Question about GE 31GT740 31" TV
TV turns on and changes channels on its own
TV turns on by itself and you'll walk into that room  to find it on.  It also changes channels on its own while you're watching and you can't get back to the one you were watching
  • frogman1 Dec 27, 2007
    Changes channel and will not hold channel. It has also turned on by itself. Turned TV off for 12 hrs. This kept the channel stable for about 30 min.
  • Anonymous Sep 16, 2008
    TV turns on and changes channels on its own. Will not hold a channel and also the remote does not work anymore and it will not turn off without being unplugged.
    Novelist:
    Champion:
  • 244 Answers
Keeps changing channel
Check voltage on D12 if below 4.8V then change
Changes channel or volume adjusts by itself
Check S900/1/2 on pcb H1, alternatively this could be due to failure of IC005 (CD4052BCM-FL63) on pcb A
Posted on Nov 24, 2007
Take back off tv then remove motherboard then remove channel/volume board remove push button which is causing problem,in my case it was the channel up button,just remove with soldering gun.Good luck
Posted on Nov 17, 2008
Magnavox TV turns itself on and changes channels
channel + or - switch is stucked in,,or broken plastic stucked in ,watch thorougly
Dec 14, 2015 | Televison & Video
Sony bravia tv constantly changing channels
Is the tv new or has it started to do this recently ?
Try to eliminate the obvious.
Does the remote continue to flash when you release all of the buttons? Is it a stuck button ?
If you cant' see the remote output, try using your smartphone camera. Most phone cameras will capture infrared light ( invisible to the eye). Aim the remote at the camera and see if you can see the flashing light, which is data being sent to the tv. When you release the buttons does the flashing stop ? If so remote is ok
Next turn all of the lights off in the room with the tv. Also turn off any lights that may shine in from other rooms. Try using the remote
If your tv functions normally, you may be getting interference from your lighting. Some LED and CFC fluorescent lights flicker at a rate which may be close to the remote IR output frequency.
If turning off the lights fixes the issue, turn on each light to isolate the issue. Replace the bulbs with ones from different manufacturers.
Let me know
Oct 24, 2017 | Sony Bravia KDL-26V4000 26 in. HDTV-Ready...
My hotel changed TV, I bought the Philip 30HF9975/12Z , but what we got is just the screen. Please help me what I need to get to get it working.
I'll assume that you work in a hotel. Do you guys feed a cable signal as is straight to each guest room or do you have you own system (i.e. separate receivers for each channel that are then combined into one trunk)? Do you guys offer a movie purchase option or allow guest to checkout through the TV? What system you guys use would determine what you'll need aside from the screen itself. These things should've been worked out before investing so much money on new TVs.
Jul 18, 2011 | Televison & Video
I have a small magnavox HDTV. I unplugged it to watch it in another room. The next day when I moved it back into the living room I turned it on. Every time I try changing the channel it changes the source...
Is it a multi-function remote? If it is, make sure you've punched the TV button before using it. Also, make sure none of the buttons on the remote or the TV have accidentally been pushed down and are stuck.
Jul 05, 2011 | Philips Televison & Video
Other room remote changes channels on BOTH TVs
turn off the uhf from you reciver in main menu set up funcion remoto control
Apr 07, 2010 | Toys
I have a Toshiba Projection Television 61A61 that I cannot change the contrast once on sports. When I do change it, it automatically goes to preference and I also have these almost double type on the...
Hi
Thanks for using FixYa. The TV will automatically turn itself off after approximately 15minutes if it is tuned to a vacant channel or a station that completes its broadcast for the day. This feature does not work in VIDEO mode. If the power is cut off while you are viewing the TV, the last mode memory feature will turn the TV on automatically when the power is re supplied. If the power is going to be off for a long time or you are going to be away from your TV, unplug the power cord to prevent the TV from turning on in your absence. You’ll also need to check the swollen/bulged capacitors on the power supply board inside the TV. The TV itself turned it off in the case of any bad capacitors or overheating with the help of built-in sensors. You’ll need to replace the swollen/bulged capacitors. Please also check the power from and to the TV.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 11, 2009 | Toshiba Televison & Video
When my sharp lc 32sb220u is turned on, my direct tv remote will not change channels. this just started. Nothig was changed. after this, i did change the direct tv box and it still would not change...
That remote has to work / it is a direct tv issue since it is their equipment that you are renting and it is supposed to work with your set..
Did you make sure that the batteries in the remote are good? that the remote unit itself is good ( Use digital camera or am radio to test out - see google)
Sep 20, 2017 | Sharp Televison & Video
AOC Plasma TV turns on by itself and changes channels non stop.
I have an AOC 32" LCD HDTV and it turns on by itself as well. Tuning is done via my cable box, so the tv is set on HDMI and I don't have the channel changing issue. I as well am trying to figure it out. The only thing I could suggest is perhaps the remote batteries are low and triggering on it's own. Try changing the batteries, or ensure that the remove it in a drawer or other room so that triggering the unit is impossible. Hope that helps.
Jun 17, 2009 | AOC A42HD84 42 in. Plasma HDTV
Screen is black but sound works
possible lamp is burned out,look in your manual for info.
Jun 26, 2008 | Samsung DLP HL-P5663W 56" TV
TV won't come on!
your system control section has failed due to sudden power failure. 1please check power to system cotrol. 2check tunning &aft ckt in system. 3check memory ic & its section 4check system ic & its section regards
Sep 12, 2007 | RCA F32650 32" TV
GE 31GT740 31" TV Logo
1,102 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
