Question about Kitchen Appliances - Others
Dalton 9p-052060 Need to reset
How do I reprogram a Wayne Dalton wireless keypad model 02-3039UH?
Usually by reading the instruction manual and doing what it says to do .at least it worked for my neighbor a few days ago .
Sep 07, 2015 | Wayne-Dalton Wayne Dalton 297138 or...
How do i reporgram a wayne dalton keypad
I would look into buying a liftmaster jack shaft its a much better unit but to get u buy just press the little red button on the opener type in your code
Feb 04, 2015 | Wayne Dalton Remotes Wayne Dalton 327308...
Timer seems to stick at 5pm? time on is 5-9p=all the buttons pushed down between 5-9p,correct?
Depending on model, time pins are either pushed in, pulled outward or slid away from the center of the time disc. Make sure that you have wired the power source and load to the proper terminals. There should always be power on the input terminals, and power on the output terminals only when the time corresponds to ON pins. Check this site for popular timer wiring diagrams.
I hope this helps & good luck!
Nov 28, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Need instruction manual for Wayne Dalton Chamberlin WD 220 grage door opener
The LiftMaster or Chamberlain web site has instruction manual downloads for all the models.
Jul 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
Don't have instructions for my wayne dalton door need spring instructions
Wayne- Dalton uses 4 different types of counter balance springs-extension, torsion, torquemaster 1, and torquemaster 2. I would need this information for a good answer. A photo would help a lot too. Thanks BB
May 16, 2010 | liftmaster Chamberlain Garage Door Opener...
Can i use the ''clicker'' model CLT1 with wayne dalton quantam 3316
It is compatible with Wayne Dalton opener manufactured between 1983 and 1987.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
RAD 9p shutting off Have checked all capacitors
Hi
The capacitors need to checked with an ESR meter. Althought capacitors sometimes bulge when they go bad this is not always true. Capacitors change value internally very easily when the conditions are right. High heat.
You can send this to my company for repair or if you need more help go ahead and email me.
Thanks
Jul 23, 2009 | Computers & Internet
RAD-9p shuts off for no reason
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 23, 2009 | KDS Radius RAD-9p 19" Flat Panel LCD...
7.3 international deisel smokes a lot...
Call "Duane" at the Dalton Bus Garage, Dalton, OH...you'll have to call the High School office (be NICE, he doesn't HAVE to answer your questions). No one knows more about this engine than Duane.
Good Luck
Sorry, you'll have to Google for the number
Jun 15, 2009 | 1988 Ford F 250
KDS Rad-9p wont stay on
my monitor will not work it will come on when the pc is cut on but it will not display
Aug 24, 2008 | KDS Radius RAD-9p 19" Flat Panel LCD...
Kitchen Appliances - Others Logo
106 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
