Question about National Little Tikes Hummer Yellow
I removed the screw so the hummer could go in gear 2 and now it doesn't reverse or drive in gear 1, tried to adjust it and now it doesnt move at all would could be the problem?
  • Anonymous May 19, 2009
    I REMOVED THE SCREW SO THE HUMMER COULD GO IN SECOND GEAR AND NOW IT DOES NOT WANT TO GO IN REVERSE OR FIRST GEAR ANYMORE
  • Anonymous May 21, 2009
    Little Tikes Hummer. 1st AND REVERSE GEAR DOES NOT WORK. 2ND GEAR ok.
  • 3 Answers
It sounds like the 1/2 switch. There are 2 switches in the lever one is 1 and 2 forward control and the other switch is forward and reverse switch. I was running into the same thing with my sons and when I switched the 1 and 2 to 2 and then flipped the reverse the reverse and high gear works. The site referenced above has the switch for sale $16.95 plus shipping.
Posted on Jun 06, 2009
    Habit-Forming:
  • 156 Answers
I had the same problem with my hummer, so I ended up replaceing the wiring harness.
I was able to find it at this website:
http://www.shopjandl.com/kids---baby-ride-on-toys-little-tikes.html
I would email them about the part because they may have a few more questions to make sure you get the right parts.
Hope this helps.
Posted on May 18, 2009
I have a 99 dodge dakota v6 when im driving in 2
Put truck in reverse and zig zag backwards turning truck left and right will take it out of four wheel when stuck.
Aug 30, 2014 | 1999 Dodge Dakota
Reverse gear not working on my ford explorer 2003
PROBLEM WITH TRANSMISSION. Check the ATF level. if low add fluid. if fluid level ok, then repair the transmission
Mar 11, 2014 | Cars & Trucks
My ford bronco doesnt move idles great gears go in but wont movee is it the clutch or the fluids
For this car, it can be really pricy or you can take my advise. I would recommend that you remove the 1 or 2 screws located on the reverse side of the shifter!. once you do this, you basically deactivate a safety device that is preventing you from shifting your car into gear! The safety device basically will not allow you to shift until you press firmly on the breaks and the key is installed. TAKE IT FROM AN EXPERT who has been there done that hundreds of times. you can find the screws on the reverse side of the shifter, just feel for them with your fingers.
Jan 26, 2011 | 1984 Ford Bronco II
Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener: my garage door unit acts like the gear is stripped...
DOES IT MOVE AT ALL OR JUST RUN??
IS THE ROPE RELEASE PULLED??
IF THE GEARS ARE STRIPPED IT WILL NORMALLY MAKE A GRAVELLY SOUND. AND THE DOOR WILL MOVE BUT NOT LIKE IT SHOUL.
TRY DISCONNECTING THE DOOR FROM THE OPENER & SEE IF THE TRAVELER MOVES NORMALLY.
May 17, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
1997 Dodge Caravan Sport. I was driving normal then it quit pulling. Now have 3 forward gears no more than 8 miles an hour. No reverse. Dropped trans pan small metal on magnet.Fluid looked ok. Changed...
The correct fluid to put in a 1997 van is (ATF-3). Sounds like you need to make adjustment on both the forward and reverse bands of the transmission to correct your problem. The kickdown band (front) forward is located at the top (outside) of the transaxle near the front. To adjust the band,loosen the lock nut approximately 5 turns. With the lock nut loose the adjusting screw should turn freely in case. Tighten the adjustment screw with an inch lb. torque wrench to 72 in-lbs. Then back the screw out 2 1/4 turns, hold the screw in place and tighten the lock nut to 35 ft-lbs. Then after removeing the transmission pan and filter the low-reverse band is located next to the valve body. Loosen the lock nut 5 turns so the adjustment screw is free. Turn the adjustment screw in to 41 in-lbs, then back the screw out 3 1/2 turns. Hold the adjustment screw and tighten the lock nut 10 ft-lbs. Install transmission pan/with gasket and refill transaxle to proper level. Test drive van. Be safe and block the rear wheels before you raise the van and try to work under it. Hope this will help you.
