Question about GE Kitchen Ranges
F-3 code on GE gas range
When trying to turn on the oven or broiler, this code F-3 comes up and a beeping noise starts. What does this mean?
  • 6,784 Answers
Hi, You may have a Open or shorted oven temperature sensor (RTD) that should be replaced.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Please rate and have a great day:)
Posted on May 18, 2009
Why doesMy GE gas range broiler and oven not ignite?
When my oven had this problem it turned out that the ignitors for both the oven and broiler had gone bad - yep, both of them. You can tell when an ignitor is bad if it doesn't glow as the oven is started.
I posted some pictures here (I think my answer is #10):
Check out this solution to the GE Profile Spectra JGBP90 Gas Kitchen...
Of course the design of your oven might be different but I suspect the repair would be very similar. Regardless, check to see if the ignitor is glowing.
Jul 08, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
Fi keeps beeping yet control still operates everything normally on my ge xl44 gas range model JGBP26GEN..it started last nite. Ive tried resetting the circuit breaker and pressing the keys in many...
The F1 code can be 1 of 2 things. Try disconnecting the ribbon cable from the touch pad to the clock. Then reconnect power and if the code comes back with 32 seconds the eoc is bad. If it doesn't the touch pad is bad.
Jun 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra eterna series gas stove broiler will not fire up. The glow plug gets hot, but the broiler fails to start.
I have an GE Spectra Eterna Series where the oven comes on and only gets warms no matter what setting the oven is set at. Can some one solve this problem?
Mar 07, 2010 | GE Eterna EGR2000EMBB Gas Kitchen Range
Have a GE gas range. Broiler doesn't work while
First clean the terminals at the control and check for tight wires at the incoming terminal block. Check the neutral wire for a good conection. If the ignitor reads less than 3 amps it does not have enough resistance to open the gas valve. Turn the gas off. Put a clamp on amp meter on the broil ignitor wire. Turn the broiler on. If less than 3 amps.replace the ignitor.
Sep 30, 2009 | GE JGBP28 Gas Kitchen Range
I don't seem to be getting gas to the oven and broiler.
top of stove work but the oven dont work the igniter come on and glows but no gas
Jan 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge oven codes
F2 means your oven temp got too high. At least, that's what the control boards thinks. More than likely you have a bad oven sensor or bad wire to it or a bad connection somewhere between the board and sensor.
Dec 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Kitchen Ranges Logo
64 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
