Question about Canon imageCLASS MF8050Cn Multifunction Printer With Copy/Fax/Print/Scan
I get a message when printing on a Canon ImageCLASS 8050cn printer: No destinations have been added to the [Destination List]. ??? How do I set up a destination list?
I have installed the print drivers for printing and scanning . Did not get any errors on installing. Tried to print and get this error.
5 Suggested Answers
SOURCE: Scanner won't scan when activate the SCAN button
i need softwear
Posted on Dec 25, 2008
Gort007
  • 1187 Answers
SOURCE: A window appears saying
Your hard drive may be getting full...
Or the account (user name) you are using on the computer does not have enough "rights" to create the output file.
Assuming it is Drive C:
Open [My Computer]
Right-click Drive C: (one time)
and select "Properties"
In the [General] tab, locate and click on [Disk Cleanup]
The system will harmlessly "scan" your hard drive to try to free up space. It is not deleting or compressing anything.
When the scan is complete, a list will appear, place a check on:
Tempoary files, Temporary Internet Files,
(do not "compress" any files)
and click [OK]
Try your scan again.
This is a temporary fix. You need more hard disk space.
Posted on Sep 28, 2009
  • 70 Answers
SOURCE: Canon MP250 printer scanner in a canning mode
Go to Device Manager at USB Controllers and disable Standard Enhaced PCI to USB Host Controller. If you can't find exactly this, disable the one with the word Enhaced in it. Right click it then click disable.
Posted on Nov 29, 2009
muntejaya
  • 10421 Answers
SOURCE: Scanner driver not installed is the error message.
Hi, please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay klacrw
Posted on Feb 12, 2011
Not receiving faxes
please replace with new original cartridge to solve this problem.
Aug 28, 2014 | Canon ImageClass MF-8050CN Multifunction...
My F4240 will print and copy but wont scan
Hi
I am providing you steps for Windows XP if your O.S is other then please reply.
Solution ;
Try copying if copying is fine then Scan through WIA.
If the scanning is successful, proceed with step 3. If scanning was not successful then I request you to perform the step given in step 4 and then perform step 3.
Step 3: Manually check for DIM
The digital imaging monitor must be running for the scan to function to work. The digital imaging monitor normally appears in the system tray in the bottom right-hand corner of the computer screen, next to the time.
If the digital imaging monitor appears in the system tray, go to the section Populate Destination List.
NOTE: If hpqtra08 is not on the list in the Startup tab, this indicates that the driver was not correctly installed. Uninstall and reinstall the driver.
9. Populate the Destination List with following steps:
a. Open the HP Solution Center.
b. Click on Settings --> Scan Settings --> Button Settings.
c. In the window opened, select "Scan to button" tab
d. Click the Destination List tab.
e. Click on each of the programs you want to appear in the scan to list.
f. Click the Add button. This moves the selected programs to the Front Panel Destination List.
g. Click OK.
h. Now try the scan to function from the all-in-one.
To save the above changes I request you to perform steps given below as Dest test.
1. Close all applications including HP Solution Center.
2. Open and run the DESTTEST file from the location:
C:\Programfiles\hp\digitalimaging\bin\Under Destination:
a. (Optional) Set the Category for the Destination List scroll
down menu on WEB_APP.
2. On the 5th option "Close Dest Test After sending to Destination", put a check mark and click on Save Results Before Exit.
3. Click on Exit in the bottom.
4. Now Open the HP Solution center, Click on Settings -> Scan Settings & Preferences -> Scan To Setup.
5. You will see all Button settings on the right side under the front panel destination List. In Case If not, click on Restore Defaults, click on Apply and click on Ok.
6. Push Scan To button on the unit you will see all the Destination List on the unit. Select the appropriate one.
Oct 03, 2009 | HP OfficeJet 6210 All-In-One InkJet...
My canon MP150 disply E14 & do not prints or scan please help
Did you install the driver? and the scan software? is the printer giving out any errors? please check the canon bci24
Aug 29, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Problems with HP Photosmart C6280 All-in-one Printer
Populate the destination list You must populate the destination list in HP Solution Center for the Scan To function to work. Follow these steps to populate the destination list.
NOTE: HP Solution Center is the software that came with the product. You must make sure the software is installed on the computer for all the product functions to work correctly. The software is also necessary for completing this procedure. Install HP Solution Center if it is not already installed.
  1. On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center . HP Solution Center opens.
  2. Click Scan Settings .
  3. Click Scan to... Setup .
    NOTE: It might take several minutes for the list to populate. If the appropriate programs are already listed as scan destinations, discontinue this procedure. You must reinstall the software.
  4. Click each program to include on the Scan To Destination list. Figure 2: Add destinations c01404190.gif
  5. Click the Add arrow. The program listing moves from the left side of the screen to the right.
  6. Click OK .
Jun 23, 2009 | HP Photosmart C6280 Printer
Tx image set not to display
getfile.asp?rid=1258 September 11, 2008
getfile.asp?rid=3215 Product : imagePRESS C1, All Fax Capable imageRUNNER Models Title : Setting the TX Terminal ID print options Question :
What are the options to print the TX Terminal ID on received pages?
Answer :
The TX Terminal ID settings enables you to specify whether the sender information is printed at the top of every document that you send via i-fax. Information such as your i-fax address is printed, enabling the recipient to know who sent the document.
Note: If you set TX Terminal ID to 'On' you can also set the position of the Terminal ID information which is printed on the recipient's paper.
The default settings are:
TX Terminal ID: On
Printing Position: Outside
Display Destination Name: On
1) Press Additional Functions
2) Communications Settings
3) TX Settings under Common Settings.
