-   whirlpool hood H00 B 01 S from ikea lights go off after a few minutes fan still working getting replacment from ikea under warranty. Item brand new when fault found when cooled down light would operate but now lights dont work at all. Fuse ok as fan still works.-   stevedoyle1
Mar 11, 2008
-   Binned it when I found out the controller part had blown and was £80 to replace. Bought a different model cheaper than the part. Useless piece of kit. Glad its gone.-   Guest
Feb 24, 2008
-   same problem, both lights not working. replaced bulbs, not the problem. Bulbs are not bown. found fuse, not blown either. cannot find schematic for actual wiring, only "instruction" booklet"........-   la jolla
Jan 12, 2008
-   Have same problem. With both the fan & the lights operating while cooking, everything shuts off completely and cannot turn ANYTHING back on. Then, at some point, the bloody thing will start working again but not on it's own. We'll press the light or fan button and everything will be working fine. This could be hours later, well after the time when the thing was NEEDED to work. My guess is there is a bad IC or something similar in the control unit. I am assuming the is some type of PCB board. I will contact Broan on Monday (closed weekends) and speak with tech support. I see other postings on internet with same problem. It looks nice but that's about it...bloody thing doesn't work when you need it to.-   Guest
Dec 09, 2007
-   Same problem. Bulb blew and everything in the hood stopped working. Tested a couple of leads and there is still power there but have not yet measured voltage-   oopsbang
The extractor fan in my kitchen in leaking. I;ve not used the fan in quite some time yet it's...
(More)
The extractor fan in my kitchen in leaking. I;ve not used the fan in quite some time yet it's leaking a considerable amount of water. On remiving the front cover of the fan I cannot find any obvious evidence of where the water is coming from. The name of the fan is Elica.
Turned on bright light and low fan speed on Zephyr Typhoon AK2100 series (stainless). Heard...
(More)
Turned on bright light and low fan speed on Zephyr Typhoon AK2100 series (stainless). Heard "pop", burning insulation smell, saw smoke. Fans stopped turning but bright lights remained "on". Now only bright lights work, not dim lights or fans. What is wrong, who can repair in Houston area.
A local small contractor installed our Kobe RA3830SQ Range Hood a few days ago. We have not been...
(More)
A local small contractor installed our Kobe RA3830SQ Range Hood a few days ago. We have not been too impressed with the efficiency of the fan. Today I noticed that it seems to blow out instead of sucking out the air. Is it possible that the wires were connected erroneously. Thanks
whilst using cookerhood on no 3 - full power and lights on, the cooker hood just turned off as though a fuse had blown / no fan or lights working!!
Changed 2 fuses but still not working1
