Question about NKOK Singer Chainstitch Battery operated Sewing Machine
How do you thread the machine?
I had to rethread it, now it won't sew. There is no bobbin?
My Bernette 715 isn't picking up the bobbin thread and is getting jammed. Any ideas what's wrong?
First thing to always try: Install a brand new needle. A dull, worn, or bent needle will cause great frustration. It is also the least expensive resolution to most problems.
Second: Remove all the threads. RAISE the presser foot. Rethread from the beginning making sure it is threaded correctly.
Pull up the bobbin thread before beginning to stitch and hold the thread tails in the left hand while slowly taking the first few stitches:
How and Why to Bring up the Bobbin Thread
If still having issues with not pulling up the bobbin thread, the needle/hook may be out of time.
Sewing machine won pick up bobbin thread hook timing fix
Feb 06, 2016 | Sewing Machines
Machine saying to rethread the upper thread but not picking up bottom thread from bobbin. Constantly rethreaded upper thread still won't sew.
Consult the owner's manual to make sure it is threaded correctly. Install a brand new needle making sure it is installed properly. Also, be sure to RAISE the presser foot BEFORE threading the upper thread.
If it is still not picking up the bobbin thread, the machine may be out of time.
Jan 20, 2016 | Brother InnovIs QC1000 Electronic Sewing...
My kenmore sewing machine model 11607090 won't pickup the bobbin thread
try changing the needle
try rethreading the machine top & make sure to use
every thread guide
make sure the bobbin is turned the right way in the bobbin case
it's also possible that the machine may need to be checked to see
if there is a timing problem
Oct 15, 2012 | Kenmore 11206 / 11306 / 11506 / 11606
My kenmore sewing machine won't pickup the bobbin thread
if you've tried changing the needle & tryed rethreading the machine
then it's possible that the machine need to have the timing checked
Singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Nov 24, 2011 | Singer 7426 Mechanical Sewing Machine
I am having a problem with my Janome Decor Excel 5018. It was working fine, until the bobbin thread won't gather with the top thread. And the top thread is binding up underneath the fabric. Kim
try a new needle
rethread the machine top & bobbin, that way you make sure the thread is not caught anywhere
make sure the bobbin is correctly inserted in the machine
clean under the needle plate & in the bobbin area for loose thread & lint
always keep a long thread tail of 3 to 5 inches long, & keep the tails pulled back behind the needle
before sewing
if none of these things help the problem,, then it may need to be serviced
Aug 10, 2011 | Janome D'cor Excel 5018
Brother xl-2600 As I am sewing ( not thick material) the thread keeps breaking, also over seams it is not sewing through. Then, when my bobbin ran out, went to change it and when pulling the needle down...
try changing the top thread tension to 3 or 4
also rethread the machine just in case the thread is hung up somewhere
take the bobbin out & put the bobbin in reverse of what you did before
you said you changed the needle, check to make sure it in correctly,, the flat side goes to the back of the machine, push it all the way up before tightening the screw
Aug 06, 2011 | Brother XL-5340 Mechanical Sewing Machine
The machine won' tsew as if the tension is too tight any ideas?
try rethreading the machine top thread & bobbin
try a tension of 3 or 4
make sure the thread move smoothly around the tension disks
make sure before threading the needle that the thread pulls smoothly
Nov 17, 2010 | Brother XL-5130 Mechanical Sewing Machine
Needle does not pick up thread from bobbin
rethread the bobbin and/or check the bobbin is placed correctly, rethread upper thread
Feb 11, 2010 | Sewing Machines
The bottom thread is all tangled. I have
Hi! This is the machine I use (mostly) and I've found it really doesn't like lint. I brush out lint every few hours and it has made a huge difference in how my machine sews. I suspect your machine may be as sensitive to lint as my is, so give her a really good cleaning. Then, rethread (yes, I know you've done that already, but do it again, for grins.) everything. Pay careful attention to the way the bobbin thread comes off the bobbin (from left to right) when you rethread. If you usually use the automatic bobbin pickup, don't. Pick up the bobbin thread the regular way, and, holding the top thread and bobbin thread securely in your left hand, start to sew.
I sure hope this helps!
Please let me know if this works, ok?
Robbie
Jan 28, 2010 | Brother CS-8060 Computerized Sewing...
NKOK Singer Chainstitch Battery operated Sewing Machine Logo
24 people viewed this question
Top NKOK Toys Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a NKOK Toy Expert? Answer questions, earn points and help others
