Question about Exerpeutic LX9 Super High Capacity Training Cycle
Exerpeutic lx 9 has a loud clanking sound almost like the chain is about to fall off
Strange clanking, rattling sound while idle seems to be coming from the drivers side 2000 Chrysler T&C lx 3.3l V6
drivers side
well it can be ignored
start with anything driven by the serp belt
a tensioner bearing or idler bearing is a probable cause of the noise
how do you see anything in that engine bay
May 30, 2016 | Chrysler Cars & Trucks
I have a clanking noise at speeds above 30 mph..
Check brake pads to see if they are loose.
Oct 12, 2014 | Motorcycles
Loud Clank when shifting VT1100C2 Shadow Sabre 2007
Hi, Eric I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Rear Chains---RATTLE
5. Cam Chains---CLICKIT
6. Clutches---CHATTER
7. Cylinders---PING
8. Fairing Panels---WHISTLE
9. Fronk Forks---Plunk
10. Gears---WHINE
11. Head Gasket---HISS
12. Hydraulic Lifters---TAP
13. Pistons---SLAP
14. Radiators---GURGLE
15. Rear Chains---RATTLE
16. Rear Shocks---SQUEAK
17. Shaft Drives---WHIRR
18. Shifting Trans---CLUNK
19. Solid Lifters---TICK
20. Starters---CLICK
21. Connecting Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2007 Shadow Spirit 1100 clunks when shifting
http://www.vtxcafe.com/archive/index.php/t-62963.html
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
May 24, 2012 | 2005 Honda VT 1100 C2 Shadow Sabre
Air conditioner has loud hollow sound
After mine set up, I turned it on and it made a steady clanking sound, turns out there is black foam that is supposed to be glued behind the cooling fan and it had come undone and was hitting the fan. Slide the unit out of its shell and reach your hand in there and see if anything has come loose. (the fan towards the rear of the unit) good luck.
Mar 29, 2012 | Frigidaire FRA256ST2 WallWindow Air...
The slow-lowering lid has reverted to slamming - can i just tighten the bolts to fix it?
If you want to be able to just tip the seat and let if fall without that loud slamming clank, look into getting some Drop-a-Seat cushions, a brand new product that is only $4.99 and absorbs the fall of the toilet seat and eliminates loud clanks. They're non-absorbent, have an easy stick-on installation, and are permanent but removable. www.drop-a-seat.com
Feb 24, 2011 | Toto Carlyle 1-piece Elongated Bowl Toilet
When I start my 96 Camaro Z28 there is a loud clank sound that happens only once. Still Starts. It only happens on start-up and is pretty loud.
the starter may need to be shimmed. could be the drive gear is getting hung up on the flywheel and when engine speeds up it slams it back
Apr 13, 2010 | Chevrolet Camaro Cars & Trucks
I have had a problem with my timing chain, I have replaced it twice and I am still having the same problem, what is going on?
I dont think a timing chain can make that sound "like a jet'.. When a timing chain goes bad - it will either fall of the gears or make a clanking sound..
The sound you describe seems as though it might be vacuum related or exaust or intake - somthing of that nature.
Sep 24, 2009 | 2000 Pontiac Sunfire
Exerpeutic LX9 Super High Capacity Training Cycle Logo
Top Exerpeutic Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exerpeutic Exercise and Fitnes Expert? Answer questions, earn points and help others
