Question about Toshiba Satellite A60 Notebook
GRRRRR... My modem decided to stop working.. tests ok but the port having issues ... I have been told get new INF modem driver updates ... how ... where ???
My modem port is not working ... how do i get new INF / modem driver updates
  • Toshiba Master
  • 32,281 Answers
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Posted on May 18, 2009
My dell latitude d600 usb ports stopped working how can i get it fixed. thans
If ALL the usb ports have stopped working, this is a problem with the USB controller. The short answer is that you cannot easily repair this. In all probability, the controller, or a circuit trace to it has blown or shorted. You would need to get another motherboard.
If one is still working, then you can get a PCIMCIA card to usb port that will give you 2-4 extra ports, but this will only work if at east one of your existing usb ports is still functioning
Aug 16, 2011 | Dell Latitude D610 Notebook
ONE OF MY USB PORTS STOPPED WORKING ON MY DELL LATITUDE D600 PC NOTEBOOK.
A shot in the dark here, but try this: Click Start>Run, type devmgmt.msc and press enter. Click the plus sign beside "Universal Serial Bus Controllers." Right click each listing that appears underneath "Universal Serial Bus Controllers" and click Uninstall. Click OK on the confirmation dialogs. After you get done uninstalling all of them, restart your computer and Windows should reinstall them. After it is done, try that USB port again.
Nov 11, 2009 | Dell Latitude D600 Notebook
CG814WGv4 cable modem from Optus Australia, all 4 ethernet ports not wokring since thunderstorm in January 2009, can ethernet ports be checked if they are still ok, can it be fixed by SW reload, purch
hi i had the same problem with an optus modem thunderstorm ruined my ethernet port. i had to replace the modem from optus and all it cost me was $40(put on my next bill) cheaper then buying another modem. i was told i couldnt buy a modem from another source because apparently they have unique codes on them...hmmm don't know about that, but thats what i was told.
hope this helps :)
May 10, 2009 | NetGear CG814M Wireless Cable Modem...
Dear Sir or Madam I have a TUSB3400 HUAWEI ETS2058/2258/2558 fixed wireless terminal and i also have a vista os with windows x64 system,now i cannot insyall the driver for this wireless modem please try to...
Go to Devive manager update device driver of the Modem and then creat new coonection , that's is .
(run)-->devmgmt.msc-->select modem-->r.click-->Update driver-->choose .inf file from ur modem driver folder.
Nov 22, 2008 | U.S. Robotics (USR5633A) Modem
Problem in canon
i found a solution for printing with Canon MF 3110
1- Download Driver For MF5730/5750/5770 For Vista 64-Bit
File Name : L7602ENx.exe
http://software.canon-europe.com/products/0010260.asp
Follow These Steps
1- Add Printer
2- add a local printer
3- Use an existing Port : Choose : USB ( Virtual Printer for USB )
4- Have Disk
5- Locate the File Name : MF5700AK.inf
6- Printer Name : Change From Canon MF5700 Series To Canon MF3110 Series
7- Print Test Page
it Work for me on Vista Home Premium SP1 64-Bit
P.s
still Cant Manage to use the Toolbox 4.9.1.1.mf04 for Scanning ( Any Ideas ? )
Oct 22, 2008 | Canon MF3110 All-In-One Laser Printer
Still my xbox live update test fails...
It is your modem, try switching out and see how that helps. Also sometimes the broadband won't work
Oct 21, 2008 | Netopia 3347W-KIT ADSL Wireless Gateway,...
Can I add a NIC card to my compaq presario pc sr5250nx? I keep loosing my internet connection every five minutes and have to reboot the computer to reconnect
you should be able to
http://h10032.www1.hp.com/ctg/Manual/c00840496.pdf
if your system is still within warranty I would think twice about opening the case yourself to installing a new network card.. you will be voiding your warranty.. so think about it
another thing i would try before deciding on going for another network card is to check your onboard network adapter has updated drivers... or you may want to reinstall the drivers for that adapter.. either one of those may probably fix your issue assuming is not a hardware failing given that your system may not be that old.... make sure you check the windows update and look for any new hardware driver for your network adapter that may be avaliable through windows update.
before you install your new network pci card you may have/want to disable the one on board going into your bios for that. so to ensure there's no resource conflicts when installing the driver for your new card (it may not be a problem even if you don't but if you run into problems while installing the new card consider this suggestion)
Oct 02, 2008 | Compaq Computers & Internet
DS_Dual4easy software for VISTA operating system?
1) Install the Konica Minolta XP software in Vista/Windows 7.
2) Plug in your DImage Scanner into a USB port and turn it on with the door closed. It will detect and install the original Konica Minolta Driver.
3) Create an empty folder on you harddrive (for instance go to my computer, double click on the c: drive, then right click and create a new folder named newminolta).
4) Open windows notepad and copy the following into it:
; scanners.inf -- Test Vista Minolta Film Drivers
; To remove this driver and install the original
; manufacturer's driver, go into Device Manager,
; open Imaging devices, then click on the scanner name
; with the right mouse button and choose Uninstall.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=3/12/2009,2.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB scanners
"Minolta Scan Dual II" = USBScanner,USBVid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USBVid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USBVid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USBVid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USBVid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USBVid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USBVid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USBVid_0638&Pid_0a16
;---------------- Duplicated from [Models]
[Models.ntamd64]
; USB scanners
;---------------- USBScanner -------------------------
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[Strings]
Provider="Konica Minolta"
Mfg="Konica Minolta"
5. Now save you new notepad file in the directory you created as newminolta.inf NOT as newminolta.inf.txt or newminolta.txt (i.e. c: newminolta newminolta.inf)
6. Go to system control panel (may have to change control panel to classic view to see system).
7. Select Device Manager
8. Select Imaging Devices
9. Right click on Minolta Scan Dual IV and click on driver tab. Select Update Driver.
10. Select Browse my computer for driver software.
11. Select Let me pick from a list of device drivers on my computer.
12. Select Have Disk
13. Browse to c: newminolta newminolta.inf and click OK
14. Click Next. Vista should now say it updated driver.
15. Run Dimage software with door closed. Wait for it to initialize and green light stops blinking.
16. Open door and insert film holder and start scanning.
Feb 10, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Konica Minolta Dimage Dual IV
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
; USB scanners
[Models.ntamd64]
; USB scanners
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
5. Now save you new notepad file in the directory you created as newminolta.inf NOT as newminolta.inf.txt or newminolta.txt (i.e. c: ewminolta ewminolta.inf)
13. Browse to c: ewminolta ewminolta.inf and click OK
Jan 12, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Toshiba Satellite A60 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
