
Turn on the PS3
Turn on controller
Press the sync button, the LEDs will flash rapidly
Insert the usb that comes with the controller, the LEDs flash slowly
Press the home button on the remote
READY.
Aug 12, 2009 | Intec PlayStation 3 Turbo Shock III...
Protocol Manta 4-Channel Radio-Controlled Quad-Copter Logo
43 people viewed this question
Top Protocol Toys Experts
scamatics777
Level 1 Expert
 Mikey
Mikey
gmduvall
Are you a Protocol Toy Expert? Answer questions, earn points and help others
