Question about Nokia 3110 Cellular Phone
Receving data from bt device are not moving directly to sd card
I have a problem for my mobile nokia 3500c that is the mobile BT device not accepting the files if the memory is greater than 5mb.and recived files not moving directly to sd card so please solve my problem.
    Problem Solver:
  • 7 Answers
I think that you should move the files that were not directly moved in the sd card (move those files to the sd card)cuz that always happen to me...then i did not understand the first question.. were you talking about downloading files and then those files werent put in ur sd card...cuz i have a solution for that..
Posted on May 18, 2009
I cant save files direct to sd memory all data is going to phone memory direct..how to activate sd memory as my default memory in E5 nokia mobile?
1. To save files received from bluetooth on sd card: Open messaging. Go to settings. Scroll to the end and select other settings. Change the default memory to Memory card. It will ask to copy or move the messages and file from phone memory to sd card. Select move to memory card.
Now all files will go to sd memory card.
2. To save all applications to sd card, open ovi store, go to settings, change installation preference from phone memory to sd card
Jun 07, 2011 | Nokia E5 Cell Phone
How to download music from computer to cellphone?
There are 2 Methods
1 is via Bluetooth other option is using a USB data cable
via Bluetooth - Switch on BT on both PC and phone. - Click on BT icon in the phone and select send a file or you may send directly by selecting the file. - Accept the file receiving via phone.
Via USB cable
- Connect the cable. - Select Mass Storage from the phone , when prompted. - Copy files to the newly installed removable drive (Which is phone's memory)
Mar 07, 2011 | Nokia E63 Cell Phone
The Lowrance 3500C has a 1 GB capability. Does that mean I must purchase a 1 GB SD card for it? Can't find anything smaller than a 2 GB SD card, but will a 2 GB card cause problems?
No, this means the internal memory size is 1 GB. If this unit accepts SD cards, you can increase the map capacity. 2GB SD cards should work properly in the unit.
Nov 01, 2010 | Lowrance GlobalMap 3500C GPS Receiver
I am using my nokia 5130 xpress music in internet connection either with my data cable or through a bluetooth device.Will the action hamper my phone? plz clear my doubts.
NO. It is meant to be used. You are not doing anything that it is not meant to do. But, remember that if you use the BT connection then the phone may get hot and use up more battery. In the long run it may be harmful as the battery will wearout that much faster and the heat has always caused damage everywhere. So use the cable connection as long as you can. Bt is fine but the phone had to work double, by working the BT to work the GPRS. In case of cable it just has to concentrate on the GPRS.
Nov 27, 2009 | Nokia 5130 Cellular Phone
How can i connect my bluetooth to my pc?
on pc side
1. give your host bt name
2. find bt COM port
My Computer->My Bluetooth Places->right click my device->Local Services->Bluetooth Serial Port
on phone side
1. give your phone bt name
then install pc suite and modem tool (if necessary)
restart computer
pairing
1. add device
host: go to My Bluetooth Places->Add new connection
phone: go to bluetooth, choose Paired Devices->add
2. provide passkey (4-digit, 0-9 only) on both
Check mRouter
check bt COM port that you found
Start bt serial
if you see mRouter turns green and blue, you got it
start pc suite
Oct 19, 2009 | Nokia 5000 Cellular Phone
Aircel internet with Operamini
i have bought aircel internet and have been trying to access net thru operamini bt couldnt its shows error like "subscribe to pakcket data first"
i m from Mumbai and using Nokia 3110...plz help me
Oct 04, 2009 | Nokia 6233 Cellular Phone
2GB memory card problem
No dear .its nt japan .i have same 8GB pen driver but made in chaina befor am using it bt nt 8 GB 256 MB like that its show in 8 GB right? bt v cnt use 8 GB .try to contact kingston website if u have searial no may be they help u ..
Sep 13, 2009 | Kingston 2GB Secure Digital Memory Card
Didnt connect bluetooth headset to N73
Sometimes what happens is that we keep looking for BT devices without making them visible. Is it so in your case too? Go to settings of the headset and make it visible and your mobile visible to the headset. then you must pair them and also authorize them to connect without pass code etc. Then they will work.
Aug 02, 2009 | Nokia N73 Cellular Phone
Photos
If transferring via BT then try by switching off BT and again on.
On PC Exit the BT application and restart it.
If it doesn't work try through Card reader or Data Cable will finally do it for sure.
Jun 01, 2008 | Cell Phones
Problems with e800BT and com ports
I use an e830 with a Holux GR230 without having any problems. The e830 uses already the latest stack from Toshiba so no need to upgrade. For the e800, hm depends on what kind of BT SD card you use, meanwhile Toshiba sells the BT SD3 card. Anyway, I would recommend to use the latest BT stack from Toshiba for your Toshiba BT SD card.
Sep 08, 2005 | Toshiba e800 Pocket PC
Nokia 3110 Cellular Phone Logo
93 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
