Question about Gateway Computers & Internet
Computer wont turn on
Hi a friend recently gave me a Gateway T1628 series notebook. The laptop doesnt turn on at all. I think it has a bad motherboard but iam not sure. Ive taken the battery out and just left the ac cord plugged in and still has no power.
  • DWDpcRepair May 11, 2010
    is the power supply good? check it with a voltage tester to make sure you are getting power to the unit.
    Brigadier General:
  • 10,406 Answers
If your Gateway computer is more than 2 years old, you're screwed, because Gateway sold all the "support" for its older models of computers to a company which went bankrupt in November 2008. So, no support and no parts are available anymore.
Posted on May 18, 2009
    Novelist:
  • 154 Answers
Could be many issues, some indication of lights or anything in your description would help. Can you see or hear the fan? Have you tried another power supply and looked at the plug part where the adapter plugs into the laptop. From there we disassemble the laptop starting with the keyboard generally and there are anywhere from 1 to 7 screws retaining it, some you must lift the panel above the keyboard first but usually screws hold this down as well. I usually remove all screws from the bottom of the laptop and then remove the wireless card and the hard-drive and dvd drive and one screw typically holds this in place.
Check all the ribbon cables and be careful of the clips that attach them and the keyboard ribbon. You should find screws under keyboard and sometimes in the dvd area once it's removed. Once the screen wires which include the camera, wifi and screen cable is disconnected and unrouted, the screen screws can usually be removed and the screen placed to one side so we can get at the motherboard if everything else looks okay.
Once making sure all the screws are out and all cables and connectors are unclipped typically under the keyboard area there are several. If one is unsure, take pics along the way.
Take a credit card and pry the top layer or mousepad and keyboard surround area beginning at the back and rear side edge to seperate the two pieces. If you find any amount of tension, check for screws that you may have missed.
Once the top layer is off you have access to the motherboard, check the connections especially where the power comes in, Some are on a cable, others are on the motherboard or a small side board. Typically the power connector is the issue but a bad power button or cable/ribbon perhaps a connector just unclipped itself to this.
To end, there are signs of little burning components one can look for, or water damage can be fixed with a toothbrush and some patience.
Sometimes it's like uncovering a dinosaur, I feel like I'm an archaelogist at times when Im working on a water-damaged Macbook Pro or something.
There are small fuses on a motherboard they are very tiny but not the tiniest of the microcircuitry. It looks confusing but if you take it easy and look closely at the board it has letters and numbers next to each piece indicating if it's (correct me if Im wrong please) L for a coil, R is Resistor, C Capacitor and F= Fuse. Not many people mention this so I thought I would There are Fuses on most motherboard (Laptops I speak of, and they are typically blue or green and again not as tiny as the tiniest of the components. Every part of the motherboard can be tested with a tester a VOM Voltage Ohm Meter. the measurement of Ohms is how much resistance is in the circuit. A fuse will have no resistance and if you get the meter that beeps when on Ohms you don't have to look at the meter to see whether the circuit is open (no beep or burnt fuse) or closed.
Diodes allow flow in one direction but not the other, and basically transistors can be tested in the same manner with consideration that the component, while tested within the circuitry may give you a false reading. it's always best to have the part out of the circuit to test it properly but that would be impossible.
If I found a bad fuse I would simply solder over it. You cant do that to a bad capacitor or resistor but perhaps with small enough tools you can attach a wire to each side of the bad part and then attach these wires to a new microcircuitry part.
This is a bit detailed and not for ,most people. This is what you pay for when you bring your laptop to a reputable person. you can find people on local sites such as Kijiji but always beware of scammers. If you know where they live it's less likely for someone to drive away with your laptop never to be heard from again.
There are videos on youtube that can help you if you are interested in learning this stuff and to fix all your machines perhaps ,most I guess would be more appropriate.
Take pictures along the way if things look confusing. Take notes and put screws and stuff in a small container.I typically have spare parts and can connect a motherboard to it's screen and power it up without any casing./
Give us feedback please.
East Coast Canada Rules!
Good Luck.
Posted on Apr 12, 2014
Remove top
To me when you state remove the top of a laptop, you are talking about removing the Palm Rest Cover.
With the laptop closed, the top cover is the Display Cover.
This, I suppose, could be considered the 'Top' also.
At any Ol' rate here is the link to a free Service Manual, for the Gateway NV53 series of Notebook PC's.
I think you'll find it crosses directly over, to the Gateway NV52 series of Notebook PC's; which you have one of,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Go to the top line - Gateway 400. (400 in blue)
Drop down to the second line, scroll over, and click on the blue -
NV53
Now you can disassemble the Display Assembly, or remove the Palm Rest Cover.
If it is the Palm Rest Cover post back in a Comment.
The reason is I want to give you needed information.
The main one is the Keyboard Cable connector on the motherboard.
IF you break that ZIF connector, you are looking at MOTHERBOARD REPLACEMENT, and why I want to guide you.
(Or any of the other ZIF connectors on the motherboard.
Zero Insertion Force)
A) http://www.insidemylaptop.com/disassemble-gateway-nv-series-laptop-fix-power-jack/
Post back in a Comment.
Regards,
joecoolvette
Feb 19, 2013 | Gateway NV52L06u Laptop PC
Gateway CX 2620 unit won't turn on. Replace motherboard?
If the power LED is on then -
The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Sep 01, 2012 | Gateway Convertible CX2620 Notebook
Gateway PC screen blank, geek squad diagnosis motherboard issue
You could replace the motor board for less than $100 but I think the geek squad says the motor board is bad on every computer that doesn't start right up for them so I would have someone else look at it first. Or just get a new computer at walmart for like $300
Jul 23, 2009 | Computers & Internet
Gateway w350a when turned on wont get past the black screen
gateway w350a T-series HDMI power on but screen stays blank...Its just a black screen. Is there a fix for this?
Mar 31, 2009 | Gateway M305CRV Notebook
Gateway Solo 9300 Laptop computer notebook PIII 500MHz
This is not a good laptop, If you are thinking of purchasing. My advice is no. It just doesnt have the processing power to run almost anything.
If you could leave a comment with a price range your willing to spend. Ill find you a laptop thats much nicer.
Jan 05, 2009 | Gateway Solo 9100/9150 Series Laptop...
My computer keeps freezing when i turn it on
reboot the machine. tap the f8 key and select safe mode. boot into safe mode and see if the computer freezes up again.
in the event it doesnt, you have a bad driver or new software on the drive. to correct this go to gateway.com select your model and download any recent updates including the bios. also uninstall any new service packs or software you had loaded recently.
reboot machine and see if you have the same error.
if this continues or it froze in safemode you could have two problems,
1. Corrupt OS files, the fix: Restore Machine after backing up data.
2. GPU having issues and heating up to the point it turns off, the fix: Local repair shop or Gateway replace mobo or local repair shop reflow board.
Let me know what you try and what works! Good Luck!
Ruben
Nov 08, 2008 | Gateway MX8711 Notebook
I have the window vista soound problem
The notebook i assume has the realtek sound chip, but at the moment their site is down so click on the link below and download the Vista sound drivers and see if they work for you, but it could be that your motherboard manufacturer does not yet have any supported sound driver for Visat. http://drivers.softpedia.com/get/SOUND-CARD/REALTEK/
May 01, 2007 | Gateway MX6450 Notebook
Computers & Internet Logo
279 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
