Question about Apple MacBook Air
MacBook Air audio driver - Apple MacBook Air
Pairing MacBook Air (2012) with Aluratek 30 pin bluetooth audio receiver please help
I'm not clear what "30 pin" refers to. It sounds irrelevant to your question or am I missing something?
Try this:
Go to System Preferences, click on Sound. Make sure you are on the Output tab. Select your device.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_1e5d703456353ef9
Jun 23, 2014 | Apple MacBook Air
How do I Return regular keyboard functionality on Apple MacBook Air notebook
Sounds like you need a new keyboard. You can get one from apple or a third party vendor. One thing you might try is re-installing the drivers for the keyboard.
Mar 05, 2014 | Apple MacBook Air Mac Notebook
I have no sound on my MacBook air. HELP! The Mute button in Sound is dimmed. And the screen displays: NO DEVICES FOUND. PLEASE HELP!
Go in to the "applications>utilities" folder. Run the "Audio/MIDI Setup" program. Insure the audio out is actually going to the audio out.
Mar 08, 2013 | Apple MacBook Air
Monster clarity does not work wired
Mine wouldn't either. Now I have paired it with the Bluetooth and it installed something (drivers?), and now it works. So, now how do I know if it is always connecting Bluetooth or wired? I connected the wire and it is still working, so now how do know if I really need the wire or not???
Oct 24, 2012 | Monster Clarity Hd Precision Micro...
Can not get audio input
If you have a first generation Macbook Air, there is no line-in nor microphone jack on this model of Macbook Air. On the latest Macbook Air models, you can use the Apple earbuds that have a build-in mic in them for a mic; otherwise, you'll have to use some kinds of USB audio adapter.
Jan 03, 2012 | Apple MacBook Air
No audio output i tried restoring and rebooting but nothing. Macbook Air.
Usually a problem with your audio jack. The jack detects an optical plug and switches to optical audio. Clean it with a compressed air can. Otherwise The apple store will probably help you. If not there are third party places that will find out what's wrong. If you want to do it yourself, the good news is, it'snot too hard to open it. Here is an Macbook Repair Guide that shows how to open an Macbook. Just open it and let it try, clean off any corrosion you can find. If you want somebody else to do it for you go to iPad Repair NYC.
May 06, 2010 | Apple MacBook Air
Macbook air internal mic not working
This is a known issue with some of the Macbook Airs - you should bring the machine to an Apple store, or open a case at apple.com
They may be able to repair/replace at no cost, depending on how old the machine is.
Hope this helps, and good luck!
For audio expertise and great AA recordings come over to my website at www.rexark.com
Jan 01, 2010 | Apple MacBook Air
My mac book sound is not working?
check your audio driver, if it is ok, check your sound options if it is muted, volume control..all are fine..then could be your speakers..if you use head phone to check it, and it does not work at all, then your audio driver, reinstall it
Oct 24, 2009 | Apple MacBook Air
Im having an issue with my Apple Macbook's audio
why use windows7? you paid for your macosx that comes with your macbook and mind you that macosx is a very powerful operating system and way better than windows. i suggest you use the macosx. you'd be amazed on how easy it is to use. i myself am a mac user and i assure you you'll never have to worry with viruses again. anyway, if you insist to use the windows7 i think the problem there is the driver for your audio. you might need the bootcamp driver on the cd that came with your macbook. try installing the audio driver and i am almost certain this will work. the red light shining in it is the laser used with fiber optic cables. your macbook is equipped with an optical audio port if you wanted a digital output going to your sound system (if it supports optical inputs).
Oct 10, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I've lost the function of my internal speakers after unplugging headphones. As others here have suggested. plugging them in and unplugging a few times has solved that issue for me. Right now, however, I'm...
Sounds like either your sound card has died, or Mac OS X cannot find it. I suggest taking it to the Genius Bar at your local Apple Retail Store, or try reinstalling Mac OS X with the DVD's that came with your MacBook Air.
Hope all goes well!
Mar 11, 2009 | Apple MacBook Air
Apple MacBook Air Logo
35 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
