Question about Sony Cyber-shot DSC-HX1 Digital Camera
Sony camera DSC-HX1 taking blurry pictures
Changed and charged battery but it focuses on center and blurs out around the edges
SOURCE: trouble with sony cyber-shot DSC-T33
try cleaning the lens first.
when taking the picture press down lightly so it will focus. Then press harder for the picture.
Posted on Aug 10, 2008
SOURCE: E:61:10
It seems to be a mechanical problem that can be fixed by placing a bit of pressure on key points. Here is the fix that I did that seems to have worked fine...
open the battery cover
take the battery out
take the memory stick out (inside the battery case)
leave the battery cover open
carefully remove the 7 small silver screws (put them in a cup so you don't lose them!!)
slightly pry the front cover away from the camera starting at the bottom
wedge something in the side to 'pop' out the top retaining tabs towards the top
the front cover should now pop off the camra
Make small paper spacer #1:
Cut the adhesive strip off of a post it note.
Fold it over again about 5 times so that it has some thickness to it.
Approx final dimensions are 1/8in x 1/4in x 1/32in(??) thick
Stick it in the upper right corner of the black plastic lense housing.
See photos attached.
(There is a nice flat rectangle at that spot about the same dims.
This spacer should fit neatly right over that space.)
Make small paper spacer #2:
Approx final dimensions are 1/4in x 1/4in x 1/32in(??) thick
Stick it in the bottom left corner of the black plastic lense housing.
(There is a nice flat rectangle at that spot, but you want the spacer
to be a bit bigger so that it covers the vertical line in the plastic.)
Put the front cover back on the camera.
Make sure it is mechanically secure, but don't install the screws yet.
Put in the battery and memory stick.
Try it. You may have to play with the spacer thickness to get it to work.
Once it is working well again, then put the screws permanently back in.
Posted on Aug 26, 2008
welcomejee
  • 10594 Answers
SOURCE: Viewfinder of Sony DSC-H2 does not work anymore
Viewfinder has focus lever at bottom, please adjust viewfinder internal focus as per your eye sight looking on-screen display. Every thing will be fine after that.
Posted on Feb 04, 2009
welcomejee
  • 10594 Answers
SOURCE: sony cyber-shot dsc-w200 taking blurry pictures in auto mode...
Its due to slow shutter speed setting.
If you want to take moving object picture, set high speed shutter, there would an icon of golf stick that is for moving object pictures.
Posted on Mar 23, 2009
  • 586 Answers
SOURCE: sony dsc t300 e 61:10
   The detail of fault is given below,
Self-diagnosis Code   Symptom/State
E 61:10         Zoom operations fault
               (Cannot initialize zoom lens.)
Correction :
Retry turn the power on by the power switch. Check the zoom
reset sensor of lens block (pin 9 of CN402 on the SY-191
board), if zooming is performed when the zoom button is
operated. If it is OK, check the zoom motor drive IC (IC401 on
the SY-191 board).
According to the symptom the possible fault is described above, You have to contact any nearest SONY SERVICE CENTRE to rectify the problem.
 Thanks for using fixya.
Posted on May 31, 2009
Blurry picture grainy and some greenish color around edges this camera was given to me and the pictures that were already on it look great but when I take new pictures I gthankset these problems
There may be the issue with the CCD (image sensor device) of the Camera.
Refer this article to confirm this.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Check whether the LCD screen of the Camera looks similar as given on the page.
Ifyes,click on the "Yes" button at the end of the page to create anonline Repair Request for sending the Camera to the Sony FactoryService Center.
Aug 19, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony Cyber-shot DSC- W55 takes blurry pictures
Hi!
The focus doesn't move as it should - it was stuck before you tapped it. Could be sand or something in it. I'm afraid you will have to give it away for a repair. You can contact your local Sony service center, but if they ask too much, I can offer you a very good price. My e-mail is toms.safranovs@gmail.com
I work in a Sony service center.
Hope this helps!
Tom
Jul 31, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cyber-shot dsc-w200 taking blurry pictures in auto mode...
Mar 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Blurring pictures
I had the same problem. Somehow my flash was set on "SL - Keep subjects and distant backgrounds bright." When I changed the flash to "Auto", it seemed to get rid of the blurry pictures.
Dec 08, 2008 | Sony Cyber-shot DSC-W90 Digital Camera
Pictures are blurred around the edges
Have you tried to change the settings like to scenery or adjusted for lighting that could have an effect. The only time it's blurry for me is when I don't adjust for the picture I am taking. The camera itself focuses so maybe there hasn't been enough time for it to focus. Try those things and if it doesn't work I would take it in to a camera shop maybe it has internal problems.
Sep 27, 2008 | Nikon Coolpix S51c Digital Camera
Blurred pictures
Check that the auto focus and auto exposure is turned on. Check that the camera is not in the macro mode for normal picture taking.
It is possible that there is a defect that is not allowing proper focus. In this case your camera will require service.
Jerry G.
May 05, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
DSC-W1 Focus Problems
Try taking some flash pictures (in fairly good light) in Manual Mode @ 1/500sec to rule that out though. Use "Center" or "Spot" autofocus. If you don't have a tripod, then use the self timer for these tests. If camera shake can be ruled out, and the camera has focusing problems even in bright light, then that unit is trashed. Sorry to hear that the Sony service center couldn't fix it right the first time. Demand a replacement.
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
DSC-T7 Blurriness
Try this test: Mount the camera on a tripod or set it on a secure base and use the self timer to trip the shutter. Doing this will totally eliminate any possibility of camera shake causing blurriness. If the picture is still blurred then there might be a problem with the AF but if it isn't blurred then the problem is either camera shake OR subject movement (or both).
Sep 12, 2005 | Sony DSC-T7 Digital Camera
DSC-T7 : Blurred images ?
I don't own a T7,but I have the P150 and S40. All these small Sony digicams have something in common;Sony uses 1/40 as the default flash shutter speed in low light conditions,while other makers use 1/60.You are more likely to get a blurry picture compared to other digicams you have previously used,unless you hold the camera steady (two hands). The other thing about these cameras is their lack of weight, coming in at a mere 134 g/4.7 oz. Light weight means you must hold the camera steady (two hands) or risk camera movement when you press the shutter. Again, the tendency with a small,light weight camera is to hold it with one hand while you take a picture,this leads to blurry pictures. The review for this camera is positive; a "Dave's Pick." - Just remember the flash range is only 5ft / 1.6m. http://www.imaging-resource.com/PRODS/T7/T7A.HTM
Sony Cyber-shot DSC-HX1 Digital Camera Logo
65 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
