Question about Grohe Ladylux Cafe Faucet with PullOut Spray in Stainless Steel 33755KD0
I have a Grohe ladylux single handle faucet. It's beginning to leak on top the counter. I removed the hex screw holding the lever/hanlde in place. But I can't get the handle off. Any suggestions on how to do this? Thanks.
  • 2692 Answers
SOURCE: Grohe ladylux faucet loose on counter.
Here is the manufactures web where you may request the information you desire concerning your faucet.
http://www.groheamerica.com/s/25_4060/page/modules/iframe/index.php?if_url=http://12.130.64.173/litrequest2.htm
Posted on Dec 10, 2008
  • 659 Answers
SOURCE: trying to remove handles on grohe 31054000
I couldn't find the number you have on the Grohe website so I have included a link to their website. Just find your model and it will give you many different options for manuals. Hopefully this will give you the information you are needing.
http://www.grohecatalog.com/category/1/
Posted on Apr 12, 2009
  • 35 Answers
SOURCE: Grohe ladylux plus kitchen faucet leaks from
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Posted on Feb 23, 2010
jyackle5
  • 8197 Answers
SOURCE: The Grohe Ladylux kitchen faucet was mounted
May I get the model # to help.
Posted on Apr 05, 2010
heatman101
  • 43501 Answers
SOURCE: I've removed the screw but can't get the handle
many times the handles will corrode on tightly....
A sharp rap from a rubber mallet will sometimes work, but most of the time you will ruin the faucet when getting the handle off...
heatman101
Posted on Jul 12, 2010
I want rotate my Grohe ladylux kitchen faucet. The handle is on the left and I want to rotate to the right side. How do I do it? Thank you John
You will presumably be pushing the faucet handle away from you instead of pulling it forward? If you don't like it, you can always put it back.
Turn off the water.
Release the water in the faucet. If you have a faucet in a room on a floor below, open that to drain the water.
From underneath the unit, back off the nut that is gripping the worktop. Slacken off the hot and cold supply pipes. I am hoping you have braided flexible hoses, or you can't do this job very easily.
Spin the faucet 180'.
Retighten the hold and cold supply pipes.
Retighten the holding nut.
Turn on the water and open the faucet.
Check for leaks.
There is an installation video here.
https://www.youtube.com/watch?v=sQgi0CMAxYM
and some further information and diagrams here.
Removing Grohe LadyLux Caf 33 755 Faucet Handle
Jan 02, 2016 | Grohe Plumbing
I've removed the screw but can't get the handle off my Grohe Ladylux single handle faucet.
heatman101
Jul 09, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
I have a Grohe Ladylux plus kitchen faucet very similar to this one, when I turn the water on there is a slight clunk and the water flow decreases. I am assuming I need a new valve but I havent' been able...
Before you start taking the whole faucet apart try taking the airiator or head of the end of the faucet. It may just be some sediment blocking the filter screen on the head. Unscrew the head and see if the water flows with the head off.
Jun 12, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
May 22, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Need technical diagram of single hole faucet
Not sure where to find the diagram, but what type of faucet is it and where is it leaking? It it's a single lever, remove the hot/cold indicator to uncover an allen set screw. Loosen it and remove the lever, then the outer bushing nut. Now you'll have access to the interior parts around the cartridge (make sure you turn the water off to the supply lines before proceeding further). If it's the two handle type, remove the index buttons from the top of each handle to uncover a screw with either a slotted or phillips head. Remove the screws and remove the handles. You now have access to the valves and seats. If it's a 12-year-old faucet, the o-rings and seats will probably need to be replaced and this will fix your problem. If it's a single lever type, you'll need to replace the seats and springs and it will probably solve the problem.
Jun 14, 2009 | Grohe 40367000 Chrome Accessories Single...
Grohe ladylux plus is leaking
I believe there is a cartrige that has some washers in the unit. There may be some debris caught in there since it was a little loose. I would turn the water off and disassymble the unit and replace any obvious washers and clean everthing up. Replace it all and try it again. If it still leaks, contact Grohe for more trouble shooting. Faucets have fantastic warranties and companies usually will send replacement parts free of charge at times. Hope this helps.
Apr 06, 2009 | Grohe Model 28 206 OOO: Ladylux Plus...
All of a sudden can not get hot water from my Grohe Ladylux plus
I aasume this is single handle
You will need to remove the handle(usually hex screw under lever or bak side covered with small erasure size button
turn water (hot and cold) off under sink
remove the handle
take an adjustible wrench and remove the cartridge it is keyed
so ou can put it back roperly inspect the cartridge for any obstructions
go under sink and slowly turn hot water on and observe if water is coming out of faucet manifold
if water is coming out ok you may have a bad cartridge or had a blockage reinstall cartridge(after youturned water off
turn hot and cold water on under sink and try again
if it works great if not I suggest you take artridge out and replace
Dec 29, 2008 | Plumbing
Dec 10, 2008 | Grohe Plumbing
Grohe Ladylux Cafe Faucet with PullOut Spray in Stainless Steel 33755KD0 Logo
54 people viewed this question
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
