Question about Dell Inspiron 6000 Notebook
I have a problem with the point where i connect the power cable for my inspiron 6000...its loose or something,battery is fine and have tried diff chargers...i have to twist it and hold in a position to keep it charging.what can i do?
  • ajarn18 May 18, 2009
    thank you!
  • Dell Master
  • 32,281 Answers
You can get it repaired or do it yourself. The power connector may only need soldering, worst case, it will need to be replaced.
Posted on May 18, 2009
Dell Inspiron 6000 (approx 4 years old) has an issue with the power cord internal connection? Battery and Power cord/adapter are fine. Computer constantly switches from battery to AC when powered on. ...
The input jack that is soldered to the motherboard (where the AC jack plugs in) probably has a cold solder joint. Thus the laptop switches from battery to AC power. You can try to have the solder joints
re-soldered.
Jan 04, 2011 | Dell Inspiron 6000 Notebook
Hello, Recenlty, when I started up my laptop I got a blue screen with a message to the effect of "windows has been shut down to prevent further damage." I've tried to restart in every configuration and...
Try to remove the battery and connect the power adapter and the cord only. Making sure that the power adapter has a green light. Then try turning on your laptop. If it fails then the power adapter is broken, you are going to need a new one, exact model of the power adapter. In any case, you can always recover your files by removing the hard drive from your laptop and insertng it to an external casing so that it will be an external hard drive. By this, you can connect this to another computer thru usb connection where you can back up your important files.
Oct 11, 2010 | Dell INSPIRON 6000 CENTRINO...
New aftermarket Inspiron 6000 battery will not power the Laptop
I would say that the power management portion of the system board is probably faulty if it behaves the same with both the factory battery and the aftermarket.
Many systems have the charge controller and battery interface on a separate board but unfortunately on the Inspiron 6000 it's integrated.
FYI, Here's a copy of the service manual for that system: http://support.dell.com/support/edocs/systems/ins6000/en/sm/index.htm
Jan 21, 2010 | Dell Inspiron 6000 Notebook
Dell inspiron 6000 not charging
suspected faulty battery. replace the battery.
May 28, 2009 | Dell Inspiron 1501 Notebook
Battery charging port issue
This sounds like a connection issue inside the computer. What this means is that the soldering inside your computer at the point of connection is probably weakened, and you will need to take your computer in for repair if you are not very good at soldering. Unless you are VERY talented at soldering, I do not suggest doing this repair yourself as you can damage or ruin your computer.
Alternatively, there may be a loose pin or something of the sort at the point where you plug your adaptor in. Again, this is something that needs to be looked at by a professional.
Jan 23, 2009 | Dell Inspiron 6000 Notebook
Sudden shutdown dell inspiron 6000
hi, i have something strange found in my inspiron 6000:
it looses SMD-parts in the dc-power-converter!
...strange isn't it?
maybe are the suddenly shutdowns the beginning of this ****!
you need someone who knows good soldering....
...and maybe someone can tell me which kind of parts the mine d6000 has loosen :oD ?
it came back from dell *without*...!!!
...please can someone post me a foto?...
thanx, lapdoc
Dec 16, 2008 | Dell Inspiron 6000 Notebook
Inspiron laptop Battery won't charge
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
Jul 10, 2008 | Dell Inspiron 6000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Half a Screen
Check first by connecting it to an external monitor. If you see that it is the same problem in the external monitor then I think there is something wrong with your video card. See if you can re seat the video card.
This issues also come from the cable that connects the LCD with the motherboard. Have you opened the Laptop anytime and moved the cable?
Check these first. It sounds something loose or a something related to video card.
Jan 16, 2008 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron 6000 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
