Question about Toshiba RDXV60KB DVD HDD VHS Recorder
Does the hard disc drive on the Toshiba RDXV60KB need de-fragmenting at some point?
On my PC I de-fragment the hard drive on a regular basis so that the free and recorded areas are consolidated. Do I need to do this for the HDD on the Toshiba RDXV60KB?
4 Suggested Answers
SOURCE: Toshiba RDXV59DTKB2 HDD/DVD/VCR recorder.
Ok, this is happening due to the fact that the CODEC FORMAT you recorded in doesn't exist on the player you wish to play it on.. you MUST ensure you encode the DVD in a CODEC that every machine will have... When you Burn a DVD the information is Encoded, with a CODEC, the SAME CODEC is required to Play it back, if the Player doesn't have the particular CODEC as standard, then it simply is unable to play the DVD. Look on the DVD Player and check out what CODECs it can handle, then encode your DVD Burns using that CODEC, and you will be able to play it on any compatible player, Usual formats are MPG4, VOB, DiVx,
have a look below to understand what you need to do.
http://www.webopedia.com/quick_ref/Video_Codecs.asp
Posted on Nov 11, 2010
SOURCE: i have a toshiba rdxv60kb dvd recorder,,and can;t
I have a toshiba Hdd & DVD / Video Recorder However I can not get it to work with my Sky setr up If I set thimer recording it does not work when I turn it on it will only work pn channels that are not from sky it will not instant record nor will it record programmes prerecoreded of sky HDD it will record everthing other than what I want.
My E-Mail Addres Is fj.gadkey_1@sky .com
My Home hone is uk 01527 545284
Posted on Mar 15, 2011
ercupa190
  • 12223 Answers
SOURCE: How do I record from my sky box onto disc
go and download the instr.manual to www.fitness.manualsonline.com or www.retrevo.com or manualsfactory.com
God bless you
Posted on Jul 21, 2012
RUNNING SLOWLY
Hi Anon depending on which operating system you are using there are various things you can do to speed up your PC, if you are using Windows 8 or 8.1 then press and hold down the Windows key and press Q, in the search box that appears type PC settings, click on PC settings and then select Update and Recovery, from the list that appears select Recovery and then choose one of the recovery options, "Refresh your PC without affecting your files" is probably the best choice. If you are not using Windows 8 or 8.1 you might get a simple speed boost by de-fragmenting your hard drive, if you are using a SSD solid state hard drive then it will not be necessary to de-fragment it.
If you are using an earlier version of Windows then the System restore tool can be used to revert your PC to an earlier point in time, when it ran more quickly.
Aug 11, 2014 | Computers & Internet
Computer slow
De fragment your hard drive and run a disk cleanup.
Jan 03, 2012 | Toshiba Computers & Internet
On my desktop ,after booting my gadgets doesn't display ,and my system is alwayz slow,please i need solution,even my battery,when you plug in the adapter it would say not charging 12% plug in,and my...
With the battery running that low and not accepting anything you will need to consider buying a new charger, as for the system is running slow try un-installing all un-wanted programmes from your computer as this is taking up space and processing power, run a De fragmentation on your hard drive which can me done by double clicking on your My computer then Right click your C Drive and going to properties then click on de fragment with will speed up your system a bit, delete all un-wanted films, pictures and music will also speed up your system
Jun 27, 2011 | HP Pavilion dv6000t Notebook
I have a toshiba satellite 1130 and know nothing about it at all. I lost power then the computer turned back on and said that there was a problem with the hard drive that needs to be fixed???? Do not know...
Resetting a computer's hard drive requires running a de-fragment program, which scans the entire hard drive and cleans up files to make it run more efficiently
Jun 20, 2011 | Toshiba Computers & Internet
Running slow
THERE MAY BE 2 REASONS.
