Question about Cuisinart SS700 Single Serve Brewing System
Coffee solenoid valve is blocked how to unblock it
Franke evolution flow meter err
coffee piston might be blocked or in the worst case flow meter might be scaled up or not sending signal but most of the case will be coffee piston blocked up.
Feb 01, 2012 | Franke Mambo Espresso Machine
Water is not pumping.
Hi, it seems that the coffee solenoid valve is blocked or broken. Cofffe solenoid valve is the valve which open to deliver the water after the pump to the coffee shower.
Apr 26, 2011 | Saeco Talea Ring Plus Espresso Maker with...
How do you clear a solenoid valve blockage? Our Oscar pumps water without a problem and the steam works. As soon as I put coffee in the holder and tamp, even a little, nothing is dispensed and the water...
  • be sure from where it leaks? 1> solenoid valve the discharge way 2 > security valve of system.
  1. if it leaks from solenoid valve you must change the mechanical part of valve
  2. security valve of system may need to be repaired , after repair you must set the valve to start leaking at 11bar.
if it is solenoid it can be from the un-cleaning with detergent&blind filter, to provide longer life of new valve you should purchase them and clean with them periodicaly.
Feb 12, 2011 | Nuova Simonelli Oscar Coffee Maker,...
Hi, My Gaggia Classic is not working. No water
try to clean the group shower which it can be ansrew by one cetrer screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Bothe the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
If you manage to clean everything above and the machine work ok so from now on in order to avoid the problem again try to flush water from the group many times without any coffee. With this is like you wash the group shower and valve from any remai coffee.
Good luck
Jun 29, 2010 | Gaggia Classic Espresso Machine
When trying to steam milk, very hot water comes out of the steamer arm and curdles the milks. Additionally no hot water comes out of the opening for the coffee, so no espresso is made. This started...
It seems that your problem is the one mention second that no water come out for coffee. So every time you try to make coffee the boiler is overflow and you have more water from steam tap.
So you have to clean the coffee shower on coffee group head since this might be blocked by dry coffee. Also the coffee solenoid valve could be also blocked from dry coffee and it can be removed and cleaned with a wire brush. It can be also be damage and most posible the solenoid coil burn out so you might need a new solenoid. So I beleive if you solve the coffee group blocked problem then you might have solve also the steam problem,
Good Luck
Remeber to vote for this answer.
Feb 23, 2010 | Krups Cappuccino/Espresso Maker -...
Water not pumping out of coffee machine
It seems that the coffee solenoid valve is blocked or broken. Cofffe solenoid valve is the valve which open to deliver the water after the pump to the coffee shower.
Feb 17, 2010 | Saeco Talea Giro Espresso Machine
Water in grounds container
The coffee solenoid valve return side is blocked from dry coffee. You can use cleaning tublets to clean some times the coffee group. With this it might be unblocked if not then you should remove it and clean it with warm water
Jan 30, 2010 | Jura Capresso Impressa S9 Coffee...
Rancilio Silvia is blocked (not completely but substantially. Water is restricted out of both the brew-head as well as the steam-wand. I've cleaned the 3-way solenoid valve and I've run CleanCaf twice....
Your problem sounds like a water pump issue rather than the 3 way valve, try priming the circuit by opening the water valve when you clean the system(if you can find scalekleen, use that instead of cleancaff to descale your machine).
Jun 13, 2009 | Rancilio Silvia Espresso Machine
Magic
when you put the machine do you have water or steam coming out of the valve if yes the brew unit might be block check it out clean it or unblock it cheers
Jan 31, 2008 | Saeco Magic De Luxe Espresso Machine
Cuisinart SS700 Single Serve Brewing System Logo
93 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
