Question about Microsoft Xbox 360 Arcade (4 GB) Console
Xbox360 wont restore to factory settings
A required storage device has been removed !
3 Suggested Answers
Bengharsa
  • 20 Answers
SOURCE: My xbox 360 wont play
Either you cpu is over heating or you need a new disk drive, you could fix these problems yourself, but it can be complicated, time consuming, and risky. But if you want to fix it your self just look up how to fix it on google and you should be able to find some reliable instructions. i would recommend calling xbox and seeing if they can help you.
Posted on May 18, 2011
87600hurri
  • 6 Answers
SOURCE: How to fix XBOX 360 error message "A required storage device has been removed."
clean the cache. highlight over your drive. then hit y. select the clear/clean cache whatever it says there. mine was just doing this.....cleaning the cache seems to have made it feel better since my movie is playing now
Posted on Dec 18, 2012
How to hard reset cherry mobile superion radar c
Hi Juramil,
Try this:
1. Open your device's Settings. The Settings app can have varying icons depending upon on your specific device, and may be also be found within the App Tray or by pushing the phone's dedicated menu button.
2. Find your Factory Reset option. Depending on your device, the "Factory data reset" feature may be located in one of two sections within the Settings app:
Select the "Privacy" settings, and scroll down to "Factory reset"
Select the "Backup and reset" settings, and scroll down to "Factory reset"
3. Tap "Reset device" to delete all data and restore your device's factory settings. The accounts that you are signed into will be displayed on the screen. By default, all of your phone's internal storage will be wiped.
If you want to erase all of the data on your phone's SD card as well, check the box at the bottom of the screen.
4. Confirm the process by selecting "Erase everything". This will delete all data and restore back to your device's factory settings. Your phone will be as if it just came out of the box.
Jun 02, 2017 | Cell Phones
Why wont my i rulu tablet wont unlock or power off ?
This might fix your problem
Every Android handheld has the same pattern on how to restore or reset the phone back to factory settings. Factory settings means you are wiping the data in the internal storage but not whats on the SD card. See steps below: 1. Turn off the tablet by pressing and holding the power for 30 seconds and tap shut down. 2. Press and hold power plus volume up until an android menu appear 3. Use the volume keys to navigate and option key or power to select. 4. look for factory reset and wipe data 5. restart the device and it should be back to factory settings.
Jun 19, 2014 | Computers & Internet
Samsung galaxy ace duos S6802 incoming call always busy. I try to hard reset nothing happens. Call forwarding are disabled. Please help me to fix.it
When a Samsung cell phone becomes unresponsive or when the device slows to a crawl, a reset may be in order. There are two primary methods used to reset the phone. Users should always start with the soft reset when the phone locks up or programs slow down due to memory or software response issues. A soft reset is akin to a reboot of the machine and usually solves most problems without any loss of user data. A hard, or master, reset is required when the phone completely locks up and becomes unresponsive to any cellular signals. This second and more drastic reset deletes all personal data, preferences and settings so that the device is restored to the original factory configuration.
Perform a Soft Reset
Step 1 Press and hold the power button for 10 to 20 seconds.
Step 2 Release the power button and tap the "Power Off" option under the "Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3 Press the power button again to restart the device.
Perform a Hard (Master) Reset
Step 1 Tap the "Menu" key from the home screen and then tap "Settings."
Step 2 Go to "Privacy" and tap "Factory Data Reset" to review the Factory Data Reset information.
Step 3 Review the Factory Reset options. Place a check next to "Format USB Storage" to clear your device of user data, such as music, pictures and other account settings.
Step 4 Review the disclaimer and verify your changes before tapping "Reset phone."
Step 5 Tap the "Erase Everything" or "Yes" buttons to confirm the reset the phone to factory settings. The device initiates the restoration process to the original factory configuration.
Perform an Alternative Soft Reset
Step 1 Power off the phone. If the phone does not turn off, remove the back cover of the phone and take out the battery. Wait between 10 and 30 seconds and then replace both the battery and the cover to restart the device.
Step 2 Simultaneously hold down the power/lock keys.
Step 3 Release the keys when the Android screen appears.
Tips
  • The ATT Samsung SII models have an alternative hard reset that requires you to simultaneously hold down the "Volume Down" and power keys after an alternative soft reset, and then release the power button, bringing up the menu titled "Fastbook, Recovery, Clear Storage, and Simlock." Use the "Volume Down" key to navigate to "Clear Storage" and then press the power button. Press" Volume Up" for "Yes" and "Volume Down" for "No." This will reset your device to its original factory setting.
  • A soft reset on a Galaxy S phone involves pressing the "Volume Up" key simultaneously with the power button.
  • Some older Samsung models have a reset button located behind the battery cover. Press the reset button using a small, blunt object.
Warnings
  • A factory data reset removes all user data and settings associated with the current account. Make a backup of all data on your device before starting a hard reset.
