Question about 1998-2002 Park Avenue Door Lock & Alarm Interface
How do you disable the security system for a 2000 park avenue?
2 Suggested Answers
Ironfist109
  • 3018 Answers
SOURCE: need information on how to disable security on
  • Locate the harness in the drivers side door. You need to locate the green wire and you need to splice into that wire and run a wire from there to a ground. You don't want to cut the green wire, just splice into it.
  • Hope this helps and thank you for using FixYA.
Regards, Tony
Posted on Jun 17, 2011
Can I disable the PK3 security on a 2001 Buick Park Ave?
easier to fix. have codes read ecm/bcm and security. should lead you to failed component
Dec 17, 2013 | 2001 Buick Park Avenue
My 1996 buick park avenue will not start sometimes but if i wait for the security light to go off it will start . how do i disable the security system so that the car will crank at all times. will...
The security light is a visual indication that something in the car's antitheft system is failing. In most GM cars and trucks there is a hidden system that most people are unaware even exists. From the moment you put your key in the ignition, there begins a constant line of communication between your key's security chip or transponder, to the ignition's lock cylinder, and then to the car's TDM (Theft Deterrent Module). These 3 parts are in CONSTANT communication. If the key is in the ignition, then these parts are sending signals to each other. The security light illuminates when that signal gets broken, even just for a second. When the signal breaks, the car misinterperates this as an attempt at theft and goes into antitheft mode. The car thinks its being stolen or hotwired because it is not getting that signal from YOUR specific key. This is why the security light turns on and shuts down your vehicle. Remember too, the TDM controls the security light. Sometimes you can have ALL the symptoms and no lights.
This link may help you.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jul 30, 2012 | 1996 Buick Park Avenue
Need information on how to disable security on 1995 buick park avenue
Regards, Tony
Jun 17, 2011 | 1998-2002 Park Avenue Door Lock & Alarm...
I need to disable the alarm on my 1998 buick park avenue
The factory disarm wire for this vehicle is in the driver's door. It is light green, located at the module above the speaker and you can test it by turning the key in the driver's door. It will switch to ground when unlocking the door with the key.
Feb 24, 2011 | 1998-2002 Park Avenue Door Lock & Alarm...
How can i find the security codes my buick park
You will find a great write up on this website:http://newrockies.ca . That was the only way I saved my 94 Park Avenue that has the exact same system.
Oct 30, 2009 | 1995 Buick Park Avenue
I have a 2000 chevy 1500 and the security light is on
Looks like the TDM in the security system (VATS/PassKey) is having problems, it can get worse till the car wont start anymore. You can find a great write-up here: http://newrockies.ca , it was the only thing that saved my Park Avenue.
Sep 15, 2009 | 2000 Chevrolet Silverado 1500
1991 buick park ave. security system set off,
Did you try the drivers door lock cylinder?
Jul 19, 2009 | 1991 Buick Park Avenue
Security system
If your car has a chip in the key, then this is the definitive solution: http://newrockies.com/vatsbypass . It was the only thing that saved my Park Avenue.
Feb 10, 2009 | 1997 Oldsmobile LSS
Buick Park Avenue Security System
I've got my own one stuck for weeks and this was the only thing that brought it to life again : http://newrockies.ca/vatsbypass
Jan 01, 2009 | 1992 Buick Park Avenue
I need to disable or reset the factory security system
get a bypass system. I got one at bakerelectronix.com turned the light off
Jul 15, 2008 | 2006 Buick Park Avenue
1998-2002  Park Avenue Door Lock & Alarm Interface Logo
Top Buick Vehicle Parts & Accessories Experts
Marc Taylor
Thomas Perkins
Thomas Perkins
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Buick Vehicle Part and Accessory Expert? Answer questions, earn points and help others
