Question about Samsung Refrigerators
Samsung rf263beaesr leaks
About every 10 days, we find water on the floor (on right side only). No ice build-up inside frig, though.
catriver
  • 878 Answers
SOURCE: water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Posted on Dec 22, 2006
Sea Breeze
  • 4654 Answers
SOURCE: Ice build up on bottom of freezer. Water leaks out.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
Posted on May 21, 2009
  • 44 Answers
SOURCE: 10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Posted on Jun 10, 2009
woodchuck789
  • 4070 Answers
SOURCE: GE side by side leaks water from icemaker tube
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 17, 2009
  • 358 Answers
SOURCE: Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Posted on Sep 28, 2009
How can i turn off the water function on the door but not the ice, the water line keeps leaking on the back of the frig
When I had this problem the water was coming from the top right rear where the water tube feeds the ice maker. The water line INSIDE the frig that feeds the ice maker occasionally freezes up causing an obstruction which causes the water to leak out the rear. This can only happen when the icemaker activates the water feed. You can remove the tube fitting without fear because the valve that feeds water through the line is at the bottom rear of the unit. If the line is frozen inside I remove the ice bin and tray and use a hair dryer to melt the ice.
I have a similar problem with the condenser fan making a tapping/clacking noise which is also a result of ice building up on that. Wish I had a different frig but for now the hair dryer will have to do.
Feb 06, 2012 | LG LSC26905TT Side by Side Refrigerator
Water leaking from inside the freezer
if the bottome of the freezer floor is frozen then the most common cause is that the defrost drain is cloged, the back wall will mostlikley need to be removed and defrosted, then i use hot water & a long zip tie to make sure the drain is clear, don't use anything too hard as to punch a hole in a drain hose.
May 24, 2010 | Samsung RS2630SH Side by Side Refrigerator
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Ice builds up inside the freezer every few days at bottom
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Sep 30, 2009 | Maytag MZD2768G Side by Side Refrigerator
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Leaking water
test: first, turn off water supply to frig. then dry up all water. then ensure frig is running at right temperature. now gradually turn on water and observe where leak is. My guess is it is overflowing the ice-maker. there is an adjustment for this. pop off the cover over the end of the ice-maker. look for a screw adjustment. turn it counterclockwise.
Jun 04, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Refrigerators Logo
73 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