4) Press the up or down arrow keys until you see TX Terminal ID
5) Select On or Off
If you select ON:
Select the printing position of the Terminal ID information, select 'On' or 'Off' for display Destination name, press OK.
Printing Position:
Inside: The Terminal ID information is printed inside the image area on the recipient's paper.
Outside: The Terminal ID information is printed outside the image area on the recipient's paper.
On: The destination's name registered in the Address Book is displayed in the Terminal ID information.
Off: The destination's name registered in the Address Book is not displayed in the Terminal ID information.
If you select OFF
Press OK
6) Press Done repeatedly until the Send Basic features screen appears.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
May 05, 2009 | Canon imageRUNNER C3200 Copier
SCANNER SAYING NO USER ID
This means that you have not set up any users in the address book in the printer.
Copy is simple, it will scan the document and print out a copy of the scanned image.
Scan however, is trying to make and store an image file of the scan, but it needs to know WHERE you want to scan it to. The printer does not know where to send the stored image unless you create a storage location for it. This is done with the address book that is stored on the printer.
The material below is how to set up the scanner settings of the printer.
Printer Settings Utility Using the Printer Settings Utility window, you can set up the fax system data options, and create and edit Phonebook entries from your computer. You can also configure the destination launches when you access Scan and then PC.
When you install the Dell software, the Printer Settings Utility is automatically installed.
For information about installing the software, see "Installing Software in Windows".
To open the Printer Settings Utility:
  1. Click Start software25.jpg Programs software25.jpg DELL software25.jpg DELL Printers software25.jpg DELL Laser MFP 1815 software25.jpg Printer Settings Utility.
The Printer Settings Utility window opens.
  1. The Printer Settings Utility window provides several features; Directory (Phone Book, Address Book), Fax Setting (Fax Cover Sheet), and Scan (Destination, Resolution, Scan Color, Show Preview).
The Scan Section The Destination Section To configure the operator panel display scan destination list that appears when you access Scan and then PC, click Destination and the Setting button. Using the destination list, you can select a software program that an image can be scanned to.
Oct 07, 2008 | Dell 1815dn All-In-One Laser Printer
Scan troubleshoot
Hello Kamaleddin_e , this no scan option issue occurs when you try to scan from the printer. It usually means , you need to set the destination file type, which is currently not populated (destination file type is the file type to which you want to save the file which you are scanning. If the device finds the list is empty (list of associated file types) , then it displays the "No scan options" error on the printer.
You can populate the destination list by following these steps.
1. Open the HP Solution Center
2. Navigate to Scan Picture Settings (or Scan Settings)
3. Select "Scan to Button" tab
4. Select destination list tab. (Note: If the appropriate programs are already listed as scan destinations, discontinue this procedure. The software must be reinstalled.)
5. There will be 2 colums visible, the left column is the scan destination list on the computer and the right one is for the scan destination list on the printer.
Click each program to include on the Scan To list. Click the Add arrow. The program listing moves from the left side of the screen to the right. Click OK.
6. Now try scanning again from the front panel.
(Note: Please make sure that the HP Digital Imaging Monitor is also running as it is required for the HP software to function properly. You can find it as an icon in the system tray. If there is no icon, then you can run the application by navigating to C:\Program Files\HP\Digital Imaging\Bin\HPQTRA08.exe (Assuming C: as your system drive)
Mostly, the issue will be resolved at this stage or else you need to uninstall the software and reinstall it again.
all the best.
thx
Sep 30, 2008 | HP Photosmart 3310 Printer
I cant scan, but I can print?
hi,
I understand that your mean issue is that "you cant scan", however, for me to assist you better, I just want to know how did you scan? and what did you use? there are actually two ways on how to scan. Also, what is the operating system of your computer?
1. Scanning using the buttom from the printer.
2. Scanning using the SOlution Center installed on your computer.
Meanwhile, ill just post a troubleshooting steps inorder for you to follow.
SOLUTION: SCANNING FROM THE PRINTER BUTTON.
Intro:
Scanning using the printer button without adding the destination list would somehow give you error message "NO SCAN OPTIONS", inorder to resolve that issue,copy and paste this link to the address bar. (note: just go directly to SOLUTION II (Populate Destination List) using that document.)
For windows Vista:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01391654&cc=us&lc=en&dlc=en&product=1153481
For windows XP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01388134&cc=us&lc=en&dlc=en&product=1153481
Those are the link that normally we followed. It helps a lot, you can jump directly to SOLUTION II (Populate Destination List), make sure that all the options are already added to your control panel printer list.
Please let me know if the document failed to resolve your issue so that i can go ahead and give you another solution.
Thank you so much.
adonscott
HP TECH
Jul 04, 2008 | HP Photosmart C5180 All-In-One InkJet...
Can not scan to computer
hi,
below are the steps that i want you to follow. The "NO SCAN OPTIONS" refer to the absence of options when you try to scan using the printer button your printer. However, if you are going to scan from the SOlution center installed in your computer, it will scan without any problem.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
  1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
    • On the Windows desktop, double-click the HP Solution Center icon.
    • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
    If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab.
    NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
  6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  7. Click each program to include on the Scan To list.
  8. Click the Add arrow.
  9. Click OK .
  10. Scan a document using the Scan To button on the front panel.
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, please let me know.
Thank you so much.
adonscott
Jun 02, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Canon imageCLASS MF8050Cn Multifunction Printer With Copy/Fax/Print/Scan Logo
963 people viewed this question
old marine
old marine
