Question about Samsung HL-S5087W DLP TV
Cooling fan motor is making loud humming noise
I have a Samsung DLP TV. Model # HLT5075SX/XAA. The cooling fan for the lamp is making a humming noise. Is it a problem to replace the fan motor myself and do you know the part #. I appreciate any help you can give me.
Thanks,
Bob W.
  • 41 Answers
You will have to pull out the light engine. That will consist of 4 or more screws and disconnecting some plugs. The the whole unit slides out where you can get to the fan housing.
Unless you're mechanically inclined, you should not try it as you could damage the assembly.
I don't know the part number off hand and some of those have newer part numbers as replacement for the original. Just do a google search to come up with a part number.
Posted on May 18, 2009
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
Samsung DLP HLN5065WX/XAA
that's from a thermal switch, to keep the innards cool, post use. Seems to me that you might just check to see that all vents are open and clear of debris, for starters.
May 07, 2008 | Televison & Video
I have a Samsung DLP HLT5075SX/XAA and I just replaced the bulb. The tv comes on but it's white with tiny black specs and and two thick black lines going across the bottom. There is no sound but...
The lamp should get very hot---make sure fans are running.
If you happen to remove the lamp---look at the color wheel that faces it to see if missing any pieces--it will before failure make a high pitched or even fan like sound.
You may have a problem in the light engine or the board often called the DMD which is part of the engine.
Jun 13, 2012 | Televison & Video
My tv is a samsung dlp 5063w I change de dlp bulb and now is working good but from the back of the tv is a loud noise
Ok look my friend..
first i need to know what type of sound is it. like a click or a buzz?
and then here are 3 suggestions.
first clean your TV with some latex globs and a can of compress air try to do it really good try that...
second. check that all the cooling fans are working just fine!
last one. its your color wheel and you need to change it.
here is a link were you can find the part and not so expensive prices!
http://www.discount-merchant.com/PANASONIC-Cooling-Fan-Set-Cooling-Fan-Set-p/1002171.htm
http://www.discount-merchant.com/product-p/samsung-bp96-00674a-cw-enc.htm?1=1&CartID=0
good luck!
Jan 21, 2010 | Samsung DLP HL-P5663W 56" TV
Making a lot of noise
Sounds like a bearing in the cooling Fan
Thanks for using FIXYA
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
50' DLP TV losing picture
the cooling fan is failing and you probably need a lamp replacment
Aug 06, 2009 | Samsung Televison & Video
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
krugie, get it replaced now or the lamp will burn up, be advised that they are expensive to get replaced, not an easy job to do, fix it now or pay much more later is the best advice I can give you, good luck, BMW Rider
Dec 28, 2007 | Samsung HLN437W 43" Rear Projection HDTV
Samsung HL-S5087W DLP TV Logo
1,304 people viewed this question
Henry  Thomas
Henry Thomas