May 19, 2010 | 1997 Dodge Caravan
Gear problem
If you hear the motors turning, remove the seat and check to see if the motors are securely tightened to the transmissions. They are easily tightened, if loose but the transmissions must be removed to gain access to the screws. The hardest part of the job may be the removal of the 'press nut' that holds on the wheel. The wires to the motors will also need to be cut. Please be very careIful not to break off the contacts at the motor. They are soldered on and cannot be pulled off so don't try. That's why the wires need to be cut. If the motors are tight then open one of the transmissions. One of the 3 gears in the reduction gearset may have seen its axle break out of the bosses. This happened to me. The gear was fine. The axle is 7/16th' diameter. Buy a 2 1/2 inch long shoulder bolt where the shoulder is 2 inches long and the last half inch is thread. Drill a 7/16 hold through the cases from inside out using the center of the broken bosses as a guide, reassemble the cases using the bolt as the new axle for the gear. Tighten securely but not overtight. I used modest amount of locktite to prevent loosening. Now all runs like new. $3.16 for bolt, nut, washers. I also found replacement trans on Ebay for $44 plus ship. Your choice.
Aug 26, 2009 | National Little Tikes Hummer Yellow
Craftsman GDO, Model 139.53600. moves 4inches up/ down
Find the increase travel adjustment screw and turn it clockwise 1/4 to 1/2 turn.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keys stuck ignition of my H2
I finished my H2 key issue today. Here is what I had to do; You will need a flat head screw driver, a phillips head screw driver, a 2"round mirror, the smallest 6 point star alternate head screw driver, wire strippers, a 20x power magnifying glass or eyepiece a head mounted flashlight.
1. Disassemble the inner tray under the arm rest
2. remove the arm rest itself.
3. Using the 1/8" 6 point screw driver or bit remove the shift lever handle, turn the ignition on so you can put the lever in 2nd for easier access to the locking screw on the front side of the shift handle.
4. Use the flat head screw drive to pry up the cup holder and gear select console up.
5.Move the gear select handle (now a black 1/4" dia plastic rod w/a yellow 1" long spout at the top)
using your 2" mirror locate the connector at the bottom of the gear select handle under the main console. On the aft side of the handle, is a tab to remove the connector.
6. Using the flathead screw driver depress the tab and pull the connector out.
You will see 1 red wire, 1 black wire, one green wire, and a green and yellow wire, in the same outlet T
he yellow wire is the key/ignition wire. Mine was completely severed I had to use my 20x eyepiece to see how to properly splice it, and using the wire strippers remove the cheap insulation which easily cracks causing the yellow wire to crack, due to the poor engineering and material selection of the insulation. Once I removed the shielding and spliced it, I had to use the eyepiece to see the connector to put back the wires that also broke while I was trying to remove the connector. I then had to spice and reinsert all the wires one at a time into their respective slots. Remove these wires one by one so as not to get them mixed up. Reverse the original disassembly steps and you will have a once again working system. This took me about 2 hours working in the H2. It's easy to do, I am not mechanically inclined and have never done this before but my key comes out of the ignition and everything works fine. In spite of the cheap materials used by GM;'s lowest bidders. For the record I am a Italialn/German sports car driver, this H2 is one of the neatest vehicles we have ever owned. High gas prices low fuel economy don't mean diddly when your driving through a mud slide, snow storm, or rain storm, with 2' deep road puddles, or 3' foot high snow drifts while going up hill on a winding road. Never mind the naysayer and haters the way things are going Hummers are going to be the way to get where you need to get.
Dec 12, 2008 | 2003 Hummer H2
Drive limits on my chamberlain wont register
Have NO IDEA what you are saying. Do you mean you adjust limits and chain moves too far? Or is chain not moving. Bad gears. Toss unit unless you are handy and can rebuild gears.
Sep 04, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
National Little Tikes Hummer Yellow Logo
401 people viewed this question
Top National Toys Experts
romney2012
Joseph Hoffmann
Adam Fjeld
Adam Fjeld
Are you a National Toy Expert? Answer questions, earn points and help others
