Question about Water Heaters
Richmond water heater
Model number: 5VR30T Serial number: RMNG05058S01452: Capacity: 30gal water heater. Is this water heater insulated from the inside of tank?
  • 74 Answers
SOURCE: water heater not heating it's a richmond water heater
Now change the thermostats........this is the only other thing it could possibly be.
Posted on Apr 27, 2009
  • 744 Answers
SOURCE: pilot light on water heater goes out frequently
Check the following:
See if your heater has a pilot gas adjustment valve. It should be on the gas control valve somewhere. Not all heaters have these. It will be a screw on the valve that can be turned.
Make sure the thermocouple sensing bulb is squarely in the pilot flame and also check that the fitting where the other end of the thermocouple connects to the main gas valve is tight.
Check the pilot gas orifice (where the pilot gas comes out) for carbon build up - you may need to remove the pilot gas line and thermocouple assembly to get to this. This problem is pretty common.
Check the gas pressure to the heater. Run the hot water in the dwelling until the hot water heater starts. Check the flame on the main burner and see what color it is - it should be blue with possibly some yellow-tipped flames. If not, there could be a problem with the gas pressure at the heater or venting. If the heater has a gas pressure regulator, it may be out of adjustment or defective.
Finally, and this isn't very common, the pilot light can be extinguished if there is a draft problem, usually associated with an issue with the flue pipe venting system for the heater or another nearby gas consuming appliance.
Posted on Dec 31, 2009
Testimonial: "thank you. will try these suggestions tomorrow. really appreciate it."
SOURCE: need reset code for richmond
I am poting this here hopefully it will help someone else. I have a richmond 40 gallon power vent water heater and it was not working. It was flashing 2-3 on the LED. I used this procedure and it started up..
you can reset the control by unplugging the blower during start up, leave unplugged for at least 5 seconds, plug back in and within 30 seconds cycle temp control from hot to low 6 times.
Posted on Apr 13, 2010
mkh5094
  • 145 Answers
SOURCE: TRYING TO REPLACE MY OLD RHEEM WATER HEATER MODEL
I would say your water heater is from the fury series; new model number 82V52-2. I've included a link with my solution that you should take a look at. You could also look at water heaters of a different brand if this one isn't available in your area. Kenmore, GE, and Hotpoint are all very good brands of water heaters.
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
Posted on May 25, 2010
SOURCE: i have a richmond gas hot water heater model
lock out code....turn off unit for 1 minute (unplug) press both arrows and hold for 5-10 sec... then enter L R L L ... R L R R...that should reset it.
Posted on Jul 25, 2010
Can Richmond tankless heater which is now LP be converted to natural gas?
If it can, then it is done with dip switch settings.
Read your product manual.
Switching types of gas, and messing with dip switches is dangerous.
LP gas burns much hotter than NG, and LP pressures are much higher than NG
Call Rheem with serial number and they might supply the information to you, but will likely tell you to call service technician... leaving you in exact same spot you are in now.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Gene
Sep 29, 2014 | Rheem Richmond Encore Tankless LP Gas...
Richmond 5v40-36f
1) My search does not show that product exists, or existed before the internet.
Maybe that product only exists on fixya.
Or the water heater is older model number from Rheem., aka Richmond, Ruud etc.
Or fixya picked up a model number from a question, and the person asking question did not copy model number correctly from label on side of tank.
It might also be older manufactured home gas water heater.
Feb 07, 2013 | Audiovox Water Heaters
Need a blanket for Rheem Water Heater model #22VRP75.
You have 75 gallon gas water heater.
I install water heater insulation 3 ways:
1) Easiest: buy ready-made blanket from Lowes and use duct tape
2) Harder: wrap heater in ordinary fiberglass insulation and use tie wire
3) Hardest: Build a box out of blue styrafoam >> leaving room for air intake for gas water heater, and space around vent pipe
Instructions for gas water heater:
Do not cover TP valve.
No insulation is put over gas valve or air intake.
No insulation touches vent pipe.
Remember the gas water heater has to breathe air into the burner, and aftter combustion takes blace, hot gases escape so extra space is left around hot vent pipe to avoid fire.
Find age of Rheem: look at 3rd and 4th digit of serial number, for example 06 was manufactured in 2006.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 11, 2011 | Rheem Tank Water Heater G75-125, 75 Gallon
I am only receiving half of the normal amount of hot water.
You have electric water heater.
Electric water heaters are fully repairable by homeowner, excluding hybrid type.
Rheem electric water heaters:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Rheem fury series manuals and models
Age of Rheem water heater is shown first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements in case you need to buy new generic 4-bolt type 4500 Watt element from hardware store.
A) If your water heater receives very cold incoming water, it may not heat fast enough to keep tank warm.
Add a tempering tank.
http://waterheatertimer.org/Tempering-tank.html
Add insulation over entire water heater except TP valve. Insulate pipes completely.
Read more information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
B) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
Rheem ships all water heaters with 4500 Watt elements.
Narrow down the suspects:
C) Water heater has some hot water.
This tells us upper element is working.
And that water heater electricity is working.
And that reset button is not tripped.
And that heater is not experiencing run-away overheating event.
That gives us 3 solid suspects.
1) lower element is burned out. Test lower element using inexpensive multi-meter from Home Depot.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace element with same wattage shown on label, and clean out sediment:
This will restore water heater to full 99% efficiency.
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
2) Upper or lower thermostat is bad. Replace both thermostats for about $25.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If you want to test thermostats and all parts before replacing anything:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
3) Burned or shorted wire. Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
geno_3245_185.jpgRheem 4500 watt element
Dec 14, 2010 | Rheem Water Heaters
The water want stay hot very long
Age of Rheem
water heater is first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements.
B) If cold outside temperatures are not to blame, your water heater may have a bad thermostat or bad lower element.
C) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
D) Water heater has some hot water.
geno_3245_183.jpgRheem element
Dec 14, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
A very old rheem fury water heater i assume it's just worn out but because of a space problem i can't go wider than the 15 inch diameter it has.
16" diameter water heaters could work if you cut away the metal and insulation off of 1 side of the water heater. The actual tank inside the shell is smaller than outside diameter.
American gas water heaters shows a 30gal 16"
model BFG61-30T30-3NOV
http://www.americanwaterheater.com/products/pdf/NRGSS00107.pdf
AO Smith has 16" Promax 30 gallon gas
Model GCV30
http://www.hotwater.com/lit/spec/res_gas/ARGSS01406.pdf
ELECTRIC 6 gallon point of use
http://www.hotwater.com/lit/spec/res_elec/AOSRE50400.pdf
You can get a tankless water heater if you have the additional money and a water filtration and softener system and don't mind expensive repairs if you install it yourself.
Oct 22, 2010 | Rheem Water Heaters
Richmond power vent water heater won't stay lit. I've reset the unit several times and the unit will run for about 10-15 minuets then shuts down (into lock down). Then I have to shut it off unplug it and...
I have a 40 gal richmond water heater with power vent and had a similar roblem. I call to talk to a tech and he suggested the vacuum switch. I ordered on line. It was $43 plus shipping and I installed it and it did the job. I happy.
Mar 29, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Water heater not heating it's a richmond water heater
Apr 27, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Water Heaters Logo
47 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
