Question about Fujitsu P50XHA10 50 in. Plasma Television
Hi, my name is scott and i have a 42" plasma fujitsu the model with no speakers its a little old but just recently ive been turning on my tv and the red led light blinks while tv is powered on and i keep getting 2 flashing codes in the upper left hand corner of the screen the codes are 410501001000 and 410501280609. I could really use your help! Thank You Very Much Sincerly Yours, Scott
    Brigadier General:
  • 8,619 Answers
Hi Scott
Thanks for using FixYa. The first thing you can do is to reset the TV by leaving it unplugged for 24hrs. If this does not resolve your problem then look for capacitors that have a bubbled or slightly raised and rounded top. This indicates the capacitors have overheated or leaked and need to be replaced. You can also try to remove the connectors from the Power Supply board one at a time and see if anything changes .
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 18, 2009
Fujitsu P42HHA30ES Plasma TV screen has stopped displaying
It sounds as though you have a fault on the Power supply, the fan doesn't not normally fail on this model. If you'd like your screen repaired, please call 0208 731 3432
Jul 11, 2010 | Fujitsu P42HHA30ES (Bundle) 42 in....
I have a Fujitsu 42'' PDS4221 - 10 years old - shuts itself off
See Fixya tips and tricks:-
'Fujitsu Plasma 42" random shutdown - continuous flashing red'
While the model of your set is slightly different, the checks described generally still apply, as it is very similar.
Nov 18, 2009 | Cars & Trucks
42 Fujitsu PDS4221W-H, no power
A user manual is available from this link:-
http://safemanuals.com/user-guide-instructions-owner-manual/FUJITSU/PLASMAVISION%20PDS4221-_E
Check for a hidden power switch under the lower left or right under corner of the screen, ensure it is ON (- not sure if this switch is fitted to your model, but it does exist on other Fujitsu models).
Fujitsu no longer support or manufacture plasma screen TVs - therefore no parts are available from them. [Fujitsu only serviced to board replacement level - very expensive].
The Fujitsu models (generally, after 4 or more years use) suffer from cracked solder joints on circuit boards (due thermal cycling stress).
See Fixya tips:-
"Fujitsu Plasma 42" random shutdown - continuous flashing red led".
Oct 28, 2009 | Fujitsu Plasmavision 42" TV
42" Fujitsu Plasma TV (About 10 yrs old)
You have not fully identified the model number of your unit, but
this is most likely caused by the Main Power pcb.
For models P42HHxxxxx and P42HCxxxxx see Fujitsu Service Bulletin on this problem. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
Sep 29, 2008 | Fujitsu Plasmavision 42" TV
Fujitsu plasma went blank
Need to have the power supply checked by a qualified technician.
Feb 12, 2008 | Fujitsu Plasmavision 42" TV
Fujitsu 42" Plasma Display shuts off after 20 minutes
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
Oct 21, 2007 | Fujitsu Plasmavision PDS-4233 42 in....
Fujitsu P50XHA10 50 in. Plasma Television Logo
101 people viewed this question
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
