Question about Sony VAIO GRV670 Notebook
Cpu fan malfunction
Hi guys,sure could use some help. my sony vaio pcg R505eL cpu fan seems to be malfunctioning(as it isnt running all the time anymore) i wanted to clean it up, but just couldnt find a way to take it out of the laptp, any ideas? i also wanted to put some oil on it(the reason why i really wanted to pry it out)
  • chrisrobin Jun 10, 2009
    thanks mr.BrokRench,
    i'll try the vacumm on it. but yeah i might be forced to buy a new set most likely, coz i tried to spin the fan manually & found out it's still pretty much mobile!(so i think, it might be busted up electrically)rather than it just being stuck by dust & dirt!bummer!
    thanks again,
    chris
    p.s. even when i'm using AC power it's still has the same problem:(
    President:
  • 1,623 Answers
Hello Chris....i highly recommend you dont "pry" on anything and it have it serviced by a qualified tech. The vaio incorporates the heatsink and fan as a unit, It's a 2 wire fan that is temp. controled from 5v and up. You can take a vacuum and place at the ventilation opening and remove some of the dirt & dust that has accumulated inside, this will help. The cost is around 100 buxs for a new fan & sink...Sony part # 1-763-483-12. Attached is a pic of the unit..; Also note: a depleted battery will effect fan operation as well.
Hope this helps and will fixya up....
Posted on May 18, 2009
Cant find drivers anywhere for Sony Vaio PCG-5A1M
http://www.downloadsarea.com/Free_sony-vaio-pcg-5a1m-drivers/
While I usually do driver downloads from CNet, this seems to be what you are looking for.
Apr 21, 2013 | Matsushita Sony Vaio PCG-5A1M 14.1in. SXGA...
Sony vaio pcg-71318L overheating
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Aug 30, 2012 | Sony Vaio PCG-71318L
How can i reboot my sony laptop tpye pcg-r505el
open command prompt and type shutdown then hit space button then -r then hit enter button your laptop will reboot
Feb 19, 2011 | Sony VAIO R505EL Notebook
Sony Vaio K33; the fan seems to run all of the time, hot and nois
i had the same problem with my vaio.
when disassembling the notebook: after you remove the metal cover under the keyboard, you'll see three areas covered with black thermal tape. peel back the thermal tape and you should see tightly packed dust buildups in those areas. use a q-tip and vacuum if you can or air duster. be sure to clean the fans as well as the heatsink assembly.
once that is done, your noise level should be reduced by about 60-70%.
if you're still running hot, consider cleaning the old thermal grease off your processor and reapplying a new layer.
Apr 01, 2010 | Sony VAIO PCG-K33 Notebook
LCD turns white.
probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver ic thus you could only see white display. A replacement of LCD panel is the best solution. best regards
May 16, 2009 | Sony VAIO PCG-R505 12.1 in. Flat Panel LCD...
My sony vaio vgn-ar61 does not detect the motion eye camera, when i go into device manager then into scanners and cameras there is only a xerox scanner being detected i have no idea were this has come from...
Hi axal49,
I seem to understand your problem. I have a Sony VAIO laptop and I might know how.... do you have VAIO Recovery Center on your PC? If you do then go to recovery center and find Reinstall Programs or Drivers.
If not then click here:
http://esupport.sony.com/perl/select-system.pl
May 13, 2009 | Sony VAIO PCG-TR3AP1 Notebook
Sony vaio pcg-r505el won't turn on
Vista or xp? I'm assuming Vista?
Apr 06, 2009 | Sony VAIO R505EL Notebook
Need to upgrade my vaio
hi there,
Sony PCG-GRS750 or PCG-GRS300 all go back to the sony ( PCG-8K1L )
Maximum CPU is Pentium 4 Processor 2.0GHz
Maximum memory is 512 DDR PC2700
Apr 09, 2008 | Computers & Internet
Sony VAIO GRV670 Notebook Logo
315 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
