Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Have arrived at my 81 year old mother's house in 106 degrees AND I CANNOT GET THE DIGITAL THERMOSTAT to TURN ON THE AIR and FAN. HELP!
  • 2 more comments
  • nancygrah67 May 18, 2009
     Honeywell THermostat (did check circuit breakers). I press SELECT, press arrow for lower temp, and Press hold.  (At bottom I switched to Fan On and to Cool).
    Doesn't appear to be batteries.
    P.s no wi fi at her place. my cell is 310 9519191 if anyone wants to call with help (its too Hoooottt! to sleep.
    Thanks
    Air has not been in use for some time (nor heat)
  • Wayne Holden May 11, 2010
    Let's back up a step. Does anything work? Fan to on and what happens? Neither heat nor air has been used for some time so there is the possiblity that something has chewed the wiring up or built nests in places that stop things from working. Dirt daubbers are bad, mice eat everything, ant's love to live in contactors and switches. You may have multiple problems due to lack of use. Would call but will wait till daylight as most of the things you are going to have to check will require some light adn I'm sure you don't want to be fighting wasp and/or ants in the dark!
    Check the breakers, don't forget that the outside unit may have a safety plug or a breaker box or switchbox of it's own out side.
    Did you just switch from heating or has the ac been in use for a while?
    President:
  • 3,433 Answers
Slide switch to cool and press doen button to lower the temp to desired temp. Check thermostat to see if it needs batteries by snapping front cover off. Good Luck
Posted on May 18, 2009
  • Ned C Cook
    Ned C Cook May 18, 2009
    slide switch to cool and press doen button to lower the temp to desired temp. Check thermostat to see if it needs batteries by snapping front cover off. Good Luck
  • Ned C Cook
    Nancy:
    How did it go last night? Did the temp pull down as we had hoped? I wanted togive you this bit of information concerning the thermostat controls. Let's see if I can do this without confusing us both.
    The one that is of greatest concern is the select button. Use of the select button allows you to scroll through 3 diferent time periods. When you come to the time period you want, using the arrows, set the temp where you prefer. then press set. Do this with each time period. If you want to maintain a constant tenp, like 74,then all time periods need to be set accordingly. Try not to keep the temp down too long or all day. The desert is comfortable between 2 and 6 am so 34 should be just about right for keeping the house cool andcutting 4 hours off of the daily run time.The hold button is to hold the temp at the current temperature until it changes at a preset. or you release it to current preset.
    If I can (If) I can do any more for you, feel free to call. You know where to find me.- NC
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
The fan on one my central heating and air unit won't come on? It was working fine when I went to bed at 1:30 in the morning and when I got up around 7:30 this morning it wasn't running anymore.My house has...
Running the equipment on 72 degrees would cause the compressor and fan to work harder on hot days. This will definitely place more strain on your capacitor. These capacitor problems usually happen on the hottest days. I would suspect the capacitor, not the fan. I'm an HVAC tech, so I would Check both with my multimeter
Aug 25, 2013 | Heating & Cooling
Unit three years old. came home yesterday and
Check your circuit breaker for the outdoor unit,seperate from the furnace.
Sep 09, 2009 | Ruud Heating & Cooling
3 year old Lennox system stops intermittently 2-3times past 24hrs
i would have the thermostat receiving 24 volts all the time by running the c terminal from the air handler to the thermostat and go from there
Jun 21, 2009 | Honeywell Heating & Cooling
Goodman a/c works, heater will work fine then fan will stop
you have a circuit board acting up. Try keeping the fan in the "On" position. It will keep the blower on all the time but it may work. There is a built-in delay not allowing the unit to come on after you reset it with the thermostat, wait three minutes or so to see if it comes back on. I still suspect a bad circuit board.
Nov 21, 2008 | Goodman GMS90703BXA Heater
Air conditioner not working
This is simple , turn your thermostat to fan only and not auto fan and see if it runs, if does then run it like this till a service man arrive, the fan motor for cool is gone out!
Sep 08, 2008 | Heating & Cooling
Inside house is warm
Use the spell check and please restate your issue. Have you checked your air filter? Has the unit been serviced recently?
Sep 04, 2008 | Carrier 38CKC036 Air Conditioner
Inside fan runs constantly on my AC
Raise your thermosat to about 78. Also check to make sure the thermostat is set to auto and not on...
Jun 12, 2008 | Whirlwind FH-778 Air Conditioner
Heating & Cooling Logo
190 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
