Question about Panasonic SC-HT900 System
The power went off for a short period of time,now I can't get it to start up again.the unit is powered up but no sound its an LG
3 Suggested Answers
Poohs
  • 4 Answers
SOURCE: Powerdown after a few seconds
Changing IC001 fixed my problem with a DMR 55 -classic start-over symptoms slowly getting worse, although once the unit managed to start it would normally work okay except for occasional breaks during recording. Interestingly, it only struggled to start when a double-sided, cassette RAM disc (the ones like a big PC floppy disk) was in the drive. No disc, or a single sided non-cassette disc was fine ! Before changing IC001, I measured the DC voltages at the "ribbon" connector onto the main board whilst the unit was trying to start. Every time it failed, all the DC voltages disappeared suggesting that the Power Supply circuit was also completely shutting down, and reinforcing suspicions of a dodgy IC001. The Power Supply board was also quite badly discoloured under IC001 suggesting it was getting very hot. I noticed that at the points the heat sink is soldered to the board, the board was not at all discoloured suggesting that very little of IC001's heat was being dissipated in to the heat sink, but being conducted down IC001's leads (were the board was most discoloured). Like other's had commented, IC001 had no thermal grease between it and the heat sink !!!! I also extended the original heat sink by joining more aluminium I had spare, in an attempt to keep the replacement IC001 as cool as possible. Well done to everybody who did the "trail blazing" on IC001 !!!!
Posted on Aug 21, 2007
  • 46 Answers
SOURCE: What malfunction of the Panasonic power supply ETX2MM702MFN?
CAPACITORS ARE THE MOST COMMON PROBLEMS WITH PANASONIC POWER SUPPLIES. THESE CAPACITORS EITHER BLOW UP ,CRACK OR BULGE ON THE TOP... IF YOU SEE ANY OF THESE REPLACE THEM... YOU CAN PUT A LITTLE HIGHER VOLTAGE TO KEEP THEM FROM FAILING BUT DO NOT CHANGE THEIR VALUETHIS IS THE CAUSE FOR NO PICTURE ONLY A BLINKING LIGHT ON YOUR TV BUT NOTHING ELSE.
Posted on Mar 01, 2012
Refrigerator will not restart for a very long period of time after power cut.
there may be a faulty capacitor for the compressor motor
I would suggest a technician check it out as it should come back working within minutes of a power cut
there will be a short delay until the pressures even out as compressors have difficulty starting under pressure but you delay is extreme and needs checking out.
Apr 27, 2015 | LG Refrigerators
LG LCD 42" sound but no picture
From this web site it says:
http://www.ehow.com/about_5379235_lg-television-problems.html
Powering Off
  • Many LG LCD television owners report having a problem with their televisions where the screen powers on, but then lasts only a few seconds or a few minutes before powering itself off again. The problem usually occurs with brand new televisions, and in this case is inside the television itself. If your television is powering off unexpectedly, contact LG so it can be serviced.
Read more: http://www.ehow.com/about_5379235_lg-television-problems.html#ixzz2qeK8T3SU
Jan 17, 2014 | LG 42LC2RR 42 in. HD-Ready LCD TV
LG 42inch LCD tv,Problem first started when on standby i try to power on and it was taking its time,getting longer and longer,Finally after watching the tv for a long period i put to standby,The next day I...
The tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 22, 2011 | LG 42LC2D 42 in. LCD HDTV
When powered on the tv makes a constant clicking sound
THe clicking noise is the relay on the PSB that allows AC to be sent to the psb. It won't hold in due to some fault either in a resetable link or some other safety component. To check this unplug the cord from the mains for an hour, then try again. You should hear the relay click once and then the TV will power on for a short period before powering off again. The solution is to replace the component, other than that replace the psb. I can't get a manual to prove this so I am just making an intelligent guess until I can prove it.
Apr 19, 2010 | LG 42LC2D 42 in. LCD HDTV
No output at all
okay close laptop remove battery, open ram / memory compartment, remove memory. try holding down power button for 3 minutes. THEN INSTALL BATTERY , NOT RAM/ MEMORY AND PRESS POWER BUTTON AND IF YOU HEAR A SOUND THAT GOOD NEWS THE SCREEN MIGHT COME ON, OR IT MAY NOT, BUT YOU SHOULD HEAR A BEEP, IF POWER BUTTON REMAINS LIT HOLD DOWN TILL COMPUTER TURNS OFF, THEN INSERT MEMORY/ RAM AND FIRE IT UP. WORK THESE STEPS
Jun 02, 2009 | Dell Vostro 1500 Notebook
Periodic power loss to ignition on 2000 Tundra.
Check the connections on the battery,It sounds like one or both may be loose.
Jun 02, 2009 | 2000 Toyota Tundra
Power; No Pic or Sound
Hi, If you had not moved it, I may rule the SMPS (power supply board) went bad.
The unit may have suffered excessive shock that it knocked loose a connecting cable or two inside the unit. Don't be a hero though by attempting to pry the unit open. LG generally has a two (2) year warranty and they're super on repair turn around time. Call it in and they'll fix it pronto.
Best Regards
Jun 16, 2008 | LG 42PX5D 42 in. Plasma HDTV
Power went out on LG lcd tv
Those units usually have a main board that all the functions are centralized on. If the LED comes on then your power supply is operating (at least no shorts). But the main board will most likely be the problem.
C-Dog
Feb 10, 2008 | LG 37LC7D 37 in. LCD HDTV
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Panasonic SC-HT900 System Logo
13 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
