Question about Watches
Set watch ry2220 confetti - Watches
How to set time on a Lorus watch Z001 X001
Digital
Press the button on the bottom left-hand side of the watch to change between the modes on the watch.
Press and hold the button on the bottom left-hand side of the watch for two seconds until the seconds begin to flash.
Press the button on the top right-hand side of the watch to set the seconds to "00" and press again to set.
Press the button on the top right-hand side of the watch again until the hours flash. Press the button on the bottom right-hand side of the watch to change the hour display. Press the button on the top right-hand side of the watch to set.
Repeat step 4 to set the year, month and day on the watch.
Analog
Pull the small knob on the right-hand side of the watch, also known as the crown, out one click.
Turn the crown until the previous day's date is displayed.
Pull the crown out one more click. Turn until five minutes ahead of the correct time and then turn back to the correct time.
Push the crown back to the side of the watch. The watch is now set.
Mar 31, 2018 | Lorus Watches
I have a digital wrist watch and I can not set it up.
hi Claude.
Press and hold the "Adjust" button to until the "Time" digits begin to flash. Use the "Start/Stop" and "Split/Reset" buttons to set your digital watch to the correct hour and minute increments. Press "Mode" to display the "Date" setting screen.31 Mar 2015
Digital Watch Instructions ' Techwalla.com
https://www.techwalla.com/articles/digital-watch-instructions
How do u set a digital watch?In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.4 Button Digital Watch - Dakota Watchhttps://www.dakotawatch.com/PDF_FILES/Digital.pdfSearch for: How do u set a digital watch?
how to set digital wrist watch Google Search
Nov 27, 2017 | Watches
How to set digital part of the watch
[PDF]4 Button Digital Watch - Dakota Watch
how to set time in digital watch - YouTube
? 1:13
https://www.youtube.com/watch?v=4FmHYMeXbDA
Oct 26, 2011 - Uploaded by Vedant Sen
https://www.youtube.com/watch?v=u_H5I3H15R8 ... how to setyour digital watch {UPDATED} - Duration: 1:20. by Vedant Sen 3,424 views ... The 10 Greatest Wrist Watches of all Time REVISED FOR 2014 - Part 1 - Duration: ...
How To Change The Time On Most Digital Watches - YouTube
? 8:40
https://www.youtube.com/watch?v=kBvaePDtEUU
Jun 27, 2012 - Uploaded by Pitskate
How To Change The Time On Most Digital Watches. Pitskate ...How to change / set time on Armitron watch, 45/7004. - Duration: 2:02. by ...
Jan 05, 2016 | Watches
How do I set the time on my pasnew watch
Dealextreme - PASNEW Sport Waterproof Quartz Analog ...
? 6:32
https://www.youtube.com/watch?v=7D6i4d-1NYQ
Oct 25, 2011 - Uploaded by TheTemplegeek
... PU watchband - Dual time display: analog and digital - Features timer, ... PASNEW Sport Waterproof Quartz ...
How to set watch model WR30M - YouTube
? 3:02
https://www.youtube.com/watch?v=VGRAb0aF2lQ
Apr 29, 2015 - Uploaded by TheUltimate
11:24. How to Set a Timex Ironman Triathlon Watch - Duration: 1:15. by Inside Endurance Sports 2,441 views ...
Dec 15, 2015 | Watches
How to set pocket watch
Hi John, There are several possiblitites depending on the watch you have. If it is a battery watch you set it like most modern watches by pulling the pendant and the hands should move. If it is a vintage watch it may set the same way. If gentle pulling the crown does not work try this. Your watch may be a lever set watch. This requires removing the crystal of your watch will be screwed on. If it doesn't loosen easily try putting the watch between your palms and twist. Once the crystal and bezel loosen remove it and set it aside. Now look near the 2 o'clock position. A lever set watch will have a small metal piece sticking up that is designed to be hooked with your fingernail and pulled out. When in the out position your watch will now be in the setting position and your hands will move when you rotate the crown. After setting push the lever back in and you will now be in the winding position. Replace the crystal and carefully screw it down but not too tightly. There are other systems but I am guessing this will cover your watch. Merry Christmas
Dec 18, 2011 | Orvis 82KG6000
We bought a sportline solar watch that has a light mode and rerset and st/stp function mode we want to set the time but don't know how? Help please
mcdevito75 here, I see in your question, SOLAR if that means the watch is operated from the sun"s energy, you first have to get the watch going (ticking) before you can set the time, Instead of a Battery your watch has a capacitor that holds onto the sun"s energy and releases it, makeing the watch go (tick). After the watch goes, you need worry about 2 buttons, MODE & SET. Press MODE and see display Flashing, now press set to set each function, (hour, minute etc.) presss MODE after ecah function is set to move on, once all functions are set, press MODE for steady display, also if thew watch is new, look for a small piece of plastic just under the crown, remove that plastic and push crown down to start watch. Hope this helps.
Jul 04, 2010 | Watches
Instuctions on how to set my mio watch
here is the mio watch instruction site you should be able to find your watch instruction there good luck to you
http://miowatch.com/node/80
Jun 18, 2009 | Bulova Watch
Setting a Casio Wave Captor watch after battery change
If the watch is running try to sync the watch 1st, meaning set the minute and hour hands pointing to 12:00 o'clock. before you go to set the time.
May 22, 2009 | Casio WVQ600DCA Wave Ceptor Watch
Timex Watch
While the time is displaying on watch press & hold the set/indiglo or top left button on watch. The seconds should start to flash.
Press the mode or bottom left button until the hour digits start to flash.
Press top right or start/stop button to advance the hour. Then press top left or set/indiglo button to exit set mode.
Mar 09, 2008 | Timex Ironman 30 Lap 53952 Wrist Watch
Watches Logo
15 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