1)FRAGMENTED FILES :
TO DE FRAGMENT THE DRIVES OR FILES -RIGHT CLICK ON MY COMPUTER -->SELECT MANAGE-->AND EXPAND THE STORAGE OPTION IN LIST(CLICK ON + SYMBOL OF STORAGE)
CLICK ON DISK DE FRAGMENTER -->SELECT ONE DRIVE DRIVE--->CLICK ON DE FRAGMENT TAB-->IT STARTS DE FRAGMENTING .IT TAKES SOME TIME TO DE FRAGMENT .AFTER DETRAGMENTING ONE DRIVE ,DE FRAGMENT THE OTHER DRIVES AND CLOSE IT.
2)DOUBLE CLICK ON MY COMPUTER---> SELECT C:\ DRIVE OR THE DRIVE WHICH CONTAINS YOUR OPERATING SYSTEM-->SELECT WINDOWS (IF THERE ARE NO FOLDERS CLICK ON SHOW ALL HIDDEN FILES )FOLDER OPEN THE TEMP FOLDER & Prefetch AND DELETE ALL IT'S CONTENTS.
PLEASE GIVE VOTINGS TO IMPROVE MY PROBLEM SOLVING SKILLS
Feb 18, 2011 | HP Computers & Internet
Computer very slow, motherboard M7VIG400 and processor VIA VT8235
If your computer is very slow then first of all try troubleshooting it from the first.
Computer gets slow due to many reasons , such as Viruses,Mal ware,Trojans and many more.Also the speed of your processor plays an important role
So first of all scan your system with good and updated anti viruses.
After that if system is slow then try De fragmenting your system. When you open "My Computer" "Right click" any drive and click "Properties"
Select "Tools" tab from above. Click on "De fragment now" and click "De fragment" This will arrange the files properly on your system and give a boost to your system. Try De fragmenting all drives.
After the above steps you are not satisfied then Remove unnecessary installed programs form your computer.You can do this from the control panel in that select "Add remove programs" and remove unwanted programs.
After this all steps your system is slow then you have to change your Processor or replace the mother board this will surely improve your system's speed
Hope the above information will be helpful to you.
Thank you for using Fixya
Nov 12, 2010 | Biostar M7VIG400 Motherboard
Will not load games
First of all get a good Antivirus software and scan your PC thoroughly after UPDATING it. Updating the Virus software is extremely important.
Secondly after doing the above step install a Registry cleaning software. I recommend Uniblue Registry booster or Regcure. Virus and unclean registry are number 1 reasons to PC slow down.
Check your hard disk if it is near to full. Use the Windows built in disk cleaning software to clean unnecessary files. After that De-fragmenting the disk will also help a lot. To de-fragment a disk Go to accessories in the start menu and then go to system tools. Find disk de-fragmentation and run it the PC performance will dramatically enhance but Virus and registry cleaning is recommended to be done first.
Jul 26, 2010 | HP Computers & Internet
I got my dell dimension e521 used, when i download software to the computer it goes to the e:/ drive instead of the c:/ drive. The computer is running slow because of lack of drive space. How do i correct...
you must erase some data on the disc if you don't want to lose all because if it goes like this you will get your hard disc crashed and you will lose all important data. run disc fragment and scan disc regularly.if problem persist rather use an external hard disc for quick,safe and easy transfer
Jun 23, 2010 | Dell Dimension E521 PC Desktop
Not much memory left in my powerbook
De-fragmentation does nothing to free up space. It only moves files that have been fragmented across scattered sectors into a file running across contiguous sectors. This speeds up disk read operations and is less stress/wear on the hard drive. To free up space... continue what you're doing. Move all non-essential files to an external drive and uninstall any programs that you don't really need.
If this answers your question and provides a solution to your problem then please take a moment to rate this post. - Thanks.
Jul 01, 2009 | Apple Mac OS X 10.4 Tiger for Mac
My hard disc is in problem
You need to connect the disk to another system boot and first take a backup of your data , try De fragmenting.
Dec 17, 2008 | Computers & Internet
Toshiba RDXV60KB DVD HDD VHS Recorder Logo
44 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
