Question about Quartet gbc 550S 71" 1:1 Projector Screen
Retractable ceiling mounted projection screen will not go back up
My image is upside down after I mounted my projector to the ceiling
There are projection mode settings which will allow you to adjust the orientation of the image. Adjusting this setting will rotate the image so that it is not displayed upside down when attaching the projector to the ceiling.
To activate this setting:
  1. Press the Menu button on the projector.
  2. Using the Arrow buttons, select the Image icon on the left side.
  3. On the Image screen under the Projection label, select the icon that represents ceiling mounted projection. Note: You may see both front and rear ceiling mounted projection modes. You may choose which ever best suits your needs.
  4. Press Menu on the projector controls to exit the settings menu.
Nov 19, 2011 | Office Equipment & Supplies
How do i reverse the upside down screen
You turn the unit upside down.
http://support.dell.com/support/edocs/acc/2300MP/en/usage.htm
Go to the menu.
Go to management.
Go to Projection Mode.
Front Projection-Desktop: If you want it to project right side up off a table.
Front Projection-Ceiling Mount: If you're hanging it off a ceiling.
Jun 24, 2011 | Dell 2300MP Multimedia Projector
I want to attach a Vivitek 650HD projector to a ceiling mount, but am not sure if I mount it upside down. There doesn't seem to be a "flip" function to flip the picture.
I am 99% sure most projectors are mounted upside down. There should be a way to simply flip the image electronically via the option menu.
In most projector OCD menu (keep in mind you may want to do this before mounting), under the "Installation" or "Initial Installation" section should be an option about Projection mode/method. The options should allow you to pick front, rear, ceiling, or ceiling+rear. This sets the project to know when it will be in front of the screen, behind it, and/or attached to the ceiling (which it knows will be upside down). Then you simply set it to ceiling, mount the projector, and finish your other adjustments as needed.
Apr 27, 2011 | Televison & Video
Upside down picture
turn the projector up the other way,
or
Press the Menu button.
Select the Advanced menu. You see the features and their settings on the right side:
Press Enter and use the directional buttons and the Enter button to set the following option:
Projection
Front: Projector is in front of the screen
Front/Ceiling: Projector is in front of the screen, mounted upside-down from the ceiling
Rear: Projector is behind the screen
Rear/Ceiling: Projector is behind the screen, mounted upside-down from the ceiling
Feb 22, 2011 | Epson EMP-54 Multimedia Projector
Turning it back to normal after ceiling mount for LP755
hi,
1. perss menu button
2. select controls
3. then select ceiling projecton (When you turn Ceiling Projection on, the projector turns the image upside down for ceiling-mounted projection. Highlight Ceiling Projection, then click either button to select turn this feature on and off.)
ok
Dec 21, 2010 | InFocus LP 755 Multimedia Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
How can i flip the screen up side down on the projecter
Or you can hold down the [A/V Mute] button for about 5 seconds to change the projection setup from Front to Front/ceiling or Rear to Rear/Ceiling.
Mar 31, 2010 | Epson EMP-S4 LCD Projector
I have a sony projector ceiling mounted, the image is projected
go into the menu and the image settings. there is a selection for front, rear, ceiling front, and ceiling rear. it might be sent to ceiling rear, so change it to ceiling front.
Dec 15, 2009 | InFocus In2102 Projector
CL-610 RUNCO PROJECTION SCREEN IS UPSIDE DOWN. Some one touched the remote control and I am at a loss to fix problem.
turn on your projector as usual, and using the remote, press the 'menu' button.
the menu will appear on the scree (albeit upside-down), and your looking for a setting like 'setup' or 'orientation'.
some runco's need a special code to get into some menus, but the orientation selection should be easy.
once you find the menu, there are usually 4 choices; front projection/floor mount, front projection/ceiling mount, rear projection/floor mount, and rear projection/ceiling mount.
the most common is 'front projection/ceiling mount'
Dec 08, 2008 | Televison & Video
Quartet gbc 550S 71" 1:1 Projector Screen Logo
29 people viewed this question
Top Quartet gbc Televison & Video Experts
Electro Med Services...
Are you a Quartet gbc Televison and Video Expert? Answer questions, earn points and help others
