Question about Kenmore Dryers
Drum rotates but does not give off heat
Its a kenmore dryer 5957, the drum rotate, no problem starting dryer... but there is no heat. Cleaned vent, attempted to light pilot did not light, I turned off the gas valve disconnected hose line going into the dryer and then slowly reopened the gas shut off valve, the gas is flowing into the dryer... so now i am stuck. what is my next step in this process?
  • 30 Answers
If the pilot will not light then there is an obstruction between the gas line and the pilot. Most times there is a particle that sticks in the pilot. The pilot needs to be disassembled to clear the blockage.
Usually the the pilot is a simple construction and one of the parts has a tiny hole that easily gets clogged. Obviously this needs cleaned.
If the problem persists, the must be a problem further up. check any elements in between. You could try to blow air through the system with various parts disconnected to identify the obstruction.
Posted on May 18, 2009
Does Samsung DV448AEW/XAA dryer have a reset switch ?
If it over heated most dryers use thermal fuses. They must be replaced if they have blown. Samsung is one of the most difficult that I have seen.
samsung dryer not heating YouTube
Searching Model For Search Your Way DV448AEW 4
SEARCH SAMSUNG
Oct 10, 2014 | Dryers
Maytag dryer clothes gray soot around the drum and door
Sounds like drum belt is out of alignment and rubbing. Check the rotation/alignment with pulleys and drum. If belt is worn replace it. Hope this helps.
Feb 17, 2014 | Dryers
My Kenmore Dryer, Mdl #86681800 won't start when hot
The most likely reason it that the electric motor is failing; the thermal protector on the motor is resetting after the motor cools down. The buzzing is due to a locked rotor in the motor while it is overheated.
Another much less likely possibility is that there is excessive drag on the drum causing the motor to overheat because it is working too hard spinning the drum. Excess drag is due to worn rollers, etc.
Try rotating the drum in the CORRECT direction by hand and see if it seems really hard to rotate. You can try this on a friend or relatives machine to see how much drag is normal.
To determine which way is the correct rotation, just start the dryer, open the door and look fast! To test, just turn it in the same direction as it was rotating before it stopped.
Mar 09, 2013 | Kenmore Dryers
Dryer heats, but drum will not rotate.
try looking for a thermo fuse or check vent on roof ??
May 02, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer modle Tc7102w/t5c7102s was working ok but drum won't rotate
Theres two things to look at, the brushes on the motor, replaceable and cheap, if they are are healthy then there is one or sometimes two large capacitors, these give the motor the ooomf to get it rotating, these fail which is a common problem with washing machines and dryers, again about £5= on ebay.
Mar 25, 2010 | Zanussi TC7102W Electric Dryer
Kenmore dryer Drum not rotating
check the belt,it might have slid off of pulley,make sure smooth side of belt is facing up,ridges should be touching drum
Nov 25, 2009 | Kenmore Dryers
Drum rotates. No Heat. Kenmore Electric Dryer
check the thermal fuse on the top of blower wheel housing,also while your there take off the cover of the housing and clean all the lint out,if your fuse was popped the lint buildup did it,check outside and make sure the air from dryer is blowing out and is not blocked,if it is blow out vent line if it's a long run with a leaf blower,if the thermal fuse is good read out the heater with a meter and if that's good read out the t-stats
Nov 15, 2009 | Kenmore Dryers
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Drum not rotating
If you clean your lint filter after each load faithfully, try removing the dryer vent hose that goes to the outside and inspect it for lint accumulation, water build up, or some other foreign material, as this will restrict air flow and cause your described symptoms. If your are unable to inspect your vent, disconnect it from the back of the dryer and start your dryer to see if it works that way.
May 29, 2008 | LG DLE2532W Electric Dryer
Kenmore gas dryer not heating
GAS DRYER, NO HEAT. CHECK THE HEAT SETTING FIRST.
IS IT ON AIR FLUFF? I'M NOT BEING SMART, BUT YOU WOULD BE SURPRISED HOW MANY CALLS I TAKE THAT ARE ON AIR FLUFF. SECOND, LISTEN FOR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER. IF YOU HEAR IT, LOOK IN THE INSPECTION HOLE ON THE FRONT OF THE DRYER, OR REMOVE THE TOE PLATE TO VIEW THE IGNITOR. IF THE IGNITOR GLOWS AND THEN CLICKS OFF BUT NO FLAME, YOU HAVE A BAD SOLENOID ON THE GAS VALVE. IF THE IGNITOR GLOWS, BUT NEVER CLICKS OFF, THE RADIANT SENSOR ATTACHED TO THE SIDE OF THE BURNER ASSEMBLY IS BAD.
IF YOU DON'T HEAR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER, THE MOST LIKELY CAUSE IS THE THERMAL FUSE LOCATED ON THE BACK OF THE DRYER DOWN NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM ATTACHED TO THE EXHAUST DUCT WITH TWO WIRES ATTACHED.
Apr 10, 2008 | Dryers
Dryers Logo
199 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
