Question about Simplicity Sewing Machines
Simplicity SL4350D manual
Simplicity SL4350D Differential Feed manual
4 Suggested Answers
chrismyers67
  • 53 Answers
SOURCE: How do I operate the differential feed? I bought
The differential feed is usually on the right side, you will see a some numbers. Their should be one that sticks out (might be red, The letter "N", "0", or a line) This is the normal setting. A larger number is going to gather the fabric and a smaller (.99 and below) is going to stretch.
Hope that helps :)
Chris
Posted on Jun 06, 2010
SOURCE: i need to know how to oil a simplicity serger-easy
I have a Simplicity serger SL880 that was my mothers. She past away about 8 years ago. I was trying to use it but appears the motor may be locked up that moves the feed dogs. Is there a place to oil it? If so where? Thank you.
Posted on Aug 24, 2011
  • 6 Answers
SOURCE: Simplicity Easy Lock Serger 804DSP with Differential Feed Tention problems
Here is the manual! Copy the entire link! http://web.archive.org/web/20060508095821/http://www.simplicitysewing.com/ftp/whitepapers/804.pdf Enjoy!
Posted on Aug 04, 2012
Fabric not feeding on simplicity serge pro. Seems like the feed dogs are not high enough. I've changed the differential speed settings and the foot tension setting.
You mean after you change the setting and then it doesn't
pull any more.?
-If so the foot tension need to be re adjust. (More tight or loose)
-Here try this:
1. If thick fabric then need more tension.
2. If thin fabric then need less tension.
*After try the above if still not work then:
4. Lift the foot up and spin the machine by hands and observe the dog feed. It should swing pass above the surface about 1/32 (+/-)
-If it swing but stay below the surface then the
internal part that spin the dog feet is worn out.
Good luck
Mai
Feb 14, 2017 | Simplicity Sewing Machines
I need to know how to oil a simplicity serger-easy lock-with differential feed
Apr 18, 2011 | Simplicity Serge Pro SW432 Mechanical...
How to use the differential adjustment knob on the Juki MO-644D. Not seeing instruction in the manual
Found the manual here on features page http://jukihome.com/products/mo644d.html
Differntial feeding is covered on page 25, and the diagram showing location of the differential feed knob and stitch length knobs inside the cloth plate is on page 2.
So swing open the left cover (cloth plate) to access these controls.
Differential feed means you change the feeding speed of the two feed dogs so the front one feeds at a different speed to the back one. Effectively, this either streches the fabric as you seam, or pushes the fabric together as you seam. So if you want to do a rolled hem "lettuce" edge you are stretching the fabric with the differential feed to achieve this, turn the numbers up. If you are sewing a loose knit and it is "waving" then turn the diff feed down to 0.7 or so to squeeze the fabric back together.
That's basically it! Like anything on an overlocker, test sew, adjust, test sew, adjust until you are getting the right effect.
Feb 28, 2011 | Juki MO-644D Mechanical Sewing Machine
Hope that helps :)
Chris
Jun 06, 2010 | Sewing Machines
Can't get the material to feed automatically
The teeth on your feed may be clogged with lint... follow instructions in the manual to remove the cover and clean out the lint...has the machine been oiled??
Aug 04, 2009 | Simplicity Serge Pro SW432 Mechanical...
I have a simplicity creative plus sa 2200 and the fabric will not feed through machine under presser foot.it doesnt move grr!
You may want to make sure that your feed dogs are not in the lowered position. If they are in the lowered position, you'll want to raise them, and that should allow them to properly feed the material through.
Jan 03, 2009 | Simplicity Creative Spirti PLus SA2200...
Apr 22, 2008 | Simplicity Frontier SL390 Mechanical...
Sewing Machines Logo
174 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Greg Cann
Greg Cann
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