May 12, 2014 | Cell Phones
Phone locked up
To Restore to factory settings
1. From the application menu, Select Settings
2. select SD Card & Phone Storage
3. Select Factory data reset
4. Select Reset phone
5. Enter your password if required, then Select Yes to confirm
To do Hard reset if your phone is frozen:
1. Turn the power off. If your Samsung Moment is frozen, pull the battery out and put it back again
2. Hold the Volume Down button, Call and End until "Samsung" appears on the screen along with a menu
3. Select Master reset device
4. When the phone is done erasing, choose the option to reboot
Once the Samsung Moment reboot it returns back to factory-fresh default state settings.
Feb 21, 2014 | Samsung Galaxy Reverb SPH-M950 Virgin...
How do take parent settings of xbox
If you want to just get to the prompt to change the passcode and you know the security question, type in:
X, Y, Left Trigger, X
If you want to reset all settings to factory default you would press:
Code to restore factory defaults.LT, RT, X, Y, LB, RB, D(dpad), Y, U(dpad), D(dpad)
Go to console settings and all the way down to select system info.
Enter code above.
Then you will be prompted to restore factory defaults.
Your 360 will then restart and go to the dashboard.
When prompted to restore family settings, you would choose to skip it.
Also, you can do this while removing all storage devices if you are concerned of any changes. Just turn off your system before and after while disconnecting your hard drive or memory units.
Nov 08, 2011 | Microsoft Xbox 360 Hard Drive (120GB)
Format
  1. If you have not already installed the Device Manager, download the .exe file to install the latest version of the Device Manager application from http://www.philips.com/support. Enter your language preference and the model number e.g.hdd070. Select Software under Product Support on the left of the screen. Scroll down and click on the .exe file of your preferred language under the category PC software. The program will install both Musicmatch® Jukebox and Device Manager in one go automatically.
  2. Connect the hdd to the power supply with the AC/DC adapter.
  3. Launch the Device Manager at Start->Programs->Philips GoGear HDD->Philips GoGear HDD on your PC
    IMPORTANT: All music & content of your micro jukebox will be erased once the factory setting is restored.
  4. A dialogue box will pop up; click Restore and OK to confirm and start restoring the unit to its factory setting.
  5. Follow all screen instructions to complete the restoration.
  6. The Device Manager will close automatically once the success message is displayed. Safely remove your GoGear micro jukebox by clicking on the EJECT HARDWARE icon in your task tray bar. When prompted, "The USB Mass Storage Device can now be safely removed from the system", click OK and unplug your micro jukebox.
Mar 18, 2011 | Philips GoGear HDD075/17 MP3 Player
How to restore my laptop to its factory settings
Proir to restoring computer devices, ascertain that resources that would require backup is securely preserved. For example, computers loose resources least complented by the manufcturer with restoration to factory settings. Also significant is consulting with technician to ascertain the condition of device that least require facory settings. Usually a condition is resolvable with an alternate means least requiring factory settings. Prior arrangments that make restoration attainable includes acquiring the tool resources either as disk roms that contain programs. Usually the computer manufacturer would have provided the restore resources either as disk roms either CD or DVD. Recent computers however have built in programs restore media in which instance restore is possible without disk roms materials. Depending on the condition of the computer considering recent innovation would either require disk material to attain restore or builing functions. Usually refering to the computer support experts with conditions that are encounted would attain means to resolve.
Feb 19, 2011 | HP Mini 210-1030NR Netbook
Restore factory settings
1 Ensure all Data is backed up, all data will be deleted.
2 Please also ensure that all USB storage devices are removed before starting the recovery process
3 Restart machine
4 When your unit switches back on, wait for the ACER screen then hold down alt & tap f10 repeatedly..
5 Please wait a moment until prompted, -How would you like to restore?-
6 Please select –Restore system to factory default-
7 Enter your defined password or enter six zeros ‘000000’
8 Click ok
9 Please wait until process completed, this will take 45min – 1hour
ALL personal information on the C: Drive I.E photos, programs, music and documents will be wiped when the above steps are taken.
Files located on the D: Drive will be safe from the procedure.
Thansk & waiting for your feedback.
Apr 03, 2010 | HP Pavilion dv6000z Notebook
Hello! I have a problem. My HTC Diamon 2 in Russian I need to change it from Russian to english.is it possible? and can u help me please how to do it step by step, Thank U VERY MUCH
If you perform a hard reset, it should allow you to choose the language the phone displays. Just be sure to back up all your info/programs you have on the phone because it will go back to factory default when you do this!!!
Performing a hard reset
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings—the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset.
Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the operating system. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
To perform a hard reset
1.
With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to the manufacturer default settings. Press VolUp to restore manufacturer defaults, or press other keys to cancel.
3.
Release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Using Clear Storage
If you can access the device settings, you can use Clear Storage to reset your device back to factory default settings.
1. Tap Start > Settings, and then tap All Settings.
2. On the System tab, tap Clear Storage.
3. Enter "1234" and then tap Yes.
Dec 17, 2009 | HTC Touch Diamond Smartphone
Cant press send to restore factory default
u need to hard reset ur device for factory default ...go to start >> setting >> system >> clear storage....then ur phone will format to default factory setting and also ur all data will be lost...make sure that u take backup of ur data..if u need..
Nov 26, 2008 | i-mate K-jam Smartphone
Microsoft Xbox 360 Arcade (4 GB) Console Logo
22 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
