Question about Hotpoint VBXR1090D Top Load Washer
Won't stop filling basin and doesn't agitate.
I started a load and set it to the extra small cycle. I watched the water and it kept filling past the top row of holes so I shut it off. Then when I ran it through all the cycles the washer will fill, drain and spin but doesn't agitate. I had run a load before this and had left it, it flooded my apartment but I'm not sure how. Any ideas?
Check your pressure level hose. it probably pulled off at the tub or the pressure switch
Posted on May 18, 2009
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Washer will not stop filling up with water and won't agitate
Is the standpipe for the drainhose at least the height of the basket or control panel?
May 26, 2012 | GE Washing Machines
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 07, 2011 | Washing Machines
Neptune washer will not go past the first wash cycle
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Apr 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine doesn't respond to the low, medium or high water settings and keeps filling. Spin and drain cycle works. Won't stop filling and doesn't go into the wash cycle.
My GE WSM2780DAWW stack set dryer and washer was encountering the same problem (water kept filling up not stopping). I saw this page, but the SOLUTION described didn't really draw a picture for me.
Here's how I fixed the leaking washer. Sitting in front of the washer I removed two small screws on the bottom left and right of the front panel. Then sliding the front panel DOWN, it comes off. This allows a view into the machine. Around the LEFT side of the wash basin you will find a white tube. This tube is about the diameter of a pencil. My tube was not attached, and when the wash basin filled up past the point where it should stop, water came out. Reaching around the side of the wash basin with my left hand I could feel where the white tube was supposed to connect properly. Then I attached the white tube. This fixed the problem.
I left the front panel off for a day to make sure it didn't continue to leak and also for the area to dry out.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_6ddd78f70d3cfe52
Jun 17, 2006 | GE WSM2780DWW Unitized Spacemaker Washer...
Hotpoint VBXR1090D Top Load Washer Logo
119 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
