Question about Wahl Health & Beauty
Wahl 8081 Circuit board
4 Suggested Answers
SOURCE: how to reassemble my wahl clipper model 8081
Okay, if you took this machine apart don't worry. You would have noticed when you loosened the first two screws closest to the blade (but still on the body of the trimmer) a small white part of the trimmer flew out...you were probably think wtf? Yeah, okay. If you took all four screws out, make sure you align the cord within its allocated space on the frame and screw in the bottom two.
1. Now, leave the top two screws about 75% loose so that you can slip the white piece back.
2. You will notice that there are two prongs sticking out of the hole where the blade is suppose to go. Make sure the "Detailer" enscribed on the front of the trimmer is facing the ground (or opposite yourself). Align the white piece so that the groves are facing the prongs and the other half of the white piece is facing yourself.
3. Slide the white piece down as far as reasonable, without forcing it. There is a little hook on the white piece, and a corresponding groove on the casing of the Detailer. Make sure that you align the white part so that the hook aligns with the groove, also make sure that you have aligned the groove on the back side of the white piece with the small round tip of the motor.
4. Okay, so this is the tricky part, you will probably be saying...the white piece is still sticking out. Well this is initally why it flew off when you took the machine apart. The blade acts a spring load for the white piece and the top two screws on the casing holds the remaing pressure forced on the white piece. What you need to do now is align the blade and its screws with the corresponding holes on the maroone casing and push the front of the blade down on the white piece and tighten the screws. The machine should now be working.
Hope this helps.
Posted on Dec 04, 2009
  • 10865 Answers
SOURCE: broken plastic housing wahl model 8081
Hello. Here is the link to the company http://consumer.wahl.com/service.cfm
Joe
Posted on Mar 24, 2010
SOURCE: I want to replace the upper and lower blades on my
what kind of blades to u buy for a wahl 8081
Posted on Sep 18, 2011
I'm going to Italy. Is it dual voltage?
Italy uses 220 volts, 50 cycles alternating current (AC). If your appliance works on both 110 or 220 then IT'S dual voltage and should work. If it only runs on 110 then you will need a voltage converter to use it on 220.
Dec 03, 2015 | Wahl 8081
Battery will not hold charge on my wahl lithium ion trimmer. Model 9854L. Do I need to replace battery? If so, how do I do that? Have trimmer for about 3 years
The battery may only be supplied with the charging circuit attached, best check with your local Wahl service agent. Lithium batteries are not generally sold to the public as they are dangerous (explosive) if charged incorrectly.
Oct 11, 2013 | Wahl Health & Beauty
Need to assemble
i need help in the wahl detailer 5 star the back piece broke where the scrues go so i need a new one some one know were to buy the back piece
Nov 04, 2012 | Wahl 8081
How to put my wahl 5 star detailer back together
my back piece where the scruess atach broke help please where can i buy a new back piece
Sep 26, 2012 | Wahl 8081
I want to replace the upper and lower blades on my wahl 8081.
Jun 21, 2010 | Wahl 8081
How to reassemble my wahl clipper model 8081
Hope this helps.
Oct 18, 2009 | Wahl 8081
Replacing Nicad battery in Wahl trimmer #8787
Contact Wahl customer service and ask them for help. they will be able to talk to you about the exact model you are dealing with.
Oct 11, 2017 | Wahl Health & Beauty
Wahl 5000 mens shaver
I had the same problem. All the lights were lit but the shaver would not work even when plugged into an AC outlet. I took it to Mar-Beck Appliances in Independence MO and they said that it needed a new circuit board and the total cost of the repair would be $59.90.
Apr 01, 2008 | Wahl 5000 Custom Shave System Electric...
Health & Beauty Logo
75 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
