Question about Moen & Posi-Temp Single Handle Shower Or Tub Valve
I recently had a new Moen Posi Temp shower valve installed. I'm having an intermittent problem now. At various faucet handle positions, the valve will start sputtering and vibrating. The only way to stop it is to move the handle to another position to change the temperature and then move it back to the original position. - I opened up the shower wall from behind and strapped all the pipes down securely and the problem still exists. With the valve exposed I heard a harsh ticking sound in the valve as the water was sputtering. Can someone please help me? It would be much appreciated.
  • 323 Answers
This problem is in the head of the valve itself. These faucets are complex systems and I have seen many improperly installed. When you pull the cover off (it has an O-ring to create enough friction to keep it in place) you will see a ring with teeth and possibly molded to fit inside the cavity in one of two or four positions. Additionally there are two tiny cups that go behind the head of the shower valve to prevent sputtering . The water must be turned off and lines opened before this is even opened. It sounds to me like one of those little plastic cups is misaligned, possibly leaving just enough space for water under pressure to escape past the wall of the cup, which creates the "sputtering".
Only professionals should attempt to install these, and I have even come behind pros that did not understand how they had to be installed. My recommendation is to call back the installer, have him pull it all out, replace that damaged cup and put it back together.
You should watch him do it, so that you see what was wrong in the installation. Properly installed there is no way this kind of thing happens.
Dan
Posted on May 18, 2009
No hot water on Moen single handle shower faucet. cold ok and shut off is fine
do you have hot water elsewhere? if not, might be that your water heater is not heating.
if you do have hot water elsewhere, did you let the faucet run for a minute or 2.
did you have hot water before? is this a new house? new valve?
need a little more detail.
on posi temp valves, if there were no water coming out of the hot side of the valve, the valve will not operate.
Aug 12, 2010 | Moen 1 Handle Lever Shower Faucet With...
I installed new moen shower valve i tested it before i put the walls up 6 months later finaly got done with bath room no water comes out now
During construction did you perhaps close off a shut off valve within the water line and not reopen it? If not do you hear anything at all when you turn the shower faucet on? Let me know.
Jul 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I just put in a Moen single, chrome handle shower faucet in my hall bath. Got it all together and the hot water is not comming out. Cold water is fine, but, when i turn the handle to the position where the...
If this is a Moen posi temp valve you may need to adjust the temperature limit stop. It is located under the handle. Usualy a plastic peice with grooves in it so it fits in another peice in the valve. If I remember right you pull this peice out and turn it counter clockwise to get more hot water. Do this in small increments and reassemble and test. I hope this helps.
May 25, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
When I push the faucet to off I get med fast
push down the tub-spout lift rod and it will empty the remaining water that is between the shower valve and the tub spout
Mar 10, 2010 | Moen Posi-Temp Single HandleTub And Shower...
I replaced my Posi-Temp cartridge for the shower faucet. While the faucet now works fine, the pipes bang (water hammer effect)in the vicinity of the faucet every time someone shuts off the hot water. They...
no one ever really figured out why this happens, but you can purchase a "hammer arrestor" to solve this problem. they work good and believe it or not they are best installed at shower valve. good luck
Jan 22, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen single handle bathtub faucet
Something is caught in the stem. Make sure the stem is free of debris. Also check that the valve or cartridge is intact.
Jul 02, 2009 | Moen 2919 Chateau Two Handle Tub and...
MOEN POSI-TEMP GOES FROM HOT TO COOL AFTER 30 SECONDS OR SO
Wow A Mystery Faucet!!! SOUNDS LIKE THE WATER LINES FEEDING THE FAUCET MAY BE SWITCHED. CHECK TO MAKE SURE THE COLD FEED GOES TO THE COLD SIDE AND THE SAME FOR THE HOT. SOMETIMES MISTAKES ARE MADE WHEN INSTALLING THE FAUCET. MAKE SURE THEY ARE CONNECTED THE SAME AS THE 2 THAT ARE WORKING. IF YOU HAVE THE TIME AND PATIENCE, YOU CAN TAKE A WORKING FAUCET AND INSTALL IT IN PLACE OF THE (mystery faucet) AND SEE IF YOU HAVE THE SAME RESULTS. IF YOU GET HOT WATER IN THE TEMPORARY FAUCET, THEN YOU HAVE A DEFECTIVE FAUCET. THESE ARE A FEW TROUBLE SHOOTING TIPS I HOPE THAT MAY HELP YOU.....JOE
Jan 30, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen & Posi-Temp Single Handle Shower Or Tub Valve  Logo
106 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
